1st January 2018, 19:43 | #5001 | Link | |
MKVToolNix author
I've just filed this issue.
Latest MKVToolNix is v83.0 If I ever ask you to upload something, please use my file server. |
1st January 2018, 20:00 | #5002 | Link |
TrackNumber can't be zero because the spec don't allow zero as a TrackNumber ("But the TrackNumber [..] can't be zero, because Tracknumbers start at 1" is circular reasoning); the size encoded in an EBML variable-sized integer can be zero (although the coded EBML variable sized integer can't be). You can even encode a size of zero in an EBML integer with 8 octets.
3rd January 2018, 12:12 | #5003 | Link |
Hello,
a question about TrueHD and AC3 Core. Do you think we will get one day the availabilty to have a truehd and ac3 core in the same track (like m2ts) or this feature will never be added to the mkv spec ? Thks a lot for your work |
3rd January 2018, 12:26 | #5004 | Link | |
If you want it to be able to re-create a m2ts with a combined track later, it still wouldn't help you, since you need a m2ts muxer that can write the additional metadata required to clearly split these two tracks - and if it can do that, it would also be able to just take a truehd and ac3 track separately and combine them.
3rd January 2018, 12:30 | #5005 | Link | |
MKVToolNix author
This is not a concern for Matroska. If the player does support Matroska, then it's highly likely that it'll be able to do somewhat smart track selection already based on the CodecIDs it supports.
3rd January 2018, 12:30 | #5006 | Link | |
1 TrueHD track + 1 AC3 track = 1 TrueHD + Core Track ? Because for DTS HD 1 DTSHD track + 1 DTS track is different from only one DTSHD+Core track (because it always include the core)[maybe I already have my answer : does TrueHD track can exist without core unlike DTS HD ?] My question is really about the size of the final mkv file (not player support ;-)) Thks ! Last edited by psychoboust; 3rd January 2018 at 12:38. Reason: complement |
3rd January 2018, 12:56 | #5007 | Link |
MKVToolNix author
TrueHD+AC-3 is not comparable to DTSHD+its core. Two completely different things. Why? Because you can decode TrueHD without AC-3 and AC-3 without TrueHD. However, you cannot decode the DTS HD extension without its core (!). Therefore both TrueHD and AC-3 form their own logical track, they can be used without each other just fine, you don't have to keep them together. With DTS you can separate the core from the HD extension, but then you can only decode the core part, but not the HD-only part.
3rd January 2018, 17:28 | #5008 | Link |
ok, if understand :
a TrueHD + AC3 in the same track from a m2ts should have the same size comparing to a mkv with (the same) 2 tracks (1 TrueHd and 1 Ac3) because Truehd doesn't share information with AC3. True ? So we should not call AC3 as Core in TrueHD when in the same track in m2ts file ? If so, I understand why there is no interest supporting this "feature" |
3rd January 2018, 18:29 | #5009 | Link |
MKVToolNix author
One could say that the AC-3 part is a lossy representation of the same content that the TrueHD part is a lossless representation of, and that both parts are independent of each other. Of course that's quite a mouthful to say; hence people usually just calling it something else. But yes, calling the AC-3 part a "core" is a misnomer in my opinion.
Latest MKVToolNix is v83.0 If I ever ask you to upload something, please use my file server. Last edited by Mosu; 3rd January 2018 at 18:41. |
6th January 2018, 13:49 | #5010 | Link |
Thanks for your feedback.
I made a simple test with EAC3TO eac3to.exe "dolby_ATMOS_amaze_lossless-DWEU_.track_4352.thd" acore.ac3 -core TrueHD/AC3 (Atmos), 7.1 channels, 48kHz (embedded: AC3, 5.1 channels, 640kbps, 48kHz) Extracting AC3 stream... Creating file "acore.ac3"... eac3to334>eac3to.exe hd_dts_animated_logo_lossless-DWEU.track_4352.dtshd acore.dts -core DTS Master Audio, 7.1 channels, 24 bits, 48kHz (core: DTS, 5.1 channels, 1509kbps, 48kHz) Extracting DTS core... Creating file "acore.dts"... Even this software tell that AC3 is "embedded" and a different "stream" unlike the DTS which is called "Core" And to answer my question, if you convert a m2ts to a mkv, TrueHD+AC3 track will have the same size than 1 TrueHD track + 1 AC3 Track. Which is not the case for DTSHD (which can't be separated from its core) So I Agree, This "feature" is not useful for MKV. Thks again for your time. |
6th January 2018, 18:16 | #5011 | Link |
Matroska find' ich toll
Hi Mosu
I have a question about: Split parts by timestamps The split-times must be ordered? Or can I use something like this: 0s-100s,+600s-700s,+200s-300s Is MTX so smart to connect different periods of time that are not ordered. |
6th January 2018, 18:22 | #5012 | Link |
MKVToolNix author
They have to be sorted as mkvmerge doesn't sort them itself.
6th January 2018, 19:01 | #5014 | Link |
MKVToolNix author
Edit: I'm clearly too tired to think clearly about this and not write total rubbish.
mkvmerge processing input once, from start to finish. It cannot jump backwards in time. Therefore the split points you've written will result in an error message during parsing the command line parameters.
Latest MKVToolNix is v83.0 If I ever ask you to upload something, please use my file server. Last edited by Mosu; 6th January 2018 at 19:07. |
6th January 2018, 19:19 | #5016 | Link |
MKVToolNix author
Yes, huuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuge amount of work. It would involve pretty much rewriting all input, all output modules of mkvmerge as well as the muxer core logic. I can safely say that'll never happen.
15th January 2018, 02:37 | #5018 | Link |
I don't understand how to use a basic function. I add 4 different files, each 25s long, and get a single file which is 25s long. The file has 4 video and 4 audio streams in it. How do I get them to play one after another?
Is it possible to do what I'm trying, or do I have to encode the 4 files into 1. Last edited by Arm3nian; 15th January 2018 at 02:42. |
