13th November 2013, 20:11 | #681 | Link | |
13th November 2013, 22:21 | #682 | Link |
Physic, this is awesome... I had no idea you were even working on this and came here looking for an easier to way to make a simple straight-play 3D disc...
Works great with video files created with Rovi's TotalCode software too. Two tiny requests? 1- Add an option to remove the replay at the end of the video (so the discs just stops instead of looping) (Not sure if there's a way to do this already, but didn't see it) 2- When doing a Blu-ray ISO, maybe an option to point to a pre-created folder containing the META info? I can create the content (the DL folder and files), just need a way to add it into the ISO... Obviously frivolous stuff for when you have a chance, not sure if they were mentioned before as I didn't read the whole thread... Just thought I'd throw it out there. Rik |
13th November 2013, 22:39 | #683 | Link | |
If you fail to plan; you plan to fail, would you not agree? Think about it. Last edited by HWK; 14th November 2013 at 01:33. |
14th November 2013, 03:11 | #684 | Link | ||
Senior Member
tsmuxer does display the error "Matroska parse error: invalid H264 NAL unit size. NAL unit truncated." when the mkv input video has header compression. The only fix right now is to remux the mkv with header compression disabled. |
14th November 2013, 03:39 | #685 | Link | |
Yes, v1.x.x clearly does not work so I want a fix now when Physic is back and develops the new beta. This format has been out for quite sometimes but some applications like xbmc still outdated and cannot recognize this format. Last edited by sunnychan; 14th November 2013 at 03:44. |
14th November 2013, 07:51 | #686 | Link |
PgcEdit daemon
I need a way to extract the Z depth of each individual subtitles of a subtitle track to convert the subs to Side by Side or Top/Bottom.
I can't find any useful info on how that information is stored in a BD3D, and how to retrieve it. From the quote above, I guess I need to read the offset metadata. Where is that metadata stored, and what is its format? Any pointer will be much appreciated.
14th November 2013, 11:13 | #687 | Link |
Good day
Wonder if it is possible to implement compatibility with the VOB files and mpg, as in the stable version 1.10.06. This version allows you to generate a single file mpg from DVD (VOB files) and allows you to do muxing/demuxing from mpeg file. In the latest version this is not possible. Sincerely thank you |
14th November 2013, 11:33 | #688 | Link |
I have mutiplexed 3d mvc video files produced with Vegas Pro. I have also add an ac3 and srt file. When I play this in PowerDVD 11 it alows me to select the sbutitle but it does not appear on the screen. The 3D video plays fine. I also tried building a blu-ray iso and that had the same problem. I am using release 2.1.8. Please can anyone help.
14th November 2013, 13:30 | #690 | Link | |
and I apologize for my ignorance |
15th November 2013, 02:18 | #691 | Link |
I am going to release next update 2.2.0 at Sunday. It will contain next improvments:
- Add support for DTS-HD elementary stream with extra DTSHD headers - Add support for mkv with 'Header Stripping' compression - Add 3D MKV support (combined AVC+MVC inside MKV) - Add PCM inside MKV support - Add PCM inside VOB support - Allow m2ts splitting for Bluray muxing - Several minor bug fixes |
15th November 2013, 02:27 | #692 | Link | ||
15th November 2013, 08:09 | #693 | Link | |
15th November 2013, 10:53 | #694 | Link | |
Life's clearer in 4K UHD
15th November 2013, 11:11 | #695 | Link | |
15th November 2013, 13:21 | #696 | Link | |
a 3D offest option dropdown with one option of "zerro". The odd thing is that powerdvd does recognise that there is a subtitle track as it alows me to select it on. |
16th November 2013, 18:32 | #698 | Link |
3D IGS (HDMV) menus?
Physic and all the experts here: Thank you very much for an awesome software and your advices.
I wanted to know how to keep the IGS menu intact in TsMuxer for 3D mpls. I own many 2D and 3D blurays which have IGS (or HDMV) menus. These have their own m2ts files. When I open these mpls files, tsMuxer ignores those m2ts files (regardless of 2D or 3D) However, for 2D mpls, once TsMuxer does its job (output as bluray), I can edit the mpls files in BDEdit and add those tracks without any issues. I tried to do this for 3D mpls, but 3D mpls also have "Extension Data" as seen in BDEdit, which I can not edit and therefore the player crashes. My intention is to keep the menus and remove unnecessary audio and subtitles. |
16th November 2013, 19:27 | #699 | Link | |
