Go Back   Doom9's Forum > Video Encoding > MPEG-4 ASP
Old 17th January 2020, 04:03   #21  |  Link
blob2500
Cartoon mode works fine only in Anime with "flat" style images, without dept...
Examples: Futurama, Simpsons
In all other cases, it should not be a good choice.
blob2500 is offline   Reply With Quote
Old 17th January 2020, 04:38   #22  |  Link
Motenai Yoda
Motenai Yoda's Avatar
and that's why it wasn't named Anime mode but Cartoon mode
powered by Google Translator
Motenai Yoda is offline   Reply With Quote
Old 20th January 2020, 18:56   #23  |  Link
Liisachan
李姗倩 Lǐ Shān Qiàn
Liisachan's Avatar
Originally Posted by Motenai Yoda View Post
Actually Cartoon mode don't work well on anime content, the same for lumi mask, vaq is better, that or no-aq.
Thanks for your opinions, that's informative. What I did was a regression test, though, not a quality test. Besides, when I say old-fashioned, I mean cell anime from like 30 years ago (1980s, 1990s), probably not what you're thinking when you hear the word "anime".
People often say some settings are better (e.g. 10-bit is better than 8-bit), but if tested in a double-blind way, sometimes (often?) they can't tell which is which Anyway the most powerful technique to make old shows look nicer, is not encoder settings, nor filter settings, but may be manual, frame-by-frame restoring/retouching to remove random dirt.
Liisachan is offline   Reply With Quote
Old 23rd January 2020, 16:32   #24  |  Link
Asmodian
It has been a while since I used Xvid but even that old anime is better with film mode, cartoon is really for Simpson's etc.
madVR options explained
Old 26th January 2020, 02:41   #25  |  Link
Liisachan
李姗倩 Lǐ Shān Qiàn
Liisachan's Avatar
@Asmodian
If you guys (encoding gurus) say so, I assume that is probably true. I still sometimes use old-fashioned xvid.avi as an internal working file for e.g. typesetting, typically a quick 1-pass, q=3. Since it's a temporary file just to check frame timing, and not related to the final format e.g. x264.mkv, I'm not trying to use the best possible settings for xvid. However, if I ever create xvid.avi, xvid.mkv, etc. as the final format, I take your advice seriously and do some blind tests. Thanks!
