#21021 | Link | ||
EPYC absolutely has NUMA. Motherboard: https://www.supermicro.com/en/produc...oard/h13ssl-nt Processor: https://www.amd.com/en/products/proc...pyc-9355p.html Memory: 6 x Micron MTC20F2085S1RC64BD2 Memory 32GB DDR5 6400MHz RDIMM My testing with NUMA with RB showed no real performance gains compared to using threads. Since I'm using a virtual machine and my server is doing other workloads, using NUMA would not give me the flexibility to fully utilize the resources of the server. So threaded is what I'll need to use. |
#21022 | Link | |
Would be a problem for you guys using Distributed Encoding mode if I replaced PC name to IP address in UNC paths?
\\192.168.0.1\Ripbot264temp instead of \\MY-PC\Ripbot264temp Is there any disadvantage of using IP address in path? What are your thoughts? ChatGPT4 gives this answer Quote:
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 4th January 2025 at 18:12. |
#21023 | Link | |
In fact I used to have a machine I wanted to add to the mix, but I kept an active vpn connection on that one, and I had issues with the name resolution back to the client. \\ip\share would have connected back just fine. I don't remember if I found a work around or not. I say go for it!! |
#21024 | Link |
Big Bit Savings Now !
Go for direct IP addressing +1, as soon as I adressed storage servers manually here: even for control, not bulk data the whole rig became snappier.
#21025 | Link |
Multipass
@ Ryushin,
So why an EPYC, and not Threadripper or Xeon ? @ rlev11, Yes, that last chunk is the worst thing with DE, and inevitably the last is is always the biggest, and 99% of the time ends up being on the slowest PC in the "pool" ![]() And what exacerbates the situation more, is if the slowest PC is way slower than the rest ![]() In a perfect world all the PC's need to be the same. It would be nice if the last chunk was the smallest. @ Atak_Snajpera, Actually shocked that you're asking the "community" about a possible change to DE, you generally make changes, release them without much or any explanation or instruction, and the user has to figure it out for themselves. If this change is implemented, and provides better stability & connectivity, then by all means. |
#21026 | Link |
I just updated RB on my 7950X, and I noticed that this setting doesn't change depending on the PC used, or the video that's loaded...
SetCacheMode(CACHE_FAST_START) SetMemoryMax(8192) #PREFETCH_LIMIT=12 Code:
SetCacheMode() SetMemoryMax(20480) The Prefetch_Limit setting can be changed, so why not the SetMemoryMax, on the same page. |
#21027 | Link | |
Pig on the wing
#21030 | Link | |
#21031 | Link | |
#21032 | Link |
Info.txt Missing - Bug?
I set up a new job to run and it failed. I got an error about info.txt missing. Went into the job and found info1.txt. Renamed it to info.txt and the job ran fine form that point on. Could be a new bug from the recent changes.
#21033 | Link | |
I only did a few quick encodes so far with the updated encodingclient with no issues. will be able to fire up the whole farm in a couple days to do a more thorough test. Pretty sure the only file that changed was encodingclient.exe. Looked like everything else remained at the same version number. I would try the same video again and just use mdegrain and see if it at least starts encoding as a test. |
#21035 | Link | |
See my post from 27 November about adding in the boost setting to the control panel power settings https://forum.doom9.org/showthread.p...72#post2010572 |
#21036 | Link | |
#21037 | Link | |
#21038 | Link | |
then I made two .bat files on my desktop, balanced.bat and highperf.bat. for balanced.bat I used this command powercfg /s 381b4222-f694-41f0-9685-ff5bb260df2e For Highperf I used this command: powercfg /s 8c5e7fda-e8bf-4a96-9a85-a6e23a8c635c These worked on all my machines, so the strings should be the same. A cmd of powercfg /l will list all your power plans along with the string to use if there is a difference. Now I can switch on the fly at anytime just by double clicking the power plan i need at the time. Last edited by rlev11; 8th January 2025 at 20:53. Reason: additional line |
#21039 | Link | |
So everything is happy now. Full speed ahead. |
#21040 | Link | |
