Old 8th June 2010, 22:23   #7961  |  Link
MKVCrazy
HD-Fan
What do you do exactly? I need real life example.
Sometimes the videos I convert for my iPod are in way too many pieces but it's rare to get. So I have no choice but convert those many pieces into one file.
For example if an episode is 40mins long then it probably will have 1-6 pieces.
Episode.1.part1.avi
Episode.1.part2.avi
Episode.1.part3.avi
Episode.1.part4.avi
.... and so on
but all adds up only around 200 - 300MB. And there isn't just one episode in the entire series Lol.
MKVCrazy is offline   Reply With Quote
Old 8th June 2010, 23:11   #7962  |  Link
Why one episode is divided in parts???
Old 9th June 2010, 01:00   #7963  |  Link
survivant001
sample, sample ,sample .....
oups.. sorry.
here
http://tinyurl.com/24nbv8l
and here the script used (here only the part with the subs)
#Subtitles
Loadplugin("D:\DVD-tools\RipBot264v1.16.0\Tools\AviSynth plugins\VSFilter\VSFilter.dll")
video=TextSub(video,"C:\Temp\RipBot264temp\job17\3_subtitles_English.ass",-1,23.976)
#AudioSource
audio=DirectShowSource("C:\Temp\RipBot264temp\job17\2_audio_Japanese.flac",video=false)
audio=ResampleAudio(audio,48000)
survivant001 is offline   Reply With Quote
Old 9th June 2010, 01:53   #7964  |  Link
MKVCrazy
HD-Fan
I have no idea mate. That's how they're posted by the original converter :\
Old 9th June 2010, 02:02   #7965  |  Link
Struck for rule 6.
@all
Do not help further on this.
Old 9th June 2010, 02:31   #7966  |  Link
MKVCrazy
HD-Fan
Originally Posted by neuron2 View Post
Struck for rule 6.
@all
You just doomed my life man
Old 10th June 2010, 01:02   #7967  |  Link
ajua
Custom Installer Maker
ajua's Avatar
Originally Posted by pacaveli211 View Post
are you locking size to 4480?
Yes, also I have encoded two blu-rays locking to DVD9 size and I fear they might as well be a little oversized too.
Originally Posted by prettyboy85712 View Post
Personally I always lock @ 4470 just to be safe.
You are right. I will begin locking to a 5-10 mb margin to be on the safe side as well.
Applications: VistaTweaker, Launch, ServiceTweaker.
Custom installers: iTunes without QuickTime, Skype and more.
ajua is offline   Reply With Quote
Old 10th June 2010, 23:21   #7968  |  Link
stinman
I want to know the difference in ref frames,seems default is 3.I have had some movies (bluray) that have 5 sometimes 4.So the more the better,I assume? A default bluray encode will take my pc about 5.5 hrs.Does using more ref frames mean way longer encode? Also does trellis 2 be that much better? I read it makes the encode take way longer,correct? Thanks to who helps!
stinman
stinman is offline   Reply With Quote
Old 10th June 2010, 23:43   #7969  |  Link
3 is optimal. above that starts placebo. your choice. options with higher number will aways take more time. your choice.
Old 11th June 2010, 00:19   #7970  |  Link
stinman
I am going on a few that I have down loaded,they had 5 ref frames,the movie was pristine but sometimes that has to do with how well the movie was made in the first place.Bluray from disk is 4 ref frames.I have made pristine bluray encodes with your program at default and about 10gbs.
stin
Old 11th June 2010, 00:21   #7971  |  Link
asarian
Originally Posted by stinman View Post
I want to know the difference in ref frames, seems default is 3. I have had some movies (bluray) that have 5 sometimes 4.
At L4.1, 1920x1080p, the max reference frames allowed (within the Blu-Ray specification) is 4. See Reference Frames. So, it seems unlikely you ever encountered an official Blu-Ray with more than 4 reference frames (though stranger things have happened in this world).
More reference frames isn't necessarily a placebo, but generally the drawbacks outweigh the benefits; there's scenes where up to 16 reference frames could make a difference, but it's often hardly worth the extra encoding time, and would leave your output file unplayable on most hardware. Or software, for that matter. Lots of HD players out there (including TMT and KMplayer) can't even handle an increase in B-frames properly.
So, keeping your reference frames at max 4 for your 1920x108p content is probably your most optimal, overall bet.
Old 11th June 2010, 00:27   #7972  |  Link
why don't use crf20 or 18????
Old 11th June 2010, 00:41   #7973  |  Link
survivant001
@Atak_Snajpera
does the sample helped you ?
Originally Posted by survivant001 View Post
oups.. sorry.
here
#Subtitles
#AudioSource
Old 11th June 2010, 00:50   #7974  |  Link
i see no problem with your sample.
Old 11th June 2010, 02:49   #7975  |  Link
Hersha
Any news about the Muxing stalls that are happening with AVCHD encodes?
Hersha is offline   Reply With Quote
Old 11th June 2010, 03:59   #7976  |  Link
Zorro70
i am awaiting that reply also, although i realise atak is incredibly busy, infact i dont know how he has enough time to sleep lol
Zorro70 is offline   Reply With Quote
Old 11th June 2010, 05:26   #7977  |  Link
stinman
I don't know,just habit of 2 pass and wanting to control size, after using TsMuxer to mux vid and audio I see what the size was(usually 20/24Gbs movie only) I try to stay close to half the size, and it never fails me to come out with a movie that you can't tell the difference. I always do dvd's with crf20.Blurays I only do the video and mux the HD audio back in after with TsMuxer.
How would you know what size,lock the size in mb just like 2 pass?
I may try one over night,crf 20.
stin
Old 11th June 2010, 05:43   #7978  |  Link
stinman
Thanks thats very good info.I have got a few mkv's 1920/800 that had reframes-5. and trellis-2 I get this info from "properties" when watching in mpc-hc.When you have a "real" bluray loaded in mpc-hc it always says reframes-4. here is a example:
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 5 frames
Muxing mode : Container profile=Unknown@4.1
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 57mn
Bit rate : 11.8 Mbps
Width : 1 920 pixels
Height : 800 pixels
Display aspect ratio : 2.40:1
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.320
Stream size : 9.47 GiB (87%)
Writing library : x264 core 95 r1592 95aacc4
Encoding settings : cabac=1 / ref=5 /
of course it goes on,I didn't want to fill up the page,I'm sure you seen it.I've always left them at 3. Thanks for the link
stin
Old 11th June 2010, 06:07   #7979  |  Link
asarian
Thanks thats very good info. I have got a few mkv's 1920/800 that had reframes-5.
Duration                         : 1h 57mn
Height                           : 800 pixels
You're not at max 1080p resolution there (only 800 vertical), so more reference frames are allowed. If you want the precise calculation, have a look here. Your device may or may not support the use of extra reference frames beyond the formula, but should you ever desire playback on something else, you may be sorry you went too high.
Old 11th June 2010, 17:56   #7980  |  Link
thebasa
thebasa's Avatar
If I go directly from the .m2ts on disc to save myself the ripping time, am I risking errors in the video?
thebasa is offline   Reply With Quote
