5th April 2020, 13:54 | #18441 | Link | |
Grumpy Old Man.
But the best way to stop this from happening, in my opinion, would be NOT to add or mod jobs, whilst Ripbot is working. Not only is it causing the problems you're having, but adding a new job while you're encoding, takes a LONG time for it to do what it needs to do. Best to do it before or after encoding. That's my 2 cents.
5th April 2020, 20:05 | #18442 | Link | |
Seconding the no border padding as default. Is that a holdover from encoding for specific devices? |
6th April 2020, 09:29 | #18444 | Link |
GPU is only used for Decoding, not Encoding. Hint the text in your screenshot "Default Video Decoder". From what I know the benefit for using GPU to decode only apply if you have a good and fast GPU, not a cheap GT1030.
6th April 2020, 11:02 | #18445 | Link |
Grumpy Old Man.
Hey guy's,
We've got another Auto Update today'ish. Core 2020-04-04, updates also to EC & ES (v1.17.3.0), mkvtoolnix v45.0 Atak, just noticed there is a new build of Mediainfo (20.03)
Not poorly done, just doin' it my way !!! Live every day like it's your last, because one day, it will be !! (M$B) Last edited by Pauly Dunne; 6th April 2020 at 11:10. |
6th April 2020, 23:00 | #18447 | Link |
Gzz is right. IT clearly says Decoding not encoding. Hardware decoding is only usefull If you have very weak CPU. Let's say mobile 2c/4t CPU plus you also work with very demanding 4k blu-ray HEVC stream @100 Mbps. With 8c/16t do not even bother using GPU decoding.
Ps. Five servers for 8c/16t is an overkill. 2 is enough for typical 1080p resolution.
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 6th April 2020 at 23:10. |
7th April 2020, 00:10 | #18448 | Link | |
7th April 2020, 12:18 | #18449 | Link |
What's a good CQ setting for h265? I generally use 10MBps for 1080 content and feel that's a good compromise between file size and quality. I tried my first H265 file and set it at CQ 20 which resulted in a 4GB file for Infinity War. That seems REALLY low.
7th April 2020, 12:42 | #18450 | Link | |
I've also noticed that 4K sources compress a lot better than their HD counterparts. I suspect it is because of 10 bit color vs 8 bit for HD. As an example I would have a 4K source that I resize to 1080p (for streaming) and it comes out to say 1.5GB. I take the HD 1080p source and resize it to 720p (for streaming) and it would not be unusual that it would be 1.5GB or even a little larger than the 1080p 4K. |
7th April 2020, 13:21 | #18451 | Link |
Not sure if it's just me, or a coincidence, but I think I've seen a 30 percent reduction in h.265 encoding speed since the last couple of updates or so. If everything appears normal to everyone else, then its probably just me.
7th April 2020, 14:30 | #18452 | Link | |
I was just having a hard time believing that a 60+GB movie can get down to 4.5GB with 4K video, HDR, and audio without looking like crap. I did see the bitrate was only 4.5Mbps Last edited by stryker412; 7th April 2020 at 14:45. |
7th April 2020, 15:34 | #18453 | Link | |
8th April 2020, 12:40 | #18455 | Link |
Can anyone tell me why this keeps happening? I ran it twice just to make sure it wasn't a one-off issue.
https://drive.google.com/open?id=1c1...A81gj9BmdWnlCI |
8th April 2020, 14:54 | #18456 | Link | |
Is this happening using DE or single server? |
8th April 2020, 14:59 | #18457 | Link |
This is with DE (my first attempt using it). I only have it set to 2 instances though. From the previous comments, I set everything back to CPU before running this attempt. I only watched a few minutes of it but out of the first 10 minutes or so this is the only time I saw this happen. However, this is also a chapter break.
Edit: I just looked and the video does it again on the 3rd chapter then the video cuts out entirely for about 5-6 minutes (audio is fine). Edit 2: I just tried in Handbrake using the h.265 (nvenc) setting. I'm averaging around 43FPS and an encode time of just over an hour. That's a massive difference compared to using CPU. I'm not sure why in Ripbot, when I set it to GPU it doesn't seem to honor that setting. Last edited by stryker412; 8th April 2020 at 15:44. |
8th April 2020, 18:17 | #18458 | Link | |
8th April 2020, 23:07 | #18460 | Link | |
