25th November 2012, 09:47 | #13121 | Link | ||
Considering the HW decoder doesn't work with this sample on your system, it would fallback to software, and that mode also works just fine for me.
25th November 2012, 18:05 | #13124 | Link | |
@nevcairiel Could you consider adding a workaround to enable Yadif for this combo? DVD + WinXP + wmplayer.exe
MPC-HC 2.2.1 |
25th November 2012, 20:51 | #13130 | Link | |
Using DXVA is not recommended, because Intels HW implementation is somewhat different (and Intel doesn't actually say different how), this is especially true for files with a high number of reference frames (like this one).
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 25th November 2012 at 21:00. |
26th November 2012, 07:45 | #13131 | Link |
AV heretic
Yep, I also would love to get DXVA1 support in LAV video. I have win7 setup but just can't move all my staff from XP to 7, so often even watch video in XP with working processes in background. Now I have to switch to Cyberlink for heavy video.
26th November 2012, 08:25 | #13132 | Link |
Not going to happen.
Thats even one of those things i wouldn't even accept a patch for, because i simply have no ability to test it and ensure it keeps working (not like i have ever received a patch thats more then 2 lines or so.)
26th November 2012, 10:09 | #13134 | Link |
Why would you want to do that?
If you want to bitstream and your receiver doesn't do TrueHD just check "Dolby Digital (AC-3)" under bitstreaming in LAV Audio. You could also try to deactivate "TrueHD" in the formats tab. |
26th November 2012, 10:54 | #13138 | Link | |
So any TrueHD track output by LAV is pure TrueHD (at least when its from a mpeg-ts file), no AC3 frames in it anymore. LAV has an option if those "substreams" should be shown as a separate track, or simply discarded. And no, there is no way to auto-select the AC3 track. Higher Quality Streams are always preferred.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 26th November 2012 at 11:03. |
26th November 2012, 11:04 | #13139 | Link |
Thx for the explanation. Had to dig out a sample file to actually test it myself because I didn't have any ready. Maybe LAV Splitter could be changed to only select tracks which can be decoded? (So one would have to disable all TrueHD decoders prior and would then select the core instead of the lossless part) Or disable the lossless part in the splitter.
The request itself seems reasonable. |
26th November 2012, 11:06 | #13140 | Link | |
I have no plans to add options for codec-based selection logic, it would just add a lot of confusion.
