14th October 2018, 08:15 | #16221 | Link | |
How can i deinterlace the whole file? thanks. link 50M file https://filehost.net/0ff31d2124b713d5 |
14th October 2018, 09:01 | #16222 | Link |
Hmm, that seems above my skill unless it's dummy proof. Where di U put that code? Do i just copy exactly how it is and paste? Do I need to add anything to that code? I may go old school and demux, MeGUI to create avs and use Vdub to encode...
15th October 2018, 09:52 | #16224 | Link |
Just an observation of strange behavior since the very latest update (a few days ago)
After I have loaded some jobs into the queue, and I press "Start", it goes thru it's procedure, but when it gets to starting the encode, it just pauses at a queued status... The only way I have found to rectify this, is to close out of Ripbot, re start it, and press "Start" again. This has happened on 2 pc's, so far. W7 & W10. |
15th October 2018, 16:09 | #16225 | Link | |
ByteShare
15th October 2018, 20:29 | #16226 | Link | |
It wont let me select deinterlace (its disabled), but there is lines when in motion. not sure if I need to use change speed to 23.x if that would take it down and remove them or what. I think its hard telecined. Thanks |
16th October 2018, 00:58 | #16227 | Link | |
ByteShare
Loadplugin("C:\RipBot\Tools\AviSynth plugins\RgTools\RgTools.dll") Loadplugin("C:\RipBot\Tools\AviSynth plugins\nnedi3\nnedi3.dll") Loadplugin("C:\RipBot\Tools\AviSynth plugins\masktools\masktools2.dll") Loadplugin("C:\RipBot\Tools\AviSynth plugins\mvtools\mvtools2.dll") LoadCplugin("C:\RipBot\Tools\AviSynth plugins\Yadif\Yadif.dll") Import("C:\RipBot\Tools\AviSynth plugins\Scripts\QTGMC.avs") video=QTGMC(video,Preset="Medium",FPSDivisor=2) |
16th October 2018, 11:31 | #16228 | Link | |
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 16th October 2018 at 11:36. |
16th October 2018, 13:10 | #16229 | Link | |
I played it on my LG 4K TV, and it played rather well, especially knowing how old this would be. No interlacing, just probably needs an MDegrain2 encode. see for yourself:- https://www.mediafire.com/file/26c7y...9-001.mkv/file Last edited by burt123; 16th October 2018 at 13:28. |
19th October 2018, 16:14 | #16230 | Link |
Distributed Encoding hangs at last frame
Every so often, I have a distributed encoder that hangs on completing the very last frame. It will be stuck at 99%. If I manually turn off the encoder and turn it back on, that chunk will complete with no issues. I have not been able to identify why this happens, it always seems to be random. I use 3 different pc's with DE and it is random across all 3 machines.
Any workarounds to monitor if a distributed encoder gets hung up and automatically restart it? |
19th October 2018, 17:44 | #16231 | Link |
Are you using latest version 1.23.1? (core 2018.10.3)
20th October 2018, 04:18 | #16233 | Link |
Evening, I've got a strange problem that has just cropped up. My encodes all fail with this error written to video.mkv.Error.txt. Any thoughts?
D:\>"C:\Users\tv\OneDrive\Tools\Ripbot264\EncodingClient.exe" "D:\Temp\RipBot264temp\job1\job1_EncodingClient.meta" D:\>"C:\Users\tv\OneDrive\Tools\Ripbot264\tools\mkvtoolnix\mkvmerge.exe" -o "D:\DVD\The Crazies (2010) 1080p x265-2 8 66.mkv" --compression 0:none --title "The Crazies (2010) 1080p x265-2 8 66" --default-duration 0:24000/1001fps "D:\Temp\RipBot264temp\video.265" --compression 0:none --language 0:eng "D:\Temp\RipBot264temp\job1\Encoded_Audio_1.ac3" --chapters "D:\Temp\RipBot264temp\job1\chapters.txt" mkvmerge v25.0.0 ('Prog Noir') 64-bit Error: The file 'D:\Temp\RipBot264temp\job1\Encoded_Audio_1.ac3' could not be opened for reading: open file error. ------------------------- Elapsed Time: 00h:27m:41s Looking at the folder structure Encoded_Audio_1.ac3 doesn't exist so that would explain the error. The question is why isn't it being created? Thanks! Last edited by mdchaser; 20th October 2018 at 05:25. Reason: World domination |
20th October 2018, 06:09 | #16234 | Link | |
see post #16181, specifically the green text sentence. https://forum.doom9.org/showthread.p...32#post1853732 |
20th October 2018, 12:35 | #16235 | Link | |
20th October 2018, 12:39 | #16236 | Link | |
20th October 2018, 18:26 | #16239 | Link | ||
Recent private message Quote:
20th October 2018, 19:55 | #16240 | Link | |
I think the issue is with the fact that they are variable frame rate and listed as 28.x I got it sorted manual tho thanks to byteshare. |
