Old 8th October 2018, 21:46   #3181  |  Link
minda76
Originally Posted by videoh View Post
What does this mean? You load the Avisynth script, the DGI file, or the actual source file?
I load dgi file and when encode starts not all hdr10 parameters are imported from dgi file like “mastering display”.
minda76 is offline   Reply With Quote
Old 8th October 2018, 21:56   #3182  |  Link
videoh
Useful n00b
From what you posted at DG's forum it sounds like MediaInfo has a problem. First check that the info is in fact in the DGI file. Then use MediaInfo directly (not through StaxRip) on the DGI file and see if it reports the info.
Old 8th October 2018, 22:24   #3183  |  Link
minda76
Info is in dgi file, checked, info is in source file, don’t know how to check dgi file with media info. “Mastering display” is not present in the encoded file.
Old 9th October 2018, 02:36   #3184  |  Link
videoh
Useful n00b
OK, then you will need to get help from the StaxRip guys.
Old 10th October 2018, 13:05   #3185  |  Link
DaMacFunkin
Does anybody have a guide on how to set up staxrip to re-encode 2160p 10 bit HDR-10 to 2160p 10 bit HDR-10 using Nvenc?
Thank you for any help given.
DaMacFunkin is offline   Reply With Quote
Old 10th October 2018, 22:03   #3186  |  Link
Revan654
Revan654's Avatar
Originally Posted by minda76 View Post
Hello,
I’m using dgdecnv with staxrip and after latest update when i load indexed file and start encode not all hdr10 info appear like “mastering display” etc. Is it related to vui import? Mediainfo?
VUI will only import Rec 2020.
Like I said in the doc. VUI will only load if the colorspace is BT.2020. Anything else gets rejected. There just to many colorspaces to build functions for ever one, Even though HDR10 docs clearly states only Rec.2020 is HDR. For some reason some studios don't fully convert to proper colorspace and leave it in P3(Which is a giant mistake). It also didn't help that MediaInfo keeps simplifying there readout. I tried to get the old readout back a few times before main dev didn't want to go back to that setup. That is the reason why allot of VUI data does not import correctly.
Apps -> MediaInfo. It Will give you the readout of what has been imported or what will be imported.
You can also use MKVinfo for more detail readout if the file is mkv.
VUI Import is just a copy function for the Metadata to Codec, to make things easier. All the metadata still loads into StaxRip, it's just doesn't copy colorspaces & other data over if it doesn't pass all the checks.
Revan654 is offline   Reply With Quote
Old 12th October 2018, 14:17   #3187  |  Link
FreaQ
Starfish
FreaQ's Avatar
Originally Posted by Digga View Post
hi there Revan654!
I tried the new 1.9 version (didn't import any settings and started fresh).
however, the resulting output is played in slow motion (exactly half of the normal playback speed).
I checked the output with VLC and MPC-HC (newest versions), as well on my TV. I feel a little uncomfortable here, maybe I overlooked something? I used the same settings that worked for me for ages, so I guess it might be someting in the new version that is causing this...
Encoding from the same source with StaxRip v1.7.0.5 results in a perfectly fine encode. Btw, checking the raw video output before muxing shows the same slow motion effect.
If I can provide any further information I will gladly do so.
I tried to copy n paste a shortened log here, but the system tells me it is much too long. so I attached it.
*edit: while pending approval, here's the log: https://www31.zippyshare.com/v/134yRkBm/file.html
thanks for your time!
Today I encountered the same problem.
I was reencoding a HDTV capture which resulted in a slow downed video. Audio is playing at the correct speed. Also the target and source video play at the same frame rate and have the same duration.
I reencoded the source video in StaxRip 1.7.0.6 and everything is fine.
Find attached logs from both versions in following posts
FreaQ is offline   Reply With Quote
Old 12th October 2018, 14:18   #3188  |  Link
FreaQ
Starfish
FreaQ's Avatar
1.9.0.0 1/2
-------------------------- System Environment --------------------------
StaxRip    : 1.9.0.0
Windows    : Windows 10 Home 1803
Language   : German (Germany)
CPU        : Intel(R) Core(TM) i7-6700HQ CPU @ 2.60GHz
GPU        : Intel(R) HD Graphics 530, NVIDIA GeForce GTX 950M
Memory     : 1 GB
Resolution : 1920 x 1080
DPI        : 96
------------------------ MediaInfo Source File ------------------------
D:\Video\Miraculous - Geschichten von Ladybug und Cat Noir - S02E03 - Prime Queen.ts
General
Complete name            : D:\Video\Miraculous - Geschichten von Ladybug und Cat Noir - S02E03 - Prime Queen.ts
Format                   : MPEG-TS
File size                : 862 MiB
Duration                 : 21 min 8 s
Overall bit rate mode    : Variable
Overall bit rate         : 5 701 kb/s
Video
Menu ID                  : 5500 (0x157C)
Format                   : AVC
Format/Info              : Advanced Video Codec
Format profile           : High@L4
Format settings          : CABAC / 4 Ref Frames
Format, CABAC            : Yes
Format, ReFrames         : 4 frames
Codec ID                 : 27
Duration                 : 21 min 7 s
Bit rate                 : 5 032 kb/s
Width                    : 1 440 pixels
Height                   : 1 080 pixels
Display aspect ratio     : 16:9
Frame rate               : 25.000 FPS
Standard                 : Component
Color space              : YUV
Chroma subsampling       : 4:2:0
Bit depth                : 8 bits
Scan type                : Interlaced
Scan type, store method  : Separated fields
Scan order               : Top Field First
Bits/(Pixel*Frame)       : 0.129
Stream size              : 761 MiB (88%)
Color range              : Limited
Color primaries          : BT.709
Transfer characteristics : BT.709
Matrix coefficients      : BT.709
Audio
Format                   : AC-3
Format/Info              : Audio Coding 3
Codec ID                 : 6
Bit rate mode            : Constant
Bit rate                 : 384 kb/s
Channel(s)               : 6 channels
Channel positions        : Front: L C R, Side: L R, LFE
Sampling rate            : 48.0 kHz
Frame rate               : 31.250 FPS (1536 SPF)
Bit depth                : 16 bits
Compression mode         : Lossy
Delay relative to video  : 8 ms
Stream size              : 58.0 MiB (7%)
Language                 : German
Language, more info      : Clean effects
Service kind             : Complete Main
------------- ffmpeg: Re-mux TS to MKV using ffmpeg 4.0.2 -------------
"D:\_Programme\_Portable\Staxrip 1.9.0.0\Apps\ffmpeg\ffmpeg.exe" -i "D:\Video\Miraculous - Geschichten von Ladybug und Cat Noir - S02E03 - Prime Queen.ts" -c:a copy -c:v copy -sn -y -hide_banner "D:\Video\Miraculous - Geschichten von Ladybug und Cat Noir - S02E03 - Prime Queen_temp\Miraculous - Geschichten von Ladybug und Cat Noir - S02E03 - Prime Queen.mkv"
[h264 @ 000001bfd9a62100] mmco: unref short failure
Last message repeated 2 times
[h264 @ 000001bfd9a62100] Increasing reorder buffer to 2
Input #0, mpegts, from 'D:\Video\Miraculous - Geschichten von Ladybug und Cat Noir - S02E03 - Prime Queen.ts':
Duration: 00:21:07.88, start: 86541.948111, bitrate: 5703 kb/s
Program 5500
Stream #0:0[0xff]: Video: h264 (High) ([27][0][0][0] / 0x001B), yuv420p(tv, bt709, top first), 1440x1080 [SAR 4:3 DAR 16:9], 25 fps, 50 tbr, 90k tbn, 50 tbc
Stream #0:1[0x103](deu): Audio: ac3 ([6][0][0][0] / 0x0006), 48000 Hz, 5.1(side), fltp, 384 kb/s (clean effects)
Output #0, matroska, to 'D:\Video\Miraculous - Geschichten von Ladybug und Cat Noir - S02E03 - Prime Queen_temp\Miraculous - Geschichten von Ladybug und Cat Noir - S02E03 - Prime Queen.mkv':
Metadata:
encoder         : Lavf58.12.100
Stream #0:0: Video: h264 (High) (H264 / 0x34363248), yuv420p(tv, bt709, top first), 1440x1080 [SAR 4:3 DAR 16:9], q=2-31, 25 fps, 50 tbr, 1k tbn, 90k tbc
Stream #0:1(deu): Audio: ac3 ([0] [0][0] / 0x2000), 48000 Hz, 5.1(side), fltp, 384 kb/s (clean effects)
Stream mapping:
Stream #0:0 -> #0:0 (copy)
Stream #0:1 -> #0:1 (copy)
Press [q] to stop, [?] for help
video:796842kB audio:59438kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.090459%
Start:    13:48:47
End:      13:48:53
Duration: 00:00:05
------------------ Demux MKV using mkvextract 26.0.0 ------------------
"D:\_Programme\_Portable\Staxrip 1.9.0.0\Apps\MKVToolNix\mkvextract.exe" "D:\Video\Miraculous - Geschichten von Ladybug und Cat Noir - S02E03 - Prime Queen_temp\Miraculous - Geschichten von Ladybug und Cat Noir - S02E03 - Prime Queen.mkv" tracks 1:"D:\Video\Miraculous - Geschichten von Ladybug und Cat Noir - S02E03 - Prime Queen_temp\Miraculous - Geschichten von Ladybug und Cat Noir - S02E03 - Prime Queen ID1 11ms German.ac3" --ui-language en
Extracting track 1 with the CodecID 'A_AC3' to the file 'D:\Video\Miraculous - Geschichten von Ladybug und Cat Noir - S02E03 - Prime Queen_temp\Miraculous - Geschichten von Ladybug und Cat Noir - S02E03 - Prime Queen ID1 11ms German.ac3'. Container format: Dolby Digital (AC-3)
Start:    13:48:53
End:      13:48:54
Duration: 00:00:00
General
Complete name         : D:\Video\Miraculous - Geschichten von Ladybug und Cat Noir - S02E03 - Prime Queen_temp\Miraculous - Geschichten von Ladybug und Cat Noir - S02E03 - Prime Queen ID1 11ms German.ac3
Format                : AC-3
File size             : 58.0 MiB
Overall bit rate mode : Constant
Overall bit rate      : 384 kb/s
Audio
Format                : AC-3
Bit rate              : 384 kb/s
Bit depth             : 16 bits
Stream size           : 58.0 MiB (100%)
----------------------- Indexing using ffmsindex -----------------------
"D:\_Programme\_Portable\Staxrip 1.9.0.0\Apps\Plugins\both\ffms2\ffmsindex.exe" "D:\Video\Miraculous - Geschichten von Ladybug und Cat Noir - S02E03 - Prime Queen_temp\Miraculous - Geschichten von Ladybug und Cat Noir - S02E03 - Prime Queen.mkv" "D:\Video\Miraculous - Geschichten von Ladybug und Cat Noir - S02E03 - Prime Queen_temp\Miraculous - Geschichten von Ladybug und Cat Noir - S02E03 - Prime Queen.ffindex"
Writing index... done.
Start:    13:48:54
End:      13:48:56
Duration: 00:00:01
--------------------------- AviSynth Script ---------------------------
LoadCPlugin("D:\_Programme\_Portable\Staxrip 1.9.0.0\Apps\Plugins\both\ffms2\ffms2.dll")
FFVideoSource("D:\Video\Miraculous - Geschichten von Ladybug und Cat Noir - S02E03 - Prime Queen_temp\Miraculous - Geschichten von Ladybug und Cat Noir - S02E03 - Prime Queen.mkv", colorspace = "YV12", \
              cachefile = "D:\Video\Miraculous - Geschichten von Ladybug und Cat Noir - S02E03 - Prime Queen_temp\Miraculous - Geschichten von Ladybug und Cat Noir - S02E03 - Prime Queen.ffindex")
-------------------------- Script Properties --------------------------
Source Frame Count : 31697
Source Frame Rate  : 25.000000
Source Duration    : 00:21:07.8800000
Target Frame Count : 31697
Target Frame Rate  : 25.000000
Target Duration    : 00:21:07.8800000
----------------------- MediaInfo Audio Source 1 -----------------------
General
Format                : AC-3
Audio
Format                : AC-3
Bit rate              : 384 kb/s
Bit depth             : 16 bits
-------------------- Video encoding using x264 2932 --------------------
"D:\_Programme\_Portable\Staxrip 1.9.0.0\Apps\x264\x264.exe" --crf 19 --preset slow --tune animation --profile main --level 4.1 --trellis 1 --8x8dct --no-fast-pskip --subme 9 --me umh --bframes 3 --ref 4 --min-keyint 25 --sar 255:191 --threads 34 --lookahead-threads 5 --deblock -1:-1 --output "D:\Video\Miraculous - Geschichten von Ladybug und Cat Noir - S02E03 - Prime Queen_temp\Miraculous - Geschichten von Ladybug und Cat Noir - S02E03 - Prime Queen_out.h264" "D:\Video\Miraculous - Geschichten von Ladybug und Cat Noir - S02E03 - Prime Queen_temp\Miraculous - Geschichten von Ladybug und Cat Noir - S02E03 - Prime Queen.avs"
avs [info]: 1440x1080p 255:191 @ 25/1 fps (cfr)
x264 [info]: using SAR=255/191
x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX FMA3 BMI2 AVX2
x264 [info]: profile Main, level 4.1, 4:2:0, 8-bit
x264 [info]: frame I:199   Avg QP:13.73  size:134263
x264 [info]: frame P:8450  Avg QP:17.19  size: 23247
x264 [info]: frame B:23048 Avg QP:21.16  size:  2167
x264 [info]: consecutive B-frames:  0.8%  6.0%  1.7% 91.4%
x264 [info]: mb I  I16..4: 46.3%  0.0% 53.7%
x264 [info]: mb P  I16..4:  8.7%  0.0%  4.6%  P16..4: 34.6%  8.9%  4.5%  0.0%  0.0%    skip:38.6%
x264 [info]: mb B  I16..4:  0.2%  0.0%  0.2%  B16..8: 14.7%  0.7%  0.1%  direct: 0.4%  skip:83.7%  L0:53.4% L1:43.5% BI: 3.2%
x264 [info]: direct mvs  spatial:99.9% temporal:0.1%
x264 [info]: coded y,uvDC,uvAC intra: 43.1% 71.9% 35.8% inter: 3.5% 8.3% 1.3%
x264 [info]: i16 v,h,dc,p: 38% 22% 12% 28%
x264 [info]: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 26% 15% 21%  5%  7%  8%  6%  6%  6%
x264 [info]: i8c dc,h,v,p: 28% 28% 28% 16%
x264 [info]: Weighted P-Frames: Y:0.2% UV:0.2%
x264 [info]: ref P L0: 63.9%  6.8% 19.8%  9.5%  0.0%
x264 [info]: ref B L0: 89.9%  7.8%  2.2%
x264 [info]: ref B L1: 97.2%  2.8%
x264 [info]: kb/s:1723.18
encoded 31697 frames, 38.40 fps, 1723.18 kb/s
Start:    13:48:57
End:      14:02:43
Duration: 00:13:45
Old 12th October 2018, 14:19   #3189  |  Link
FreaQ
Starfish
FreaQ's Avatar
1.9.0.0 2/2
General
Complete name        : D:\Video\Miraculous - Geschichten von Ladybug und Cat Noir - S02E03 - Prime Queen_temp\Miraculous - Geschichten von Ladybug und Cat Noir - S02E03 - Prime Queen_out.h264
Format               : AVC
File size            : 260 MiB
Writing library      : x264 core 157 r2932 303c484
Video
Format               : AVC
Format profile       : Main@L4.1
Format, CABAC        : Yes
Color space          : YUV
Bit depth            : 8 bits
Scan type            : Progressive
--------------------- Muxing using mkvmerge 26.0.0 ---------------------
"D:\_Programme\_Portable\Staxrip 1.9.0.0\Apps\MKVToolNix\mkvmerge.exe" -o "D:\Video\Miraculous - Geschichten von Ladybug und Cat Noir - S02E03 - Prime Queen.mkv" "D:\Video\Miraculous - Geschichten von Ladybug und Cat Noir - S02E03 - Prime Queen_temp\Miraculous - Geschichten von Ladybug und Cat Noir - S02E03 - Prime Queen_out.h264" --audio-tracks 0 --language 0:ger --sync 0:11 --default-track 0:0 --forced-track 0:0 "D:\Video\Miraculous - Geschichten von Ladybug und Cat Noir - S02E03 - Prime Queen_temp\Miraculous - Geschichten von Ladybug und Cat Noir - S02E03 - Prime Queen ID1 11ms German.ac3" --global-tags "D:\Video\Miraculous - Geschichten von Ladybug und Cat Noir - S02E03 - Prime Queen_temp\Miraculous - Geschichten von Ladybug und Cat Noir - S02E03 - Prime Queen_tags.xml" --ui-language en
mkvmerge v26.0.0 ('In The Game') 64-bit
'D:\Video\Miraculous - Geschichten von Ladybug und Cat Noir - S02E03 - Prime Queen_temp\Miraculous - Geschichten von Ladybug und Cat Noir - S02E03 - Prime Queen_out.h264': Using the demultiplexer for the format 'AVC/h.264'.
'D:\Video\Miraculous - Geschichten von Ladybug und Cat Noir - S02E03 - Prime Queen_temp\Miraculous - Geschichten von Ladybug und Cat Noir - S02E03 - Prime Queen ID1 11ms German.ac3': Using the demultiplexer for the format 'AC-3'.
'D:\Video\Miraculous - Geschichten von Ladybug und Cat Noir - S02E03 - Prime Queen_temp\Miraculous - Geschichten von Ladybug und Cat Noir - S02E03 - Prime Queen_out.h264' track 0: Using the output module for the format 'AVC/h.264 (unframed)'.
'D:\Video\Miraculous - Geschichten von Ladybug und Cat Noir - S02E03 - Prime Queen_temp\Miraculous - Geschichten von Ladybug und Cat Noir - S02E03 - Prime Queen ID1 11ms German.ac3' track 0: Using the output module for the format 'AC-3'.
The file 'D:\Video\Miraculous - Geschichten von Ladybug und Cat Noir - S02E03 - Prime Queen.mkv' has been opened for writing.
'D:\Video\Miraculous - Geschichten von Ladybug und Cat Noir - S02E03 - Prime Queen_temp\Miraculous - Geschichten von Ladybug und Cat Noir - S02E03 - Prime Queen_out.h264' track 0: Extracted the aspect ratio information from the MPEG-4 layer 10 (AVC) video data and set the display dimensions to 1923/1080.
The cue entries (the index) are being written...
Multiplexing took 2 seconds.
Start:    14:02:43
End:      14:02:45
Duration: 00:00:01
General
Complete name                 : D:\Video\Miraculous - Geschichten von Ladybug und Cat Noir - S02E03 - Prime Queen.mkv
Format                        : Matroska
Format version                : Version 4 / Version 2
File size                     : 319 MiB
Overall bit rate              : 2 109 kb/s
Encoded date                  : UTC 2018-10-12 12:02:43
Writing application           : mkvmerge v26.0.0 ('In The Game') 64-bit
Writing library               : libebml v1.3.6 + libmatroska v1.4.9
Writing frontend              : StaxRip v1.9.0.0
Video
Format                        : AVC
Format, CABAC                 : Yes
Codec ID                      : V_MPEG4/ISO/AVC
Bit rate                      : 1 723 kb/s
Original display aspect ratio : 16:9
Frame rate mode               : Constant
Color space                   : YUV
Bit depth                     : 8 bits
Bits/(Pixel*Frame)            : 0.044
Stream size                   : 260 MiB (82%)
Default                       : Yes
Forced                        : No
Audio
Format                        : AC-3
Codec ID                      : A_AC3
Bit rate                      : 384 kb/s
Bit depth                     : 16 bits
Delay relative to video       : 11 ms
Stream size                   : 58.0 MiB (18%)
Language                      : German
Default                       : No
Forced                        : No
----------------------------- Job Complete -----------------------------
Start:    13:48:46
End:      14:02:45
Duration: 00:13:58
Old 12th October 2018, 14:20   #3190  |  Link
FreaQ
Starfish
FreaQ's Avatar
1.7.0.6 1/2
StaxRip    : 1.7.0.6
DPI        : 96
General
Format                   : MPEG-TS
File size                : 862 MiB
Video
Format                   : AVC
Format, CABAC            : Yes
Format, RefFrames        : 4 frames
Codec ID                 : 27
Color space              : YUV
Bit depth                : 8 bits
Audio
Format                   : AC-3
Format, Endianness       : Big
Codec ID                 : 6
Bit rate                 : 384 kb/s
Bit depth                : 16 bits
Language                 : German
------------- ffmpeg: Re-mux TS to MKV using ffmpeg 3.3.4 -------------
D:\_Programme\_Portable\StaxRip\Apps\ffmpeg\ffmpeg.exe -i "D:\Video\Miraculous - Geschichten von Ladybug und Cat Noir - S02E03 - Prime Queen.ts" -c:a copy -c:v copy -sn -y -hide_banner "D:\Video\Miraculous - Ge..._temp\Miraculous - Geschichten von Ladybug und Cat Noir - S02E03 - Prime Queen.mkv"
[h264 @ 00000227f7d276c0] mmco: unref short failure
[h264 @ 00000227f7d276c0] Increasing reorder buffer to 2
Program 5500
Output #0, matroska, to 'D:\Video\Miraculous - Ge..._temp\Miraculous - Geschichten von Ladybug und Cat Noir - S02E03 - Prime Queen.mkv':
Metadata:
encoder         : Lavf57.71.100
Stream mapping:
Start:    14:26:18
End:      14:26:23
Duration: 00:00:05
------------------ Demux MKV using mkvextract 20.0.0 ------------------
D:\_Programme\_Portable\StaxRip\Apps\MKVToolNix\mkvextract.exe "D:\Video\Miraculous - Ge..._temp\Miraculous - Geschichten von Ladybug und Cat Noir - S02E03 - Prime Queen.mkv" tracks 1:"D:\Video\Miraculous - Ge..._temp\Miraculous - Geschichten von Ladybug und Cat Noir - S02E03 - Prime Queen ID1 11ms German.ac3" --ui-language en
Extracting track 1 with the CodecID 'A_AC3' to the file 'D:\Video\Miraculous - Ge..._temp\Miraculous - Geschichten von Ladybug und Cat Noir - S02E03 - Prime Queen ID1 11ms German.ac3'. Container format: Dolby Digital (AC-3)
Start:    14:26:25
End:      14:26:26
Duration: 00:00:00
General
Complete name         : D:\Video\Miraculous - Ge..._temp\Miraculous - Geschichten von Ladybug und Cat Noir - S02E03 - Prime Queen ID1 11ms German.ac3
Format                : AC-3
Audio
Format                : AC-3
Bit rate              : 384 kb/s
Bit depth             : 16 bits
D:\_Programme\_Portable\StaxRip\Apps\Plugins\both\ffms2\ffmsindex.exe "D:\Video\Miraculous - Ge..._temp\Miraculous - Geschichten von Ladybug und Cat Noir - S02E03 - Prime Queen.mkv" "D:\Video\Miraculous - Ge..._temp\Miraculous - Geschichten von Ladybug und Cat Noir - S02E03 - Prime Queen.ffindex"
Start:    14:26:26
End:      14:26:28
Duration: 00:00:01
LoadPlugin("D:\_Programme\_Portable\StaxRip\Apps\Plugins\both\ffms2\ffms2.dll")
LoadPlugin("D:\_Programme\_Portable\StaxRip\Apps\Plugins\avs\TDeint\TDeint.dll")
FFVideoSource("D:\Video\Miraculous - Ge..._temp\Miraculous - Geschichten von Ladybug und Cat Noir - S02E03 - Prime Queen.mkv", colorspace = "YV12", \
              cachefile = "D:\Video\Miraculous - Ge..._temp\Miraculous - Geschichten von Ladybug und Cat Noir - S02E03 - Prime Queen.ffindex")
SelectEven().AssumeFPS(25)
TDeint()
General
Format                : AC-3
Audio
Format                : AC-3
Bit rate              : 384 kb/s
Bit depth             : 16 bits
-------------- Video encoding using x264 0.150.2851 8-Bit --------------
D:\_Programme\_Portable\StaxRip\Apps\x264\x264.exe --crf 19 --preset slow --tune animation --profile main --level 4.1 --trellis 1 --8x8dct --no-fast-pskip --subme 9 --me umh --bframes 3 --ref 4 --min-keyint 25 --sar 255:191 --threads 34 --lookahead-threads 5 --deblock -1:-1 --output "D:\Video\Miraculous - Ge..._temp\Miraculous - Geschichten von Ladybug und Cat Noir - S02E03 - Prime Queen 2_out.h264" "D:\Video\Miraculous - Ge..._temp\Miraculous - Geschichten von Ladybug und Cat Noir - S02E03 - Prime Queen 2.avs"
x264 [info]: frame I:322   Avg QP:15.89  size:125493
x264 [info]: frame P:10271 Avg QP:19.05  size: 27995
x264 [info]: frame B:21104 Avg QP:22.21  size:  7547
x264 [info]: consecutive B-frames:  8.2%  7.9%  3.6% 80.3%
x264 [info]: mb I  I16..4: 48.1%  0.0% 51.9%
x264 [info]: mb P  I16..4: 14.8%  0.0%  7.6%  P16..4: 34.9%  8.8%  4.4%  0.0%  0.0%    skip:29.6%
x264 [info]: mb B  I16..4:  1.0%  0.0%  0.8%  B16..8: 23.9%  2.9%  0.6%  direct: 1.8%  skip:68.9%  L0:40.2% L1:53.4% BI: 6.4%
x264 [info]: direct mvs  spatial:100.0% temporal:0.0%
x264 [info]: coded y,uvDC,uvAC intra: 42.3% 67.7% 31.1% inter: 6.7% 15.3% 2.0%
x264 [info]: i16 v,h,dc,p: 39% 21% 11% 29%
x264 [info]: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 27% 14% 22%  5%  7%  7%  6%  6%  6%
x264 [info]: i8c dc,h,v,p: 29% 27% 28% 16%
x264 [info]: Weighted P-Frames: Y:0.5% UV:0.4%
x264 [info]: ref P L0: 62.9%  8.0% 20.2%  8.1%  0.8%  0.0%
x264 [info]: ref B L0: 87.9%  9.5%  2.6%
x264 [info]: ref B L1: 96.1%  3.9%
x264 [info]: kb/s:3074.21
encoded 31697 frames, 21.56 fps, 3074.21 kb/s
Start:    14:27:18
End:      14:51:48
Duration: 00:24:30
Old 12th October 2018, 14:21   #3191  |  Link
FreaQ
Starfish
FreaQ's Avatar
1.7.0.6 2/2
General
Complete name        : D:\Video\Miraculous - Ge..._temp\Miraculous - Geschichten von Ladybug und Cat Noir - S02E03 - Prime Queen 2_out.h264
Format               : AVC
File size            : 465 MiB
Writing library      : x264 core 152 r2851 ba24899
Video
Format               : AVC
Format, CABAC        : Yes
Color space          : YUV
Bit depth            : 8 bits
--------------------- Muxing using mkvmerge 20.0.0 ---------------------
D:\_Programme\_Portable\StaxRip\Apps\MKVToolNix\mkvmerge.exe -o "D:\Video\Miraculous - Geschichten von Ladybug und Cat Noir - S02E03 - Prime Queen 2.mkv" "D:\Video\Miraculous - Ge..._temp\Miraculous - Geschichten von Ladybug und Cat Noir - S02E03 - Prime Queen 2_out.h264" --audio-tracks 0 --language 0:ger --sync 0:11 --default-track 0:0 --forced-track 0:0 "D:\Video\Miraculous - Ge..._temp\Miraculous - Geschichten von Ladybug und Cat Noir - S02E03 - Prime Queen ID1 11ms German.ac3" --global-tags "D:\Video\Miraculous - Ge..._temp\Miraculous - Geschichten von Ladybug und Cat Noir - S02E03 - Prime Queen 2_tags.xml" --ui-language en
mkvmerge v20.0.0 ('I Am The Sun') 64-bit
'D:\Video\Miraculous - Ge..._temp\Miraculous - Geschichten von Ladybug und Cat Noir - S02E03 - Prime Queen 2_out.h264': Using the demultiplexer for the format 'AVC/h.264'.
'D:\Video\Miraculous - Ge..._temp\Miraculous - Geschichten von Ladybug und Cat Noir - S02E03 - Prime Queen ID1 11ms German.ac3': Using the demultiplexer for the format 'AC-3'.
'D:\Video\Miraculous - Ge..._temp\Miraculous - Geschichten von Ladybug und Cat Noir - S02E03 - Prime Queen 2_out.h264' track 0: Using the output module for the format 'AVC/h.264 (unframed)'.
'D:\Video\Miraculous - Ge..._temp\Miraculous - Geschichten von Ladybug und Cat Noir - S02E03 - Prime Queen ID1 11ms German.ac3' track 0: Using the output module for the format 'AC-3'.
The file 'D:\Video\Miraculous - Geschichten von Ladybug und Cat Noir - S02E03 - Prime Queen 2.mkv' has been opened for writing.
'D:\Video\Miraculous - Ge..._temp\Miraculous - Geschichten von Ladybug und Cat Noir - S02E03 - Prime Queen 2_out.h264' track 0: Extracted the aspect ratio information from the MPEG-4 layer 10 (AVC) video data and set the display dimensions to 1923/1080.
Multiplexing took 3 seconds.
Start:    14:51:49
End:      14:51:51
Duration: 00:00:02
General
Complete name                 : D:\Video\Miraculous - Geschichten von Ladybug und Cat Noir - S02E03 - Prime Queen 2.mkv
Format                        : Matroska
File size                     : 523 MiB
Overall bit rate              : 3 460 kb/s
Encoded date                  : UTC 2018-10-12 12:51:49
Writing application           : mkvmerge v20.0.0 ('I Am The Sun') 64-bit
Writing library               : libebml v1.3.5 + libmatroska v1.4.8
Writing frontend              : StaxRip v1.7.0.6
Video
Format                        : AVC
Format, CABAC                 : Yes
Bit rate                      : 3 074 kb/s
Color space                   : YUV
Bit depth                     : 8 bits
Bits/(Pixel*Frame)            : 0.079
Stream size                   : 465 MiB (89%)
Default                       : Yes
Forced                        : No
Audio
Format                        : AC-3
Codec ID                      : A_AC3
Bit rate                      : 384 kb/s
Bit depth                     : 16 bits
Stream size                   : 58.0 MiB (11%)
Language                      : German
Default                       : No
Forced                        : No
Start:    14:27:17
End:      14:51:51
Duration: 00:24:34
Old 12th October 2018, 20:16   #3192  |  Link
imhh11
Hi, its very easy to do.
Load NVenc H265 , then import your HDR file and start the encode.
If your source is DCI-P3, you'll have to set the mastering display values manually in the VUI tab. If your source is BT2020: nothing else to do.
You could also use my custom staxrip with templates especially made for encoding UHD-BDs. Nothing to manually set, everything is automatic (dci-p3 or bt2020)
https://drive.google.com/open?id=1yO...jcItjpOOfa9rnD
Old 13th October 2018, 10:05   #3193  |  Link
DaMacFunkin
https://drive.google.com/open?id=1o7...Wy6SxeriUTJOYF
Thank you very much, I will give this a go.
Old 16th October 2018, 17:26   #3194  |  Link
Revan654
Revan654's Avatar
StaxRip is only passing the flags onto the Encoder. If there is an issues it's due to the encoder, not StaxRip it self. It's likely due to internal changes to the encoder, Which I have no control over. Whoever compiled them could have done it incorrectly. You can also try VS2015 version or GCC version, each one uses different code to compile the source. Also make sure your using the correct one to match your CPU.
Lastly Make sure sourcefilter is being used correctly. If your using AVS, click source play. it will playback the file using the avs file. It can help narrow down where the issue is.
Without knowing the exact process that creating the issues, it's impossible to look at the code and see if it's creating issues.
I'm currently re-installing VS 2017, it might take a bit before I can look at the code. The setup was eating way to much HDD space(I was close to 100GB just for VS 2017). No Compiler should eat that much space.
The Next Release, Everything will be compiled from the ground up using my CPU, instead of using exe from others. It will delay things bit but this way I know everything is 100% correct.
if you look at your AVS there very different.
vs
TDeint()
Old 18th October 2018, 14:17   #3195  |  Link
mironicus
QSVEnc
Hello,
I am using Staxrip and tried H265 GPU encoding with the integrated Intel Kabylake GPU. That is working, however if I try 10 Bit Encoding (MAIN10), the files get so much larger compared with 8 Bit (MAIN) and same settings.
For example the length of a demo file in 8 bit after encoding: 388 MB, the version with MAIN10 and the same settings is 1.79 GB.
I also tried Handbrake also with 8/10 Bit encoding and Intel GPU and the file size of the 10 bit version is usually smaller than the 8 bit version.
Can someone confirm this problem?
mironicus is offline   Reply With Quote
Old 18th October 2018, 16:34   #3196  |  Link
Khun_Doug
Did you use Mediainfo or something similar to look at the bitrate of the encoded file to compare the 8 bit encode versus the 10 bit encode? It could be that the 10 bit encode is somehow encoding at a much greater bitrate than expected. I know from own experience that using NVEncc with my Nvidia board produces the expected results.
Khun_Doug is offline   Reply With Quote
Old 19th October 2018, 02:15   #3197  |  Link
Revan654
Revan654's Avatar
Originally Posted by mironicus View Post
Hello,
HandBrake Uses FFMPEG, Where StaxRip uses QSVEncC/GPUBrandENCc.
You can Use FFMPEG Encoder Engine too. The Main Encoder are the ENCc.
For Intel:
New Release: https://github.com/rigaya/QSVEnc/releases/tag/3.10
Fixes: Fix decode issue with some HEVC 10bit inputs
Updated: Updated to Intel Media SDK 2018 R2 (API 1.27).
Nvidia:
New Release: https://github.com/rigaya/NVEnc/releases/tag/4.20
Fixes: Fix avhw decode issue on some 10bit HEVC
Fixes: avsw decode issue on some 10bit HEVC + other 10Bit Fixes.
Old 19th October 2018, 18:57   #3198  |  Link
FreaQ
Starfish
FreaQ's Avatar
You are right.
Since TDeint is missing from1.9.0 I used yadifmod2. It seems I am not capable of configuring it correctly and this caused the slowdown.
As for 1.7.6 I have no clue were SelectEven().AssumeFPS(25) came from because I just enabled TDeint.
Old 20th October 2018, 11:42   #3199  |  Link
-QfG-
QfG Group Germany
-QfG-'s Avatar
A simple question?
When i'm extract mkv's, and i have *.sup subtitles and audio, following happens in 1.9:
- Subtitles (sup) without extension (example german.sup, extracted: german.)
- Audio: will be extracted in mka container. Why? I must demux the mka container for dubbing.
Rolling back to 1.8, i hope you fix this. Or is this only a setting, i don't know?
-QfG- is offline   Reply With Quote
Old 20th October 2018, 20:37   #3200  |  Link
Zetti
MKVToolNix v28.0.0 is released.
