Old 29th December 2013, 05:25   #1801  |  Link
Aleksoid1978
Aleksoid1978's Avatar
Originally Posted by arrgh View Post
MPC is not anymore able do transcode an AAC 5.1 audio stream (e.g. from a mkv) to an AC3 and stream it to a SPDIF...it even hangs or gives only stereo or no sound at all, depending on the details of the setup (Win7x86; MPC with internal filters)...tried MPC Audio Renderer, Direct Sound,...
I think i know what happened. Fix at morning
Old 29th December 2013, 20:32   #1802  |  Link
alexins
MPC-BE DEV
alexins's Avatar
MPC-BE 1.3.1.0.4155 Dev.:
MPC-BE 1.3.1.0.4155 Dev (sourceforge.net)
MPC-BE 1.3.1.0.4155 Dev (dev.mpc-next.ru)
MPC-BE 1.3.1.0.4155 for D-BOX Dev (dev.mpc-next.ru)
Win11 x64, i7 8700K 5Ghz, ASUS MAXIMUS X HERO, G.Skill (2x8GB) Trident Z F4-3600C16D-16GTZ, RX 5700,TV Philips 43PUS6703/12, Zappiti 4K HDR
Media Player Classic - BE x86/x64. Team of developers.
alexins is offline   Reply With Quote
Old 30th December 2013, 13:49   #1803  |  Link
arrgh
MPC-BE 1.3.1.0.4155
AAC transcode works again, thanks!
arrgh is offline   Reply With Quote
Old 30th December 2013, 20:13   #1804  |  Link
Lord Maius
Hi! I would like to know if it is possible to remove "Play with MPC-BE & Add to MPC-BE Playlist" voices from Windows Context Menu.
Happy 2014!
Lord Maius is offline   Reply With Quote
Old 30th December 2013, 20:40   #1805  |  Link
z_mashine
z_mashine's Avatar
Happy 2014!
uncheck this:
z_mashine is offline   Reply With Quote
Old 30th December 2013, 20:51   #1806  |  Link
Lord Maius
Updated italian translation (rev.4122)
https://www.dropbox.com/s/sngpvhqkzs...yerc.it.rc.txt
Happy 2014
Old 30th December 2013, 20:53   #1807  |  Link
Lord Maius
Originally Posted by z_mashine View Post
uncheck this:
Done but it doesn't work.
Thank you for your help
Old 30th December 2013, 21:01   #1808  |  Link
alexins
MPC-BE DEV
alexins's Avatar
MPC-BE 1.3.1.0.4161 Dev.:
MPC-BE 1.3.1.0.4161 Dev (sourceforge.net)
MPC-BE 1.3.1.0.4161 Dev (dev.mpc-next.ru)
MPC-BE 1.3.1.0.4161 for D-BOX Dev (dev.mpc-next.ru)
Old 31st December 2013, 09:51   #1809  |  Link
z_mashine
z_mashine's Avatar
reinstall mpc-be with settings reset and unchecked shellext. or try "regsvr32 /u mpcbeshellext.dll" from installation folder.
Old 31st December 2013, 15:47   #1810  |  Link
Lord Maius
Perfect! Thank you
Old 31st December 2013, 18:31   #1811  |  Link
alexins
MPC-BE DEV
alexins's Avatar
MPC-BE 1.3.1.0.4166 Dev.:
MPC-BE 1.3.1.0.4166 Dev (sourceforge.net)
MPC-BE 1.3.1.0.4166 Dev (dev.mpc-next.ru)
MPC-BE 1.3.1.0.4166 for D-BOX Dev (dev.mpc-next.ru)
Old 8th January 2014, 09:26   #1812  |  Link
suanm
why not build a Media Player Classic - BE for Android?
suanm is offline   Reply With Quote
Old 8th January 2014, 09:44   #1813  |  Link
v0lt
Stupid question. Because ATL, MFC, DirectShow, Direct3D, ...
Old 8th January 2014, 09:55   #1814  |  Link
Lord Maius
And for Windows 8/8.1 Store? Is it possible?
Old 8th January 2014, 10:57   #1815  |  Link
v0lt
We do not deal with this nonsense.
Old 8th January 2014, 13:33   #1816  |  Link
Lord Maius
Why do you call it "nonsense"? It can't technically be done or what?
Old 8th January 2014, 23:34   #1817  |  Link
They have zero desire to address this area. No point in asking I think, it would be quite the effort.
Old 9th January 2014, 18:09   #1818  |  Link
v0lt
There are two official places where you can download MPC-BE. Why another one?
Old 11th January 2014, 05:34   #1819  |  Link
iwod
How do I change the placement of .idx subtitle? I try using the options but it seems they are application to .sub or .SRT format.
iwod is offline   Reply With Quote
Old 11th January 2014, 08:25   #1820  |  Link
Aleksoid1978
Yes - placement options use only for text subtitles.
