1st March 2013, 19:04 | #16721 | Link | |
Also, have you inspected the original rips (on the same computer) to see that these problems don't exist in them? |
1st March 2013, 22:03 | #16722 | Link | |
[Edit] There's also a new X264 version posted on www.x264.nl -- you could try that one as well. Last edited by jdobbs; 1st March 2013 at 22:27. |
1st March 2013, 22:42 | #16723 | Link | |
2nd March 2013, 07:01 | #16727 | Link |
this has most likely been asked many times, but I do not know if it is a problem with img burn and anydvd or windows 8 pro x 64. when I run the inspect I get this;
- Windows Version: 6.2 [9200] - AVISYNTH Version: [2.5.8.0], Ok - HAALI Splitter: [1.9.42.1], Ok - FFDSHOW: [4422], Ok - FFDSHOW VC-1 set incorrectly: [0] - FFDSHOW MPEG2 set incorrectly: [0] - FFDSHOW AVC set to "libavcodec": Ok - AnyDVD settings check: Ok. - BD Rebuilder v0.43.0.1, Ok - X264: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok It is on a fresh install of windows 8 pro x 64 and I do not know how to fix this. I usually rip my original to the hard drive with the latest version of anydvd, and I always close my a/v and malware programs as well.when I use imgburn it comes up with read errors as it is verifying. I have tried it on my sony and asus burners and both have the same issues with imgburn and the inspect error. Any help is appreciated, thanks! ironleg1963@gmail.com |
2nd March 2013, 13:56 | #16728 | Link | |
"make sure MPEG2 decoding is enabled. Do the same using "Audio Decoder Configuration" to ensure "Uncompressed" is set to "All Supported"." and "Setup VC-1 decoding in the same way you did MPEG-2 in step one. For Vista or Windows 7 using "Video Decoder Configuration" -- select "wmv9"" I'm not sure if there is anything else you need to do on Win8, but that would be a good start. That being said, I can't see how those settings would interfere with the actual burning operation. It could be that you have a bad burner, or bad media. |
2nd March 2013, 14:37 | #16729 | Link | |
Now, this is such a weird issue I don't expect it to be solved anytime soon... so I decided to find an alternative solution: 1) Ripped English subs from the original into a .sup file using MeGUI's Stream Extractor. 2) Dropped the BDMV directory from BD-RB output with missing subs into DeanBG's very handy MultiAVCHD. 3) Added the .sup as an external subtitle and removed the original English subs. 4) Made sure transcoding was disabled and processed the lot to full BD25. Output has English subs in all episodes. Last edited by colinhunt; 2nd March 2013 at 15:27. |
2nd March 2013, 15:16 | #16730 | Link | |
3rd March 2013, 00:05 | #16731 | Link | |
4th March 2013, 00:25 | #16732 | Link | |
Here's the rebuild MOF.INF file (timing approx): Code:
[Status] LABEL=MOF VERSION=v0.43.01 (beta) SOURCE_SIZE=40202883072 SOURCE_VIDEO_SIZE=40202883072 TARGET_SIZE=25375539200 REDUCTION=.631187050803161 RESIZE_1080=0 AUDIO_TO_KEEP=eng; KEEP_HD_AUDIO=0 SUBS_TO_KEEP=eng; BACKUP_MODE=1 MOVIEONLY_TYPE=0 USE_LAVF=0 INSTANCES=1 DGDECNV=0 QUICK=0 ENCODE_STEP=0 COMPLETED=1 REBUILD_COMPLETE=1 [00001] AUDIO=100 PGS=100000 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=25375539200 RATE=20775 SPLITS=1 NSIZE=0 FLINK=0 MLINK=0 NSTART=27000000 NEND=421458885 0:05:09 "Obey me and I'll love you forever" 1:15:01 "I borrowed it" 2:08:44 "What does she call her bear" The first point was in sync, the last was noticeably delayed for the audio. It could always be a bad disc release, of course. I recently did "The Woman in Black" and it had HIDEOUS banding (hideous to me - my wife and son didn't say anything about it). According to BluRay.com the BluRay video was supposedly fantastic, but I found some other comments online saying that the Alliance version had bad banding. My disc is the Alliance. So, for what it's worth, this "Man On Fire" disc says "© 2007 FOX". |
4th March 2013, 02:10 | #16733 | Link |
The one I have has the exact same sizes etc. that yours does. Confusing... I've made a few changes since v0.43.1, but nothing that should change the audio sync, except when the source uses pulldown -- and MOF doesn't... maybe I'll step back and try it just to be sure.
4th March 2013, 17:12 | #16734 | Link |
jdobbs, remember the issue I've had with small m2ts files containing two LPCM audio tracks, one or both of which refuse to be re-encoded into AC3?
Well, dammit. I recently built a new PC for non-encoding purposes but ended up installing BD-RB on it after all. Earlier today I threw "Baron Blood" at it, fully expecting to see the Audio Reencoding issue pop up again. But no! First VID on the disc is only 6.05MB and has two LPCM audio tracks. My encoding rig (a dual-Xeon) stumbled on it immediately... but this new PC encoded the files like it was the simplest task on the planet. I suppose we can cross that bug off the list. |
4th March 2013, 17:28 | #16735 | Link |
With the good comes the bad. Another japanime title, Steinsgate, was subjected to a movie-only backup last night. Result: last of the eight episodes plays without subtitles. I went through the log and .INF files but found nothing that would have even hinted at a problem.
Ripping .sup with MeGUI's Stream Extractor and muxing it into BD-RB's output with multiAVCHD saved the day again. |
5th March 2013, 14:25 | #16736 | Link | |
7th March 2013, 03:31 | #16737 | Link |
Question about Edit mode
When in Full Backup and Edit mode the VIDs that appear are the same for when I'm not in Edit mode. The only way to see all the VIDs is to go into Movie and Menu mode with Edit mode. I have been told that Full Backup and Edit mode should allow me to see all the VIDs but that is not the case. I have ENABLE_TEST=1 in the INI file.
Edit: I originally meant to ask this as a possible bug but didn't phrase it as such, sorry. Last edited by AGKnotUser; 7th March 2013 at 11:38. |
7th March 2013, 14:43 | #16739 | Link | |
