Old 27th June 2017, 14:08   #3481  |  Link
Some time ago, I had issues with threading in complex functions (probably QTGMC?) and was recommended to remove avstp.dll from the auto-load directory, but that was with AviSynth 2.6 MT (SEt). Unfortunately, I do not remember the details of the circumstances, only the conclusion. Is the cooperation different under AviSynth+?
LigH is offline
Old 27th June 2017, 14:36   #3482  |  Link
Groucho2004
Since AVS+ has a different multi-threading implementation I would say yes, it's different. If it's better or worse, I don't know.
Either way, I don't think it's a good idea to mix Avisynth's multi-threading with plugins that have internal MT. It's not only less efficient because of increased scheduling overhead, it also adds unnecessary complexity.
Groucho2004 is offline
Old 27th June 2017, 14:44   #3483  |  Link
One reason why QTGMC exposes the parameter EDIThreads...
LigH is offline
Old 27th June 2017, 16:31   #3484  |  Link
MysteryX
Soul Architect
MysteryX's Avatar
I should mention that pinterf's latest mvtools2 still supports multi-threading through avstp.dll and that it is enabled by default (mt = true).
Adding avstp.dll to your plugin directory may improve things - or not.
Which function(s) exposes mt parameter?
Perhaps if avstp.dll is using internal multi-threading and was never meant to be called several times, and it is being called multiple times, then the various threads lock each other.
MysteryX is offline
Old 27th June 2017, 16:33   #3485  |  Link
Groucho2004
Originally Posted by mysteryx View Post
which function(s) exposes mt parameter?
rtfm
Old 27th June 2017, 20:54   #3486  |  Link
Groucho2004
You should really read the documentation.
Old 28th June 2017, 00:45   #3487  |  Link
MysteryX
Soul Architect
MysteryX's Avatar
Adding and loading avstp.dll really doesn't change much at all -- and if it's not loaded, then I assume it's using single-threaded mode.
MysteryX is offline
Old 28th June 2017, 06:57   #3488  |  Link
postscripter
Hello, guys. I've switched from AVS 2.6 to AVS+ and got my plugin broken. It can not even load the dll and says this:
VirtualDub Error
Avisynth open failure:
'D:/Личные папки/Projects/Ретранслятор/Osd/MyOSD.dll' cannot be used as a plugin for AviSynth.
(D:\Личные папки\Projects\Ретранслятор\Измерения\Скрипт.avs, line 29)
The plugin is C-plugin written in Delphi, and the classic AVS 2,5 - 2,6 had no problem with it.
The error I mentioned can be found on the line 534 and next on the 659. And the only check there is this:
AvisynthCPluginInit = (AvisynthCPluginInitFunc)GetProcAddress(plugin.Library, "avisynth_c_plugin_init@4");
if (AvisynthCPluginInit == NULL) return false;
In russian we say that the dog is buried somewhere here, meaning the heart of the matter, which is close enough. As close, as the symbol [@], which is the dog in russian C-dlls usually have this @4 in export table after the name of the function, but delphi does not know about such things, and so do I. Google says, it's called function decoration. This is the first time I see such notation. Could anyone explain, what is it for and what to do with it? I can just recompile my plugin, of course, but wouldn't it be better to submit an issue (or the developers are already here)? Looks like a regression.
postscripter is offline
Old 28th June 2017, 07:57   #3489  |  Link
Groucho2004
Avisynth+ does not support C/CPP 2.0 plugins.
Old 28th June 2017, 08:11   #3490  |  Link
pinterf
Yes, you are using probably the old, not supported interface.
The same part in current version looks like this:
https://github.com/pinterf/AviSynthP...nager.cpp#L942
#ifdef _WIN64
  AvisynthCPluginInitFunc AvisynthCPluginInit = (AvisynthCPluginInitFunc)GetProcAddress(plugin.Library, "avisynth_c_plugin_init");
  if (!AvisynthCPluginInit)
    AvisynthCPluginInit = (AvisynthCPluginInitFunc)GetProcAddress(plugin.Library, "_avisynth_c_plugin_init@4");
#else // _WIN32
  AvisynthCPluginInitFunc AvisynthCPluginInit = (AvisynthCPluginInitFunc)GetProcAddress(plugin.Library, "_avisynth_c_plugin_init@4");
#endif
pinterf is offline
Old 28th June 2017, 11:10   #3491  |  Link
postscripter
Absolutely no idea what 2.0 means, but I've just changed the export name and have it usable now. Magic?
Well.. yeah. By the way. About current versions. Which one is the latest? Which is the latest for those, who need MT? What happened with the original AviSynth repo, which is referred by in Wiki and on avs-plus.net? I can see the same contributors there and last activity in 2014'th... Did they lost the password?
looks like this
Looks the same for me) I see changes for 64 bit only. I reckon, you did it for Studio compiler, which introduce a big mess, adding @x for 32-bit DLLs only. But Delphi compiler does not add @x at all, unless you write it by yourself. Why don't you keep it simple, like this:
AvisynthCPluginInitFunc AvisynthCPluginInit = (AvisynthCPluginInitFunc)GetProcAddress(plugin.Library, "_avisynth_c_plugin_init");
 if (!AvisynthCPluginInit) AvisynthCPluginInit = (AvisynthCPluginInitFunc)GetProcAddress(plugin.Library, "avisynth_c_plugin_init");
  if (!AvisynthCPluginInit) AvisynthCPluginInit = (AvisynthCPluginInitFunc)GetProcAddress(plugin.Library, "_avisynth_c_plugin_init@4");
   if (!AvisynthCPluginInit) AvisynthCPluginInit = (AvisynthCPluginInitFunc)GetProcAddress(plugin.Library, "avisynth_c_plugin_init@4");
Or you can make an array of names))
Old 28th June 2017, 11:30   #3492  |  Link
Groucho2004
The Avisynth C 2.0 API was the first C implementation by Kevin Atkinson. See here.
Right now I don't have a reference table that lists the differences between the 2.0, 2.5 and 2.6 APIs but I suppose it's possible that just changing the export name might do the trick. Here's some documentation but I'm not sure how helpful this is for your Delphi plugin thingy.
Old 28th June 2017, 14:18   #3493  |  Link
Groucho2004
It works better with something "simple" such as MDegrainN().
Old 28th June 2017, 19:19   #3494  |  Link
qyot27
qyot27's Avatar
The MT branch is the most up-to-date on the upstream repo:
https://github.com/AviSynth/AviSynthPlus/commits/MT
The stuff pinterf is working on is currently being treated as an ad hoc development HEAD, there's an open pull request for it.
The reason MT hasn't been merged into the master branch has less to do with stability (to wit, you have to use builds from the MT branch if you want to use AviSynth+ with FFmpeg, since only the MT branch is synced up with AviSynth 2.6.0/2.6.1), and more to do with ultim going on hiatus every so often and wanting bugs that had existed in the MT branch to be resolved first. They mostly have*, but like I previously mentioned, hiatus. The same largely applies to pinterf's pull request, although the recent Unicode fixes broke GCC again.
*save for the problems inherent to synchronous access, as discussed at length over the last few pages of this thread.
Supported compilers are Visual Studio 2015 and higher, and GCC (experimental). I was in the middle of testing weird function decoration stuff with GCC and the C plugin back in April, but since I can only use 64-bit Wine or take a huge performance hit and run 64-bit Windows in a VM, that stalled out somewhat.
qyot27 is offline
Old 29th June 2017, 10:37   #3495  |  Link
pinterf
New release with TemporalSoften fix.
Thanks to Sharc for the report.
Download Avisynth+ r2508-MT
20170629 r2508
  - Fix TemporalSoften: threshold < 255 (bug exists probably since r1576)
pinterf is offline
Old 29th June 2017, 18:24   #3496  |  Link
Sharc
20170629 r2508
I confirm it's working now. Thank you.
Sharc is offline
Old 1st July 2017, 03:46   #3497  |  Link
mkver
Is it normal that using Levels with high-bitdepth input and enabled dithering eats incredibly much RAM? Is this a gigantic LUT?
Video = BlankClip(10000,pixel_type="YUV420P10")
Return Video.Levels(0,1.0,1023,0,1023,coring=false,dither=true)\
            /*.Levels(0,1.0,1023,0,1023,coring=false,dither=true)\
			.Levels(0,1.0,1023,0,1023,coring=false,dither=true)*/
uses 82 MB. Each Levels that I uncomment adds about 64 MB to that. This does not happen without dither or with 8bit input.
On a related note: Would it be possible to add a switch to avsmeter to disable the "Script runtime is too short for meaningful measurements" error? I needed to increase the framecount of the blankclip
mkver is offline
Old 1st July 2017, 07:23   #3498  |  Link
MysteryX
Soul Architect
MysteryX's Avatar
That's the reason LUT is disabled for 14-16 bit clips and it is using runtime evaluation.
MysteryX is offline
Old 1st July 2017, 09:44   #3499  |  Link
mkver
Are you sure about this? avsmeter reports exactly the same memory usage for 10, 12, 14 and 16 bits. And strangely: It doesn't matter if it is a greyscale format or what chroma subsampling it uses, the difference is negligible. I always thought that Levels treats Luma and Chroma differently (i.e. knows that luma should be scaled normally, but that chroma should be scaled from 128 so that one should need two LUTs for them).
mkver is offline
Old 1st July 2017, 19:29   #3500  |  Link
MysteryX
Soul Architect
MysteryX's Avatar
Take a look at release notes of v2.2.2 and play with realtime argument.
When realtime is enabled is well documented here
MysteryX is offline
