Old 20th July 2019, 19:01   #6461  |  Link
Klaus1189
How are you opening videos? There are several ways to do that.
Old 20th July 2019, 19:28   #6462  |  Link
botcherO
Doubleclick in explorer.
botcherO is offline   Reply With Quote
Old 21st July 2019, 11:52   #6463  |  Link
Klaus1189
Seems to be working for me, because the new video is in focus when the new file double clicked.
Old 23rd July 2019, 17:44   #6464  |  Link
botcherO
How much videos did you try while leaving the window open?
It seems to work on the second, but not with the third video and on.
I'm on 1809 x64 if that matters.
Old 23rd July 2019, 18:51   #6465  |  Link
Klaus1189
I am on 1903 and tried more than 10 videos and it is working fine here.
Old 23rd July 2019, 23:46   #6466  |  Link
stax76
stax76's Avatar
Originally Posted by botcherO View Post
Hello everyone! I switched from mpc-hc to mpc-be (1.5.3) recently and there is one single thing i couldn't find out.
If a video is already playing and i doubleclick another vid, the player stays behind and does not go to foreground after loading the new file. Where is the option for that?
What i don't want is "stay on top while playing", just one "initial set to foreground" like mpc and mpc-hc did.
It seems to work for one time after starting fresh, but if i start the third video it stays behind windows.
No problem here with mpc-be and Win 10 1903, works fine here.
(in my code I'm calling this: AllowSetForegroundWindow)
edit:
I think this type of issue is typical for malware, antimalware and certain kind of system apps.
Old 28th July 2019, 10:49   #6467  |  Link
botcherO
So better check it with 1809 then.
Also the system is clean.
Please specify if there are known issues with thirdparty software, thank you.
Old 28th July 2019, 15:10   #6468  |  Link
jespermart
Feature request
Add the possibility to launch a program or bat file when mpc-be starts and stops
jespermart is offline   Reply With Quote
Old 28th July 2019, 16:07   #6469  |  Link
chros
chros's Avatar
Originally Posted by jespermart View Post
Feature request
I thought about that too: I want to switch off the TV before the PC goes to sleep, triggered by MPC-BE.
But since I use madvr,. I'm not sure what kind of issues it would raise, so that's why I haven't asked for it.
Ryzen 5 2600,Asus Prime b450-Plus,16GB,MSI GTX 1060 Gaming X 6GB(v385.28),Win10 LTSB 1607,MPC-BEx64+LAV+MadVR,Yamaha RX-A870,LG OLED65B8(2160p@23/24/25/29/30/50/59/60Hz)
Old 29th July 2019, 00:06   #6470  |  Link
Anima123
Sometimes I got warbled sound from MPC-BE's MPC Audio Renderer just during playing back a video, pause and play will not get the normal sound back. I was suspecting the float output format, but after untick it, the issue still there.
Anima123 is offline   Reply With Quote
Old 29th July 2019, 05:37   #6471  |  Link
You using nightly? I've yet to encounter any issues with it.
Old 29th July 2019, 09:17   #6472  |  Link
Anima123
You using nightly? I've yet to encounter any issues it it.
Yes. Hope the issue will be fixed in the near future. I would say it was not that common, perhaps harder for the developer to figure out the culprit.
Old 29th July 2019, 10:45   #6473  |  Link
Aleksoid1978
Aleksoid1978's Avatar
I always use MPC Audio Renderer and it's always perfect playback, no any issue.
I7 2600K@4.2 /Asrock P67 Extreme4 Gen 3 /Kingston HyperX 8Gb 1866 (4x2) Kit /OCZ Vertex 3 256Gb /Gigabyte GTX 960 /BenQ EW2430 /LG 47LM620T /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215
Aleksoid1978 is online now   Reply With Quote
Old 29th July 2019, 10:46   #6474  |  Link
Aleksoid1978
Feature request
Not planned, sorry.
Old 29th July 2019, 13:43   #6475  |  Link
v0lt
@huhn
MPCVideoRenderer-v0.2.1.773+ supports chroma sample location.
Old 29th July 2019, 14:09   #6476  |  Link
chros
chros's Avatar
It just popped in my mind, at least for me, probably I could use standard Windows events to fire up a script: e.g. when the computer goes to sleep it can try to switch the TV off. That should work, in theory
Old 29th July 2019, 14:13   #6477  |  Link
nice. adding support for more subtitle renderer would make this a perfect default renderer.
if you add support for 16/32 bit texture format you should think about adding dithering. i know the build from JanWillem32 had it maybe it can be ported:
https://forum.doom9.org/showthread.php?t=161047
16 bit should be enough so it could be tested with dx9.
there is a small thing in the OSD which is most likely irrelevant.
if an PNG is loaded with lavfilter the OSD reports inf as the frame rate but lavfilter is supposed to create a 25 HZ file: https://abload.de/img/mpcvrosdyuk4z.png
Old 29th July 2019, 15:16   #6478  |  Link
v0lt
I think this is a LAV Source Filter problem. MPC-HC EVR-CP has a more serious problem with it. MPC VR works correctly and shows in statistics what it gets.
Generate Still Video for JPEG works more correctly.
Old 30th July 2019, 08:55   #6479  |  Link
Aleksoid1978
What you mean "more subtitle" ?
Old 30th July 2019, 10:44   #6480  |  Link
with mpc.hc internal, xy subfilter and assfilter mod doesn't work/connect with it i guess proper support is needed first.
xy subfilter does this on MPB-BE: https://abload.de/img/subtitleissuek9kmc.png
