Old 10th June 2018, 01:04   #4101  |  Link
poisondeathray
Here is a similar test on a 0-255, Y,U,V pattern (0-255 Y just copied to the U,V planes), and again 8x back and forth, and then to TV range
You end up with Y 16-235 , U,V 16-240 hard limits (so chroma=100 for smooth levels is probably correct value for typical usage scenarios), but the average is skewed with coloryuv , resulting in the colorization of greyscale values. Also see the line artifacts again with coloryuv (smoothlevels had dither disabled)
poisondeathray is offline
Old 10th June 2018, 06:59   #4102  |  Link
pinterf
I have noticed and commented a line in color.cpp, this is the final step in lut creation, so far calculation was done in double precision:
// Convert back to int
int iValue = int(value); // hmm P.F. 20180226 no rounding?
pinterf is offline
Old 10th June 2018, 19:53   #4103  |  Link
`Orum
Ah, that might be it. Do you have a test build with rounding? Otherwise I'll probably monkey with it and build one myself.
My filters: DupStep | PointSize
`Orum is offline
Old 11th June 2018, 06:35   #4104  |  Link
pinterf
I'll build one then
pinterf is offline
Old 11th June 2018, 09:34   #4105  |  Link
pinterf
EDIT:
Limiter dont work as required, mod to Levels
Are you sure?
pinterf is offline
Old 11th June 2018, 10:55   #4106  |  Link
pinterf
Avisynth+ r2710 test build: installer w/o C++ redistributables.
https://drive.google.com/open?id=1tM...W4v99uCUtwwemj
New things since last test:
- Fix: ColorYUV: round to avoid green cast on consecutive TV<>PC
- Enhanced: Limiter to work with 32 bit float clips. 'show' option still not supported
- Enhanced: Limiter new parameter bool 'autoscale' default false.
  If set, minimum/maximum luma/chroma values are treated as they were in 8 bit range (but non-integer values are allowed), limiter will autoscale it.
  Default: does not scale at all, parameters are used as-is. Parameters now are of float type to handle 32 bit float values.
- New: function bool VarExists(String variable_name)
  Checks if a variable exists
  Returns true if variable exists, false otherwise
pinterf is offline
Old 11th June 2018, 12:01   #4107  |  Link
So AviSynth+ "VarExists" is comparable to PHP "isset"?
LigH is offline
Old 11th June 2018, 14:28   #4108  |  Link
wonkey_monkey
Formerly davidh*****
wonkey_monkey's Avatar
Hopefully it doesn't return "false" when the variable exists but is null, which is what isset does...
wonkey_monkey is offline
Old 11th June 2018, 14:32   #4109  |  Link
I believe AviSynth has no "null" value/type.
LigH is offline
Old 11th June 2018, 15:00   #4110  |  Link
pinterf
They can hold an 'undefined' value. But in this case the variable still exists and the function returns true.
pinterf is offline
Old 11th June 2018, 15:08   #4111  |  Link
StainlessS
StainlessS's Avatar
BlankClip
#Fred=Undefined                     # Uncomment to show True
Ex=RT_VarExist("FRED")      # Edit or r2710 VarExists
Subtitle("VarExist for fred="+String(ex))
False unless assigned Undefined [EDIT: or some variable type]
Will show true in Script function where Fred is an un-supplied optional arg, ie UnDefined. (exists but not defined as anything in particular)
I sometimes post sober.
StainlessS is offline
Old 11th June 2018, 15:17   #4112  |  Link
StainlessS
StainlessS's Avatar
Are you sure?
Went all the way back to v2.57 and could not get Limiter to fail as posted, sorry, I have not explanation, other than senility.
Old 11th June 2018, 15:30   #4113  |  Link
StainlessS
StainlessS's Avatar
@P,
Note, the builtin file existing function is named Exist(), ie no ending 's', so I used RT_VarExist() and RT_FunctionExist() both without ending 's',
(I initially did RT_VarExists with ending s and changed to be compatible style with builtin Exist).
EDIT: I see that you have already implemented FunctionExists() with trailing 's', maybe too late to change
Function Fred() {return True}
BlankClip
Ex=FunctionExists("FRED")
Subtitle("FunctionExists for fred="+String(ex))
EDIT: To below,
... because of senility
Yeh, sometimes I miss out the odd 's', and sometime I add way too many, hence the usernamesssss.
Old 11th June 2018, 15:33   #4114  |  Link
pinterf
Good advice, thanks, unless 's' is missing from there because of senility
pinterf is offline
Old 11th June 2018, 16:45   #4115  |  Link
pinterf
Ok, VarExist name is fixed and 'show' is supported in 32bit float, here is r2713
Avisynth+ r2713 test build: installer w/o C++ redistributables.
EDIT: link refreshed (I have messed up the 32/64 bit files)
https://drive.google.com/open?id=1GC...wz-7LIerlDQYLn
New things for today:
- New: function bool VarExist(String variable_name)
  Returns true if variable exists even if it holds 'Undefined', false otherwise
pinterf is offline
Old 11th June 2018, 17:12   #4116  |  Link
StainlessS
StainlessS's Avatar
P, so you decied to keep FunctionExists with the extra 's', no sweat either way
Sorry, but latest ver$, have included 64 bit dll's in 32 bit install.
EDIT: And just to mitigate doubts about senility,
EDIT: Above after total uninstall, reinstall. [WinXP32]
EDIT: Not just that dll, looks like maybe all of them.
EDIT: Double check on senility [better to be sure]
C:\Documents and Settings\root>avsmeter -avsinfo
AVSMeter 2.7.7 (x86) - Copyright (c) 2012-2018, Groucho2004
Cannot load a 64 bit DLL in 32 bit Avisynth: 'C:/Program Files/AviSynth+/plugins+/ConvertStacked.dll'.
Old 11th June 2018, 18:12   #4117  |  Link
pinterf
Senility contest: I won.
I'll upload a proper version tomorrow, until then the ColorYUV rounding issue fix can be investigated in r2710, some posts before.
pinterf is offline
Old 12th June 2018, 09:20   #4118  |  Link
pinterf
r2713 reuploaded
pinterf is offline
Old 12th June 2018, 09:47   #4119  |  Link
StainlessS
StainlessS's Avatar
Installed, everything hunky dory here thanx
Old 12th June 2018, 15:43   #4120  |  Link
`Orum
r2713's ColorYUV(levels="TV->PC") still looks different from MPC-HC's conversion (MPC-HC's caucasian skin-tone colors become redder post-conversion than AviSynth+'s), but at least it no longer seems to have the green cast any more, and repeated conversions back and forth (in AviSynth+) work fine now. So, the difference may be that MPC-HC is doing it incorrectly, I'm not really sure and don't have the time to dig through their code right now. As far as I'm concerned, the issue is resolved for AviSynth+, unless someone can demonstrate otherwise.
Thanks!
Edit: I'm starting to suspect the difference now really is related to a conversion error in MPC-HC, as other colors, like orange/yellow, appear to be oversaturated after conversion.
`Orum is offline
