28th March 2018, 18:07 | #561 | Link | ||
28th March 2018, 19:01 | #563 | Link |
Are there already video files that fully comply with the approved specification?
28th March 2018, 19:12 | #564 | Link |
もこたんインしたお!
Daemon404 posted that on HN as people posted the "news" article there.
I love it how this wasn't co-ordinated at all with the technical folk in AOM. The bit stream hasn't yet been frozen. It is close to it, but there are still open issues on the issue tracker, and apparently there was going to be some final check-ups from now towards the first day or days of April.
[I'm human, no debug]
29th March 2018, 09:44 | #565 | Link |
https://aomedia-review.googlesource.com/q/statuspen is this the same as the github tracker as there seems to be a lot more than 57 bugs on this one?
29th March 2018, 10:55 | #566 | Link |
Thats a code review platform, not a bug tracker. All those entries there are proposed changes going through review in some shape or form.
29th March 2018, 13:03 | #567 | Link |
http://www.streamingmedia.com/Articl...in-124134.aspx
Apparently the hope is for the encoder to be 5x and decoder 2x slower by EOY when compared to VP9. |
29th March 2018, 21:33 | #568 | Link |
Anyway ... enough reason for MABS to support libaom in ffmpeg now, in the "non-free" variant. (And Zeranoe probably soon as well? Read their notes.)
Just check if "--enable-libaom" is included in ffmpeg_options.txt if you used the option ffmpegChoice=1; I believe it is not yet added { P.S.: Now it should. }. Elseway, ffmpegChoice=4 builds the full (non-free) version. Do not distribute. Last edited by LigH; 29th March 2018 at 22:02. |
30th March 2018, 13:20 | #570 | Link | |
I would expect any film enthusiast to want to keep as close a quality to the original source as humanly possible in the lowest bit rate possible. MANY hevc files have this and only the good encoders who know what to look for seem to be smart enough to disable the film grain filter which I believe is on by default. Plenty of skin wrinkles get removed as a result of this filter. |
31st March 2018, 04:12 | #571 | Link | |
AV1 shares dna from VPx, daala, thor, will be apart of webm container together with vp9, vp8, opus and vorbis
Woah! Ninja?! http://nwgat.ninja/ (AV1 Overview) "Not available in your region" has now been redefined as "Go Pirate, you filthy scum" Nwgat Last edited by wiak; 31st March 2018 at 04:14. |
31st March 2018, 17:26 | #573 | Link |
Video compressionist
Unlike to HEVC, there is a shortage of technical papers and detailed tutorials on AV1. i could not find even a dozen papers dedicated to AV1.
i use March 2018 'aomenc' version (AOMedia Project AV1 Encoder 0.1.0-8619-ge0018b5). There is one issue not clear to me: To enable parallel encoding, it's necessary to use tiles. Apparently a sort of frame-level parallelization has not been implemented yet (i.e. when one core starts the first frame and upon completion of several MB-rows the second core starts the second frame by using already reconstructed samples of the first frame for motion estimation and so on). The corresponding code is responsible for activating multi-threading: if (AOMMIN(cpi->oxcf.max_threads, cm->tile_cols) > 1 && cm->tile_rows == 1) av1_encode_tiles_mt(cpi); else encode_tiles(cpi); So, in order to activate multi-threading you need set the following parameters: '--num-rows=0' and '--num-columns=N' and '--threads=log2(N)' Actually in order to apply the parallel encoding i have to divide frames into column-wise tiles. For example, if i use 4x4 tile grid by setting '--num-rows=2 --num-columns=2 --threads=4' then no parallel encoding is performed. What's a reason for such restriction? |
1st April 2018, 17:23 | #574 | Link | |
Angel of Night
I'm pretty loathe to lump a bunch of codecs together unless they're strongly related and all getting lots of topics. (There was a time when we had a VP3/VP6/Theora subforum.) But that's just my opinion, not necessarily D9's or the other mods'. |
2nd April 2018, 17:39 | #576 | Link |
I have a question.
Why AV1 has more relevance than VP9? VP9 is on par with H265, but on youtube doesn't offer signfiicant bitrate improvements, video bitrate is about the same as Mp4. Because it is better? For 4K videos ? Supported by many companies? |
2nd April 2018, 19:20 | #577 | Link |
Welcome.
How do you measure "more relevance"? I suppose as soon as a more efficient format is announced already with a backing by major commercial companies, interest in the predecessor formats naturally subsides. |
3rd April 2018, 00:14 | #578 | Link |
VP Eng, Kaleidescape
FFMPEG AV1 encode syntax
Now that FFMPEG officially supports AV1, has anyone gotten FFMPEG to successfully encode an AV1 bitstream? What container are you using for output? FFMPEG rejects .av1, .bin, .webm and .mp4. It seems to run (SLOWLY) if you use .mkv or .ts
FFMPEG -f rawvideo -vcodec rawvideo -pix_fmt yuv420p -s 1920x1080 -r 60 -i Netflix_PierSeaside_1080p.yuv -c:v libaom-av1 -strict -2 Pier.mkv I can't figure out how to pass parameters. -av1-params doesn't work, nor does any other syntax (-aom-params, etc.) I can guess. If you've successfully encoded, have you been able to decode your AV1 bitstream back to YUV? Last edited by TomV; 3rd April 2018 at 01:50. |
3rd April 2018, 00:21 | #579 | Link |
Matroska is the only supported container for AV1 in ffmpeg so far. MPEG-TS will just result in an unplayable file, don't do that. AV1 will likely never fit into MPEG-TS, unless someone defines an additional wrapping with special bitstream startcodes to sync to.
Not sure about other containers, are the specs for those even finalized? For the options, it doesn't work like x264 or the likes, you can't just pass arbitrary option strings to the library to parse. Currently, the following options are available directly, plus the usual ffmpeg options for bitrate etc: -cpu-used x -auto-alt-ref x -lag-in-frames x -error-resilience {default|partitions} -crf x -static-thresh x -drop-threshold x -noise-sensitivity x
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 3rd April 2018 at 00:30. |
3rd April 2018, 01:54 | #580 | Link | |
It would make sense for FFMPEG to be able pass AV1 specific encoder parameters to libaom just like you can with -x264-params or -x265-params. |
