Old 3rd October 2018, 02:21   #16181  |  Link
burt123
burt123's Avatar
It has nothing to do with 4k footage because you are still resizing to 1080p. The issue is that you are throwing too much on those poor 24 threads.
Other servers basically do not have access to spare cpu cycles to start encoding in 1 minute time limit. (hence encoding stalled message and forced restart in encoding server). Nevertheless I will disable this forced start by default in encoding server and implement command line switch so you can set your own time limit instead of current hardcoded 1 minute.
Apologies for being a bit "slow" with the info you wanted, last night (my time)
OK, today is another day, and there was an early auto update, so I have installed that on the "troublesome" pc, and everything seems to be running pretty sweet. No "list index" error's, and no time out's on the servers. (I've only got 2 running today)
So you mentioned you were going to add a command line switch to customise the time limit settings....where's that ??
edit:- forget the last sentence / question, as I have found it
So if this setting isn't applied, does that mean that there's no time out restart ??
Can you please provide an example of the command line for say a 2 minute delay ? (I'm lost with commands / dos)
Server1CommandLine=/port 1000 /minimize /priority low /node 0 /port 1000 /restart-if-no-progress 2 ??
burt123 is offline   Reply With Quote
Old 3rd October 2018, 04:28   #16182  |  Link
mdchaser
Originally Posted by burt123 View Post
Are you using Distributed Encoding ?
There is a new setting that needs to be addressed, which may fix your problem. see:-
https://forum.doom9.org/showthread.p...75#post1852975
This has actually changed a little, you'll see when you go to this setting.
And btw, if you were to start Ripbot without being connected to any network (not even the web) do you get a series of pop up error's stating something like "list index is out of bounds" ?
edit:- that error may not happen with the very latest update...
Thanks for getting back to me! I've already checked the IP setting, I have a single nic so my ip section is greyed out, I don't get the option to change it... The error implies ripbot is sending the wrong shared path to all of the clients.
mdchaser is offline   Reply With Quote
Old 3rd October 2018, 11:09   #16183  |  Link
Server1CommandLine=/port 1000 /minimize /priority low /node 0 /restart-if-no-progress 2
Correct. Server will restart encoding after two minutes of idle time.
If /restart-if-no-progress 0 or omitted then server waits endlessly.
@mdchaser
show me ipconfig /all output
Old 3rd October 2018, 11:17   #16184  |  Link
burt123
burt123's Avatar
Wow, well I can do things right, when I put my mind to it, thanks for confirming that.
And I have to say, whatever you did with the latest update overnight (my time), has worked a treat.
I had ZERO problems today, after a self imposed shocker, yesterday.
And I had it pretty busy today, and smooth as.
The "list index" error has gone...
Old 3rd October 2018, 11:19   #16185  |  Link
Nevertheless please do not run 6 servers on 12C/24T cpu next time ,ok? 1 server per 8C-12C should be enough with active mdegrain2 in 1080p.
Old 3rd October 2018, 11:44   #16186  |  Link
burt123
burt123's Avatar
Yes, I think I've learnt my lesson on that one, and MDegrain2 on 4K will be a lot more strain.
And a question, how would a single 12C compare with dual 6C's ??
At least the dual has 2 Numa Nodes (if that makes much difference)
Old 3rd October 2018, 17:56   #16187  |  Link
mdchaser
@mdchaser
Here you go!
PS C:\Users\tv> ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : Movies
Primary Dns Suffix . . . . . . . : ace.local
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
DNS Suffix Search List. . . . . . : ace.local
Ethernet adapter Ethernet 2:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Mellanox ConnectX-2 Ethernet Adapter
Physical Address. . . . . . . . . : 00-02-C9-29-34-18
DHCP Enabled. . . . . . . . . . . : No
Autoconfiguration Enabled . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::a111:2c7a:dd90:7c1f%7(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.42.6(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.42.1
DNS Servers . . . . . . . . . . . : 192.168.42.10
192.168.42.11
NetBIOS over Tcpip. . . . . . . . : Enabled
Ethernet adapter Bluetooth Network Connection 2:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : Bluetooth Device (Personal Area Network) #2
Physical Address. . . . . . . . . : 00-1A-7D-DA-71-13
DHCP Enabled. . . . . . . . . . . : Yes
PS C:\Users\tv>
Old 4th October 2018, 05:40   #16188  |  Link
tuanden0
Hi, I'm a RipBot newbie. Could someone help me a little?
1. How can I use vapoursynth through RIPBOT?
2. I have a batch script to encode x265 video and how I use it in RIPBOT:
"C:\Program Files (x86)\VapourSynth\core64\vspipe.exe" --y4m "%~dpn1.vpy" - | "%~dp0Tools\x265.exe" --y4m --preset slow --aq-mode 3 --output-depth 12 --crf %crf% -o "%~dpn1.hevc" -
Thank you!
tuanden0 is offline   Reply With Quote
Old 5th October 2018, 13:45   #16189  |  Link
Ryushin
Ryushin's Avatar
Bug - Adding Job Sometimes Never Completes and Corrupts Job
So I encountered something new sometime in the last update or two. When adding or editing a job the job window gets stuck and the only way to fix it is to close/kill the application. When this happens in an the avisynth window, and I go back into the job, the script only has one line like this:
Import("D:\Temp\RipBot264temp\job676\job676_a1.avs")
Cannot find a way to fix it, so I have to delete the job and add it again fresh. The new ability to move jobs is a huge welcome here as I can put the new job where it needs to go.
One time when clicking Done on the job window it got stuck, and I clicked Done a few times and it created additional jobs all the same job number. I had to edit the job list to clear out those bad jobs.
Old 5th October 2018, 15:16   #16190  |  Link
legend
How do I set by default audio=Amplify(audio,3.0).
All the time it needs to set manually in every file.
legend is offline   Reply With Quote
Old 7th October 2018, 06:51   #16191  |  Link
mdchaser
No luck after the most recent update, I'm still getting failures across the board when trying to encode. This is with all end points joined to a domain. Looks like ripbot is sending the wrong network path:
Any help would be appreciated, I've had to fall back to dvdfab and it's so sloooooow. This started happening after a recent update, I've gone through the ini files to make sure everything looks like it should.
Old 7th October 2018, 12:09   #16192  |  Link
HehoChef
With the newest version it stopped demuxing properly.
Can choose neither Audio nor Subtitles, but no errors.
Running Win 10 64bit and mkvtoolnix 27.
Any suggestions?
HehoChef is offline   Reply With Quote
Old 7th October 2018, 12:36   #16193  |  Link
What version does ripbot264 use by default v25 or v27?
Old 7th October 2018, 15:30   #16194  |  Link
Ryushin
Ryushin's Avatar
Here is an image that shows what happened after I clicked done on a job. I had to kill the main windows and thankfully the job was still there. It's freaking me out now editing a job as I might have to start all over. I think if it gets stuck when finishing the job it is still there. But if it get stuck at avisynth then the job is corrupted.
Old 7th October 2018, 18:59   #16195  |  Link
HehoChef
Well the one in the ripbot264 folder is still v25, and thats also whats listed under Settings --> Tools. Didn't know i comes with its one instance.
Does it bother RipBot264 that there is a second system wide installation of mkvtoolnix?
I only mentioned it in the first place since its the only thing that changed on my end since RipBot last worked...
Old 7th October 2018, 19:09   #16196  |  Link
slalom
slalom's Avatar
This was fixed about a week ago. Are you sure you are updated?
Xeon E5-2680 v2 @ 3.1GHz 16GB
Sony Vaio VPC-F13Z1E/B
Old 7th October 2018, 19:14   #16197  |  Link
byteshare
ByteShare
byteshare's Avatar
Originally Posted by stretch009 View Post
Windows 7 Ultimate. Have other x86 users successfully used the latest ripbot versions? Would like to hear from the ripbot author.
Not sure if you saw Atak_Snajpera's solution as he didn't seem to use the quote option but he posted a link to instructions to use 32bit only with the newest version:
https://forum.doom9.org/showthread.p...76#post1819776
Old 7th October 2018, 19:25   #16198  |  Link
byteshare
ByteShare
byteshare's Avatar
I forget at which update point but I had to go down from 4 servers to 2 on my Ryzen 7 2700x, and it has been much smoother sailing since the change (and all of the great updates).
Old 7th October 2018, 19:27   #16199  |  Link
byteshare
ByteShare
byteshare's Avatar
Thank you!
As far as I know you'll need to use AviSynth+ and not VapourSynth, or use a different application that supports VapourSynth
Old 7th October 2018, 19:30   #16200  |  Link
byteshare
ByteShare
byteshare's Avatar
No option right now, but after you load the jobs you can change the setting with a batch operation with NotePad++ by loading the .avs files with audio instructions. Personally I use a secondary program to handle the audio and then use a batch mux script to put the subs, audio, and video all together at the end.
