4th April 2022, 08:47 | #31222 | Link |
SGT_PEPPERS_LONELY_HEARTS_CLUB_BAND is an audio bluray with only a little video on it. All original audio together is just too much to fit on 22,95 GB. You can check that after the job in the working path. If you want to keep all original audio you have to split the disc in two.
7th April 2022, 18:24 | #31224 | Link | |
16th April 2022, 04:07 | #31225 | Link |
Illegal Framerate/unknown
tsMuxer was used to take MKV 4k HDR files and create Blu-ray folders. BRDB was then used to read in the folders to create the intermediate Blu-ray structure. No issues. Because the total file size was too big for a BD-25, I then hit backup so that BDRB would recode the files to fit. But, it immediately failed with an error that the framerate was illegal/unknown. That is not true, as it is 23.976.
I then started the NVENCCRE program and it is happily recoding the videos. Why would BDRB give such an error?
My Total Eclipse 2017 Photos My Nov 2019 Game of Thrones Tour My NEOWISE Comet Photos 2020 Last edited by MrVideo; 18th April 2022 at 02:12. |
17th April 2022, 20:32 | #31226 | Link | |
18th April 2022, 02:12 | #31227 | Link |
This also happened back on 2/07/22. But here are the recent entries:
---------------------- [04/15/22] BD Rebuilder v0.61.25 [21:45:26] Source: JESSICA_JONES-S1 - Input BD size: 28.18 GB - Approximate total content: [03:25:18.264] - Target BD size: 22.95 GB - Windows Version: 6.1 [7601] - Quality: High Quality (Default), 1-Pass VBR - UHD-BD source detected. - Decoding/Frame serving: NVENCC - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [21:45:28] PHASE ONE, Encoding - [21:45:28] Processing: VID_00001 (1 of 4) - Error: Video framerate is illegal/unknown. [21:45:28] - Failed to retrieve audio, aborted ---------------------- [04/15/22] BD Rebuilder v0.61.25 [21:51:32] Source: JESSICA_JONES-S1 - Input BD size: 28.18 GB - Approximate total content: [03:25:18.264] - Target BD size: 22.95 GB - Windows Version: 6.1 [7601] - Quality: High Quality (Default), 1-Pass VBR - UHD-BD source detected. - Decoding/Frame serving: NVENCC - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [21:51:32] PHASE ONE, Encoding - [21:51:33] Processing: VID_00001 (1 of 4) - Error: Video framerate is illegal/unknown. [21:51:33] - Failed to retrieve audio, aborted
My Total Eclipse 2017 Photos My Nov 2019 Game of Thrones Tour My NEOWISE Comet Photos 2020 Last edited by MrVideo; 18th April 2022 at 20:07. |
18th April 2022, 15:26 | #31228 | Link | |
I had the same issue as previously posted. It appears both our sources are 4K(UHD). I wonder if that has something to do with it? Below is my information. [03/22/22] BD Rebuilder v0.61.25 [11:58:37] Source: SS_00000 - Input BD size: 59.52 GB - Approximate total content: [02:28:09.880] - Target BD size: 46.26 GB - Windows Version: 6.2 [9200] - MOVIE-ONLY mode enabled - Quality: Highest (Very Slow), Two Pass - UHD-BD source detected. - Decoding/Frame serving: FFMPEG - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640 [11:58:39] PHASE ONE, Encoding - [11:58:39] Processing: VID_00000 (1 of 1) - Error: Video framerate is illegal/unknown. [11:58:39] - Failed to retrieve audio, aborted Here is the mediainfo for the file - General ID : 1 (0x1) Complete name : C:\Users\Brian\Desktop\SS\BDMV\STREAM\00000.m2ts Format : BDAV Format/Info : Blu-ray Video File size : 59.5 GiB Duration : 2 h 28 min Overall bit rate mode : Variable Overall bit rate : 57.5 Mb/s Maximum Overall bit rate : 35.5 Mb/s Video ID : 4117 (0x1015) Menu ID : 1 (0x1) Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5.1@High Codec ID : 36 Duration : 2 h 28 min Bit rate : 54.6 Mb/s Width : 3 840 pixels Height : 2 160 pixels Display aspect ratio : 16:9 Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 (Type 2) Bit depth : 10 bits Bits/(Pixel*Frame) : 0.274 Stream size : 56.5 GiB (95%) Color range : Limited Color primaries : BT.2020 Transfer characteristics : PQ Matrix coefficients : BT.2020 non-constant Mastering display color primaries : BT.2020 Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2 Maximum Content Light Level : 9978 cd/m2 Maximum Frame-Average Light Level : 867 cd/m2 Audio ID : 4352 (0x1100) Menu ID : 1 (0x1) Format : AC-3 Format/Info : Audio Coding 3 Codec ID : 129 Duration : 2 h 28 min Bit rate mode : Constant Bit rate : 640 kb/s Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Bit depth : 16 bits Compression mode : Lossy Stream size : 678 MiB (1%) Service kind : Complete Main |
22nd April 2022, 16:59 | #31233 | Link | |
frame_rate: This 4-bit field indicates the frame-rate of the video stream associated with a stream number for the stream_attributes(), and shall be set to a value according to frame_rate defined in Table 5-24 of 5.4.4.3.2. It isn't optional. Are you saying the PlayItem() entry doesn't have a video stream listed? Last edited by jdobbs; 22nd April 2022 at 17:12. |
23rd April 2022, 01:00 | #31236 | Link | |
My Total Eclipse 2017 Photos My Nov 2019 Game of Thrones Tour My NEOWISE Comet Photos 2020 Last edited by MrVideo; 24th April 2022 at 01:48. |
