14th December 2017, 23:08 | #2881 | Link | |
core.std.BlankClip(format=vs.YUV420P8, length=1000, color=[n, 128, 128]) |
14th December 2017, 23:40 | #2883 | Link | |
from vapoursynth import COMPATBGR32, RGB24, YUV420P8, RGBS |
17th December 2017, 04:00 | #2885 | Link |
avisource, alpha channel questions
R40 x64 There seems to be problems with the alpha channel using AVISource on an RGB32(RGBA) AVI with a valid alpha channel (I tested uncompressed, lagarith, ut video codec) . The same AVI is ok in avisynth, and showalpha() shows the correct alpha Code:
import vapoursynth as vs core = vs.get_core() video = core.avisource.AVISource(r'F:\blah.avi', pixel_type="RGB32", alpha=True) #video[0].set_output() video[1].set_output() alpha channel seems to work ok with other things, e.g. on an imagemagick RGBA png sequence , video[1].set_output() would show the correct alpha Q2) How do you send RGB32 data to something else ? . If python holds it as an array, how would you encode, say an RGBA png sequence with ffmpeg ? |
17th December 2017, 13:28 | #2886 | Link | |
Professional Code Monkey
2. There's actually no easy way to do that. I mean ideally you'd output RGBAP but the default output handling doesn't take this into consideration. How about a solution like this: Code:
clip.set_output(alpha=alpha_clip)
17th December 2017, 18:15 | #2887 | Link |
UT Video ULRA , alpha channel sample
http://www.mediafire.com/file/lsb7cz35387ow1z/UTVideo_ULRA.avi I think that should work, but would alpha=True be more consistent ? Or would you have to define the alpha_clip specifically ? |
17th December 2017, 19:26 | #2888 | Link | |
18th December 2017, 17:49 | #2889 | Link |
20th December 2017, 01:43 | #2890 | Link |
I think something is up with the "bits" and "floatout" parameters of std.Lut/Lut2, you can "evaluate" it but previewing and encoding crash:
import vapoursynth as vs core = vs.core clip = core.std.BlankClip(format=vs.GRAY8) core.std.Lut(clip, lut=[0]*256, bits=16).set_output() Script was successfully evaluated. Output video info: Frames: 240 | Time: 0:00:10.000 | Size: 640x480 | FPS: 24/1 = 24 | Format: Gray16 Crash on preview Code:
import vapoursynth as vs core = vs.core clip = core.std.BlankClip(format=vs.GRAY8) core.std.Lut(clip, lutf=[0.]*256, bits=32, floatout=True).set_output() Script was successfully evaluated. Output video info: Frames: 240 | Time: 0:00:10.000 | Size: 640x480 | FPS: 24/1 = 24 | Format: GrayS Crash on preview So, std.BoxBlur seems to be really, really slow at copying planes. The difference between splitting to GRAY clips and using the planes parameter is huge Code:
args = dict(hradius=2, hpasses=1, vradius=2, vpasses=1) clip = core.std.BlankClip(None, 1920, 1080, vs.YUV444PS, 500) core.std.BoxBlur(clip, planes=[0], **args).set_output() Time elapsed: 0:07.476 - 66.88474253259326474108 FPS clip = core.std.BlankClip(None, 1920, 1080, vs.GRAYS, 500) core.std.BoxBlur(clip, **args).set_output() Time elapsed: 0:02.996 - 166.90969959623313911834 FPS Last edited by kgrabs; 20th December 2017 at 12:48. |
20th December 2017, 20:12 | #2891 | Link |
I'll look into the first one - FIXED NOW. Second is memory bw limited due to blankclip having to fill all 3 planes. Set keep=1 in blankclip and you'll see that it's really close. Or should be at least...
VapourSynth - proving that scripting languages and video processing isn't dead yet Last edited by Myrsloik; 20th December 2017 at 22:00. Reason: FIXED IT |
27th December 2017, 15:20 | #2892 | Link |
R41-test4
It's a test version because some fairly big changes have been made for the alpha output part. To use this simply do clip.set_output(alpha=alpha_clip) and it will be output through vspipe. Note that Y4M doesn't get alpha and can't be combined with it. Test it well. Code:
r41: updated to zimg v2.7 added convenient alpha output to vspipe and vsscript, set_output() in python now takes a second optional alpha clip which will be used for this fixed avisource leaking one frame reference on destruction updated plugin list to be more consistent with links to source/binaries and doom9 discussion thread fixed lut triggering a fatal error when the bits argument is used fixed regression that prevented alpha output from working in avisource removed dependency on the now deprecated codecvt header fixed memory leak where modifyframe wouldn't release the function reference when done fixed a rare memory leak that could happen if the core was freed before the last frame fixed a memory leak that would happen if a python videoframe object was instantiated imwri will no longer write alpha to images unless an alpha clip is specified improved imwri's input and output format guessing, now integer and float image formats will most likely be returned in native precision imwri now requires hdri support since it's enabled by default in version 7, as a result of there only being one major configuration the namespace is now always imwri stackvertical now properly rejects compat formats instead of producing unexpected output the default initial cache size now also depends on the number of threads used fixed negative frame request error listing the parent node name instead of the correct name fixed expr clamping of 9-15 bit output, previously it would clamp to 16bit fixed corrupted output in expr when mixing int and float for input and output (pinterf)
28th December 2017, 13:07 | #2893 | Link |
I did some more testing and R41-test4 should be considered RC quality.
30th December 2017, 19:49 | #2894 | Link |
R41-RC1
Fixes an avisource crash and some minor typos. Also lots of imwri changes but that's a separate thread.
31st December 2017, 17:24 | #2895 | Link |
About the BoxBlur thing, there's still a pretty big difference
#Main from vapoursynth import core, GRAY, YUV, YUV444PS args = dict(hradius=2, hpasses=1, vradius=2, vpasses=1, planes=[0]) # Use "planes" clip = core.std.BlankClip(None, 1920, 1080, YUV444PS, 2000, keep=1) clip = core.std.BoxBlur(clip, **args) clip.set_output() # Time elapsed: 0:27.135 - 73.70663065422803583715 FPS # Split to Gray clip_yuv = core.std.BlankClip(None, 1920, 1080, YUV444PS, 2000, keep=1) clip = core.std.ShufflePlanes(clip_yuv, 0, GRAY) clip = core.std.BoxBlur(clip, **args) clip = core.std.ShufflePlanes([clip, clip_yuv], [0,1,2], YUV) clip.set_output() # Time elapsed: 0:11.011 - 181.64144952606065430700 FPS Time elapsed: 0:05.794 - 345.20685825648109812391 FPS (split to gray) Time elapsed: 0:07.107 - 281.39460754565209299471 FPS (use "planes") PS sry for being lazy and taking like a week to do it :^) Edit: Rather than also being 73fps like the "use planes" test, changing it to planes=[0,1,2] is actually only about 63fps. PPS I used R41-RC1 Last edited by kgrabs; 31st December 2017 at 17:37. |
31st December 2017, 18:27 | #2896 | Link | |
6th January 2018, 22:04 | #2897 | Link |
R41 RC2
Should fix BoxBlur not copying planes the fastest possible way. Otherwise no real changes from RC1. So test BoxBlur a bit to verify that I got it right.
9th January 2018, 20:09 | #2898 | Link |
R41 released. The usual post about it. Have fun with less shitty alpha support.
10th January 2018, 07:53 | #2899 | Link | ||
Is it like this ? Code:
clip[0].set_output(alpha=clip[1]) What exactly is COMPATBGR32 ? I know it's for legacy purposes, sometimes RGB flip , but does it carry a valid alpha or is it a "dummy" alpha ? or something completely different. I figured it was remotely similar to "RGB32" in avsiynth-ese |
10th January 2018, 10:56 | #2900 | Link | |
Compatbgr32 is simply packed bgra with dummy alpha. It only exists for avisynth compatibility reasons.
