#32181 | Link |
Thanks for your reply - I'll take a look, but I do the same thing every time and just create a new folder, automatically called New Folder by Windows and then rip using DVDFab, so the structure within is always the same.
But I'll give it another go from scratch. Many thanks |
#32183 | Link |
Big Bit Savings Now !
Exceptionally long would be more than 259".
Or characters. Whatever seems more important under given circumstances. ;-}}
#32184 | Link |
How does BDRB determine how many frames are in a file? I just had BDRB bail because it only got 167640 frames of 179976 frames. But, there are only 167640 frames in the file. I pulled the file into VRD and it shows 167640 frames. I went to the end of the file and it is not truncated.
So, I thought I would edit the AVS file for the video. Well that didn't work. BDRB rebuilt the file. Bug? |
#32185 | Link | |
![]() Join Date: Oct 2001
jdobbs.softworks@gmail.com |
#32186 | Link |
Yep, as indicated in the posting, the frame count is less than what BDRB is told that it should be. When BDRB hits the real frame count, it fails indicating that the frame count was less than expected.
#32187 | Link |
I just used BDEdit to look at the playlist and took the length of 1:56:31.985 (6991.95 sec) and came up with 167638.9932 frames. Just one frame shy. I have no idea where BDRB came up with 179976 frames.
#32188 | Link |
Could you please post the log so I can see what it says?
#32189 | Link |
It says what I've said in the posting, but here it is:
[04/19/25] BD Rebuilder v0.62.12 [21:18:32] Source: - Input BD size: 53.31 GB - Approximate total content: [02:27:51.037] - Target BD size: 22.95 GB - Windows Version: 6.1 [7601] - Quality: High Quality (Default), 1-Pass VBR - UHD-BD source detected. - Decoding/Frame serving: NVENCC - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 - Resuming from previously started job. [21:18:39] PHASE ONE, Encoding - [21:18:39] Processing: VID_00001 (1 of 1) - [21:18:39] Reencoding video [VID_00001] - Source Video: HEVC, 3840x2160 - Rate/Length: 23.976fps, 179,976 frames - Bitrate: 20,665 Kbs - [21:18:39] Reencoding: VID_00001, Pass 1 of 1 - Error: NVENCC prematurely terminated. - Encoded: 167640, expected: 179976 [21:51:29] - Failed video encode, aborted http://vidiot.com/images/BDEDIT-BDRB-mpls.jpg Hopefully there is a clue in there. |
#32190 | Link | |
NVENC_NO_FRAMECHK=1
#32193 | Link | |
jdobbs.softworks@gmail.com Last edited by jdobbs; 21st April 2025 at 12:45. |
#32194 | Link | |
Does this mean that your website is no more? Or is it temporary as it is still listed in your signature.
#32195 | Link |
It wasn't getting enough hits to justify the cost. I'll just take it out of my signature.
#32197 | Link |
Yeah. I had mine running on my server here too. It's the fixed IP VPN costs that I was referring to. The VPN stopped working (quit forwarding ports) for the umpteenth time last week and I decided to call it quits before I had to renew it.
jdobbs.softworks@gmail.com Last edited by jdobbs; 22nd April 2025 at 00:36. |
#32198 | Link |
I have a static IP business account, that I recently updated to 1Gbps down/50 Mbps up. It is a cable connection. They have work to do before the 50 Mbps up can be increased. It is just taking them a long time. No VPN involved. True that it isn't cheap, but not as bad as I thought it was going to be. To go from 100 Mbps down to 10x faster was not 10x the price. It wasn't even double.
My Total Eclipse 2017 Photos My Nov 2019 Game of Thrones Tour My NEOWISE Comet Photos 2020 Last edited by MrVideo; 24th April 2025 at 05:09. |
#32200 | Link | |
But, it is SO quick and easy to plug in the video file and boom Clever FFMpeg which is VERY fast, also converts HEVC files to AVC files, something I KNOW BDRB can do, but I could never quite figure out how to do it properly. The AV always seemed out of sync for some reason. So, that other program is great for doing those 2 kinds of conversions. |
