#3802 | Link |
@Atlantis, you need to grab beta 2.1.7.3, it has full unicode for x265 and other fixes.
https://staxrip.readthedocs.io/intro....html#download |
#3805 | Link |
They can be created with mklink which is a cmd built-in.
https://docs.microsoft.com/de-de/win...%20hard%20link. But they are needed for all tools that don't support a custom avisynth path: ffmpeg, x264, x265, VCEEnc edit: but this will not work due to how the feature is implemented in staxrip Last edited by stax76; 21st January 2021 at 17:19. |
#3806 | Link | |
#3807 | Link | |
DId you try running staxrip as administrator, only on time, so the links are created |
#3809 | Link |
@Atlantis
Right click on it. And on Apps Manager(F9), go to x265 > Help > Online, and search. It's not new. It's been around in some other category. However, you don't have to touch it in reality in almost all cases. Last edited by JKyle; 21st January 2021 at 21:58. |
#3810 | Link |
I love those options. The best options are the options that you don't have to touch!
![]() Maybe it was better to be in another category if it is not that important. Better to keep the main, first page options simple and clean. |
#3813 | Link |
@uNderdog_101 there could be another reason why symlinks caan not be created: something is already there.
Go to the following folders inside Staxrip's tree: APPS/Encoders/ffmpeg APPS/Encoders/QSVEnc APPS/Encoders/x264 APPS/Encoders/x265 If there is any avisynth.dll in those folders (with size zero or other than zero), delete those avisynth.dll. Then retry. |
#3814 | Link | |
#3815 | Link | |
For ffmpeg, soft links are needed even if avisynth is not installed, because ffmpeg does not use default DLL loading which would search in PATH, it uses a limited DLL search for increased security. A possible solution that would remove the need for soft links altogether is described here: https://github.com/staxrip/staxrip/issues/473 2.1.7.4Beta Changelog https://github.com/staxrip/staxrip/b...r/Changelog.md Download https://staxrip.readthedocs.io/introduction.html#beta |
#3816 | Link |
Thanks @stax76, thanks for the new beta also:
2.1.7.5 Beta Changelog https://github.com/staxrip/staxrip/b...r/Changelog.md Download https://staxrip.readthedocs.io/introduction.html#beta |
#3818 | Link |
Just a simple question regarding audio issue.
I do a lot of VHS recording and all of these recordings come out like this Code:
Format : AC-3 Format/Info : Audio Coding 3 Commercial name : Dolby Digital Muxing mode : DVD-Video Duration : 1 h 8 min Bit rate mode : Constant Bit rate : 256 kb/s Channel(s) : 2 channels Channel layout : L R Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossy Delay relative to video : -288 ms Stream size : 126 MiB (3%) Service kind : Complete Main dynaudnorm=p=0.94:m=70:s=22 though it won't let me keep the 256k bitrate at the same time as using the command. Is there a way of getting Staxrip to let me keep the same audio bitrate of 256kbps and use the custom command. Ps...sorry forgot to mention it will only let me set the bitrate at 224 if I got to 256 it says it's an invalid bitrate. Last edited by lordalibaski; 26th January 2021 at 23:54. |
#3819 | Link | |
thanks
abahram |
