30th March 2014, 00:15 | #19721 | Link | |
1. Re-rip disc and see if it goes away. 2. If above does not try different player to see if it is there. 3. If yes for 2, change it.
30th March 2014, 00:18 | #19722 | Link | |
No, it's not a layer break issue; it's a bad rip. All you can do is to try cleaning the disc and re-ripping it. Standalone players are designed to ignore little problems like that from a bad disc surface, but re-encoding algorythms on a PC can't do that. It's possible for them to just create a momentary pixelated image, but it is quite common for the video to hang while the audio continues.
30th March 2014, 00:35 | #19727 | Link | |
30th March 2014, 00:48 | #19730 | Link |
BD-50s have two layers, and it has to change between them, but there isn't a "layer break" in the same sense as what you may be thinking of in a DVD. You'll never see a pause of hiccup at the change like you might on a DVD.
30th March 2014, 00:56 | #19732 | Link |
Ohh-kay, first encode job finished on 0.47.03. Unfortunately it ended in an error message:
One or more reencoded files (00052.m2ts) are missing. Cannot complete the REBUILD process. Code:
[03.29.14] BD Rebuilder v0.47.03 (beta) [21:49:51] Source: KHUMBA - Input BD size: 35,35 GB - Approximate total content: [01:58:20.843] - Target BD size: 22,95 GB - Windows Version: 6.1 [7601] - Quality: Highest (Very Slow), ABR - Output folder: M:\_ENCODES\ - MVC 3D Output Mode enabled - Decoding/Frame serving: FRIMDecode - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 - Resuming from previously started job. [21:49:57] PHASE ONE, Encoding - [21:49:57] Processing: VID_00006 (1 of 11) - [21:49:57] Reencoding video [VID_00006] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 122*712 frames - Bitrate: 25*211 Kbs - Using FRIMEncoder for MVC encoding - [21:49:57] Reencoding: VID_00006, Pass 1 of 1 - [01:27:00] Video Encode complete - [01:27:00] Processing audio tracks - Track 4352 (eng): Keeping original audio - Track 4353 (eng): Keeping original audio - [01:27:00] Multiplexing M2TS - [01:35:47] Blanking: VID_00012 (2 of 11) - [01:35:47] Processing: VID_00014 (3 of 11) - [01:35:47] Extracting A/V streams [VID_00014] - [01:36:27] Reencoding video [VID_00014] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 10*032 frames - Bitrate: 26*313 Kbs - Using FRIMEncoder for MVC encoding - [01:36:27] Reencoding: VID_00014, Pass 1 of 1 - [01:38:54] Video Encode complete - [01:38:54] Processing audio tracks - Track 4352 (eng): Reencoding audio to AC3... - [01:38:57] Multiplexing M2TS - [01:39:33] Scanning for 3D CLPI info... - [01:39:47] Processing: VID_00037 (4 of 11) - [01:39:47] Extracting A/V streams [VID_00037] - [01:39:53] Reencoding video [VID_00037] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 470 frames - Bitrate: 16*528 Kbs - Using FRIMEncoder for MVC encoding - [01:39:53] Reencoding: VID_00037, Pass 1 of 1 - [01:40:00] Video Encode complete - [01:40:00] Processing audio tracks - Track 4352 (eng): Keeping original audio - [01:40:00] Multiplexing M2TS - [01:40:04] Processing: VID_00043 (5 of 11) - [01:40:04] Extracting A/V streams [VID_00043] - [01:40:16] Reencoding video [VID_00043] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 2*976 frames - Bitrate: 19*173 Kbs - Using FRIMEncoder for MVC encoding - [01:40:16] Reencoding: VID_00043, Pass 1 of 1 - [01:41:00] Video Encode complete - [01:41:00] Processing audio tracks - Track 4352 (eng): Keeping original audio - [01:41:00] Multiplexing M2TS - [01:41:07] Processing: VID_00046 (6 of 11) - [01:41:07] Extracting A/V streams [VID_00046] - [01:41:24] Reencoding video [VID_00046] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 4*147 frames - Bitrate: 19*170 Kbs - Using FRIMEncoder for MVC encoding - [01:41:24] Reencoding: VID_00046, Pass 1 of 1 - [01:42:24] Video Encode complete - [01:42:24] Processing audio tracks - Track 4352 (eng): Keeping original audio - [01:42:24] Multiplexing M2TS - [01:42:33] Processing: VID_00064 (7 of 11) - [01:42:33] Extracting A/V streams [VID_00064] - [01:42:37] Reencoding video [VID_00064] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 144 frames - Bitrate: 19*356 Kbs - Using FRIMEncoder for MVC encoding - [01:42:37] Reencoding: VID_00064, Pass 1 of 1 - [01:42:40] Video Encode complete - [01:42:40] Processing audio tracks - Track 4352 (eng): Keeping original audio - [01:42:40] Multiplexing M2TS - [01:42:43] Blanking: VID_00066 (8 of 11) - [01:42:43] Processing: VID_00068 (9 of 11) - [01:42:43] Extracting A/V streams [VID_00068] - [01:43:52] Reencoding video [VID_00068] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 14*202 frames - Bitrate: 19*181 Kbs - Using FRIMEncoder for MVC encoding - [01:43:52] Reencoding: VID_00068, Pass 1 of 1 - [01:47:18] Video Encode complete - [01:47:18] Processing audio tracks - Track 4352 (eng): Keeping original audio - [01:47:18] Multiplexing M2TS - [01:47:55] Processing: VID_00070 (10 of 11) - [01:47:55] Extracting A/V streams [VID_00070] - [01:48:10] Reencoding video [VID_00070] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 3*598 frames - Bitrate: 19*186 Kbs - Using FRIMEncoder for MVC encoding - [01:48:10] Reencoding: VID_00070, Pass 1 of 1 - [01:49:03] Video Encode complete - [01:49:03] Processing audio tracks - Track 4352 (eng): Keeping original audio - [01:49:03] Multiplexing M2TS - [01:49:13] Processing: VID_00072 (11 of 11) - [01:49:13] Extracting A/V streams [VID_00072] - [01:49:27] Reencoding video [VID_00072] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 3*094 frames - Bitrate: 19*181 Kbs - Using FRIMEncoder for MVC encoding - [01:49:27] Reencoding: VID_00072, Pass 1 of 1 - [01:50:13] Video Encode complete - [01:50:13] Processing audio tracks - Track 4352 (eng): Keeping original audio - [01:50:13] Multiplexing M2TS [01:50:23]PHASE ONE complete [01:50:23]PHASE TWO - Rebuild Started - [01:50:23] Converting SSIF file references - [01:50:38] Rebuilding BD file Structure [01:57:03] - Failed to REBUILD There are no files beginning with 00052 in the WORKFILES directory. VID_00012 and VID_00066 were blanked manually. BDRB's Stream window does not list a VID_00052 but there is a 00052.m2ts (stereo, 213MB) on disc. Could this have happened because I resumed an earlier encoding job which stopped at FRIMEncoder crashing? Last edited by colinhunt; 30th March 2014 at 01:22. |
30th March 2014, 02:15 | #19734 | Link |
Ran another encode, again with hardware decode/encode. FRIMEncoder behaved well, but job ended in the same error message as the previous one. It's again complaining about a missing 00052.m2ts. This time I made sure to start from scratch instead of resuming.
Looks to me like BDRB was not building a full backup, in fact. A lot of non-blanked files are missing from WORKFILES and from the partially-completed output. Last edited by colinhunt; 30th March 2014 at 02:20. |
30th March 2014, 03:06 | #19738 | Link | |
