15th October 2022, 11:46 | #502 | Link | |
gMKVExtractGUI author
Hopefully the right click menu can help you easily select all Dutch language elements. |
29th January 2023, 13:32 | #506 | Link |
Hey guys!
Another new year, another release! Thanks to @tormento's feedback, I released a new minor version to address the issue with having spaces in output file names when a pattern placeholder is empty. As always, enjoy! Download link: https://sourceforge.net/projects/gmk....4.7z/download Changelog v2.6.4
16th February 2023, 04:23 | #510 | Link |
Add images to other image sources like https://imgur.io/ or you will waiting for approvaled by moderator forever
27th February 2023, 12:34 | #511 | Link |
Sorry for the late reply @Bigmango, unfortunately it seems that mono does not respect the DPI aware code the same way as Windows do, I cannot guarantee I will be able to fix this issue, since I need to setup a new Ubuntu box for testing.
5th March 2023, 04:26 | #512 | Link |
From version 2.6.0 to latest version, all are showing Trojan.Malware.300983.susgen infection after scanning on virustotal
https://www.virustotal.com/gui/file/...21d88c66488d39 |
10th March 2023, 07:29 | #514 | Link | |
In any case, this is an open source project, so feel free to download and build the source code yourself in case you feel uneasy with the pre-build binaries. |
17th May 2023, 22:52 | #516 | Link | |
You could try and give it a go and post your results here |
28th May 2023, 23:01 | #517 | Link | |
Thanks kindly for your advice and help! |
8th November 2023, 11:03 | #520 | Link |
ASXGui Developer
Is there any way to get this to work with the Windows Store version of mkvtoolnix? If I find the directory that the exe files are located in, it gives me access denied errors. If I modify permissions on the mkvtoolnix folder (which is a little difficult compared to usual) then it works, but then it breaks mkvtoolnix until I uninstall it and reinstall it again.
extractor, gmkvextractgui, matroska, mkv, mkv extract, mkvextract, mkvextractgui |
