12th September 2014, 21:59 | #241 | Link | |
Hi Nikse
I keep getting this error: Quote:
13th September 2014, 06:25 | #242 | Link | |
LAV Filters cannot decode all video files so you might switch to VLC media player for special files like 10-bit color or similar. Also, from version 3.4.0 SE runs 64-bit on 64-bit operating systems which will require 64-bit lav filters too. |
15th September 2014, 20:37 | #244 | Link |
theres still problem with hearing impaired stuff removal in .ass subs and the "remove text before a colon" option. when the "only if text is UPPERCASE" box is ticked as well, then the information about the speaker is not removed:
{\an4\pos(1335,891)}NIC: Shh! --> {\an4\pos(1335,891)}NIC: or {\an4\pos(691,748)}WOMAN: (OVER PA) --> {\an4\pos(691,748)}WOMAN: (both lines should be removed entirely as they dont include any speech) and when I leave the "only if text is UPPERCASE" box unticked then everything before the colon is removed including the screen position information part of the line: {\an4\pos(652,817)}NIC: "Your hack into MIT --> "Your hack into MIT (screen position information needs to be preserved and not taken into consideration for removal if there is still speech present in the line)
21st September 2014, 05:55 | #246 | Link | |
24th September 2014, 13:12 | #247 | Link | |
Standard Fade effect, Fade in/ out adjustable strengt 1-100%, and an almost ridiculous lot of else subtitle settings, selections/ adjustments/features/gimmicks on top of that. Be aware! You prefer it rather basic and readily comprehensible- better dont bother with |
25th September 2014, 13:28 | #248 | Link |
Do you think it'll be possible to open several subs at the same time?
For example, sometimes I work with subs from TV series, and I'd like to be able to spell check them all with exactly the same settings, so that certain weird name not in the dictionary can be skipped automatically on all the subs or certain words be renamed on all subs. But I'd rather not add them all permanently in the program because occasionally there may be spelling variations on a particular name, which may be used in one movie, but spelled differently in another. So I want to manually specify which spelling I want to use. This is often the case for us who work with English subs for non English movies. Maybe each sub can be in it's own tab or something. Also, you should separate word list which we have added manually into a dedicated XML file, so that each time we upgrade your program we can simply just copy this XML file over. Currently all are stored in the eng_OCRFixReplaceList and each time I upgrade your program, I need to manually add in my own stuff in there, because each new version will write over this file. Problem is that all the words will be sorted alphabetically in eng_OCRFixReplaceList, and often I don't remember which one was my own. Hope you understand what I'm trying to say. Last edited by Mole; 25th September 2014 at 13:35. |
26th September 2014, 18:22 | #249 | Link |
I think the subtitle edit have a little bug with sub color. Check this script:
VAV STUDIO Hân Hạnh Giới thiệu Bộ phim: <font color=yellow>"CUỘC CHIẾN LUÂN HỒI"</font> Hope you can fix it as soon as possible. |
3rd October 2014, 13:49 | #250 | Link |
Hi Nikse,
I have a lot of problems with DVB-SUB (included in TS) ; 1)a lot of ts can't be opened ("unhandled exception") 2)with those which are opened, the size after conversion in Blu-ray sup without OCR is completely different (much more little) than what I see when I play the original TS in MPC-HC and VLC (which both handle DVB-SUB). But for SE the size of the lines are the same before and after conversion : I mean that just after parsing the ts, if the detected height of a line is 33 (in the OCR window), the size will still be 33 for this line when opening the Blu-ray sup created from this ts, thus I don't know what is the real size and why they are different for MPC-HC and VLC while they are the same for SE. And when put on AVCHD and played with a standalone player, the size of the Blu-ray sup is also very little, same size than what I see in MPC-HC and VLC (when playing remuxed TS with the Blu-ray sup). But I'm sure that the original TS is correctly displayed by MPC-HC and VLC because they display the same subtitle size than my DVB recorder. That's why I'm sure SE reduce the size of these DVB-SUB, but why ... 3)when I make OCR with Tesseract, a lot of words are not correctly identified while they are well readable (but maybe a little bit too tiny for Tesseract) 4)even when they are correctly identified, I have to skip them all one by one because SE don't know these words while they are very common Last edited by Music Fan; 3rd October 2014 at 13:56. |
3rd October 2014, 14:18 | #251 | Link |
@Mole: In next update the OCR fix list and the names etc list will have a "user" file.
@minhjirachi: thx, should be fixed here: http://www.nikse.dk/SubtitleEdit.zip (on src on github + next release) @Music Fan: 1) the crash should be fixed here: http://www.nikse.dk/SubtitleEdit.zip (on src on github + next release) Could you verify? 2) Could I check the file (email/msg)? Perhaps VLC/MPC-HC scales the subs etc? 3) yes, small fonts don't work too well in Tesseract. 4) English vs US? Try another dictionary. |
4th October 2014, 13:43 | #252 | Link | |
Thanks Nikse for all responses.
Here is a 1080i file that can be opened and "OCRed" ; http://www72.zippyshare.com/v/94029699/file.html You should be able to play it in VLC and MPC-HC to see the subtitles size (activate the french sub if not done automatically). When exported in 1080p Blu-ray sup (whatever the bottom line setting) and remuxed in TS with TSmuxer, the subtitles size is much more little. By the way, could you add the possibility to avoid the bottom line setting to have exactly the same position than in the original sub (if you solve the resize problem, because currently the position changes anyway because of the resize) ? I don't believe so, they are displayed at the same size than with my DVB recorder. Mmmh, could the other method work ? That's french, I didn't realize I had to change the language , that's ok now (I tried with the old 3.4.2 version, not the one you linked yesterday) But a lot of t and q are considered as ( And I had to download the french dictionnary while there was already a fr-FR.xml file in the language folder. Or does it only concern the language of the program ? If yes, where are stored the dictionnaries ? Anyway, there are still two problems ; crash with some ts and resize in Blu-ray sup. Last edited by Music Fan; 4th October 2014 at 13:45. |
5th October 2014, 20:21 | #253 | Link | |
I chose 2 for x and y (twice the size for width and height to keep text's proportions). Then I open this sup in SE and launch the OCR which is better done |
5th October 2014, 20:42 | #254 | Link |
@Music Fan: OK, nice - in the meantime I've hopefully fixed the last TS crash here: http://www.nikse.dk/SubtitleEdit.zip (also in latest src on GitHub)
5th October 2014, 21:02 | #255 | Link |
Thanks, it doesn't crash anymore
I recall my other questions ; 1)did you try my ts file to see why it's resized when converted in Blu-ray sup ? 2)could you add the possibility to avoid the bottom line setting to have exactly the same position than in the original sub ? 3)in which folder are stored the dictionnaries ? |
12th October 2014, 20:00 | #257 | Link |
Problem with timings
I have a problem when converting from SUP to SRT.
When there are two sets of subtitles shown, one at the top of the screen and one at the bottom at the same time, the timings of the bottom get screwed up I mean lets say a subtitle appears at the top of the screen from 15:30:20 - 18:20:12, and lets say something appears at the bottom from 17:15:15 - 19:10:12. With the OCR method, the SRT file generates timecodes of 15:30:20 - 18:20:12 for the top subtitle and 18:20:12 - 19:10:12 for the bottom one. Is there anyway to fix this (except for manually setting the timecodes of course). Last edited by mantis2892; 12th October 2014 at 20:03. |
13th October 2014, 02:25 | #258 | Link |
I have a alignment problem with this script:
Phim thuyết minh độc quyền tại <font color=yellow><b> WWW.ABC.NET </b></font> Still have error with time stamp when exporting as xml/png. Subtitle Edit cannot re-load the previous setting. Last edited by minhjirachi; 13th October 2014 at 17:21. |
21st October 2014, 14:01 | #259 | Link |
v3.4.3 has been released 8 days ago, I don't understand why Nikse555 didn't tell us this ;
https://github.com/SubtitleEdit/subtitleedit/releases |
21st October 2014, 19:32 | #260 | Link |
He, I only updated the title of this thread.
SE 3.4.3 has some general performance improvements + some fixed memory leaks (especially in batch convert). Also, "Compare" + "Measurement converter" are broken... not on purpose though |
