27th November 2015, 20:07 | #4821 | Link |
Thx, but it is not available as compiled build yet
http://ffmpeg.zeranoe.com/builds/win32/static/ |
29th November 2015, 10:19 | #4823 | Link |
I don't see any option in MeGUI to manage VFR video: http://forum.doom9.org/showthread.php?t=172917
Feature request: 1) Add a tool to extract video timecodes from mkv. 2) Add a option to load video timecodes in mkv muxer.
1st December 2015, 10:49 | #4825 | Link |
I don't have samples now, maybe some anime fan user.
BTW, for a first test, you can use any mkv source. To extract, supossed the "0" is the video track: "...megui\tools\mkvmerge\mkvextract.exe" timecodes_v2 "source.mkv" 0:"my_timecodes.txt" To merge you need insert: "...megui\tools\mkvmerge\mkvmerge.exe" ... --timecodes 0:"my_timecodes.txt" ... VIDEO_TRACK
4th December 2015, 08:14 | #4826 | Link |
2624 [Log] do not print a warning when "Haali Matroska Splitter" is not found 2623 [OneClick] removed the deprecated option "Language to set if it cannot be determined" 2622 [File Indexer] choose by default in the file selector "All supported files" 2621 [OneClick] fixed the option "Languages to select if selection does not match". Bug #822 |
4th December 2015, 17:59 | #4827 | Link | |
Opus v1.1.1 is available http://www.opus-codec.org/downloads/ Last edited by Barough; 4th December 2015 at 18:28. |
5th December 2015, 20:51 | #4829 | Link |
I keep on getting this:
---[Error] [12/5/2015 1:43:40 PM] LoadPlugin: unable to load "C:\Users\Daniel\Desktop\MeGUI_2525_x86\tools\lsmash\LSMASHSource.dll", Module not found. Install missing library? |
5th December 2015, 21:15 | #4832 | Link |
First discover which year: Microsoft Visual Studio 2010 / 2012 / 2013 / 2015? A different LSMASHSource.dll may need a different runtime installed if it was compiled with a different generation of C++ compiler.
I keep repeating myself: Never rely on MSC*.dll's placed in local folders. Always install all runtime installers (in 32 bit, if you run a 32 bit AviSynth). Last edited by LigH; 5th December 2015 at 21:18. |
5th December 2015, 21:17 | #4833 | Link |
Probably: vcredist_x86.exe.
5th December 2015, 21:46 | #4834 | Link | |
This only started happening when I updated L-Smash. |
5th December 2015, 21:52 | #4835 | Link |
You can try to load the DLL in "Dependency Walker". Or you can check which DLLs you did not unpack from the archive of your updated version. Maybe it is even documented in a text file which version it was compiled with.
In case of doubt, install all recent runtime versions. So you did not miss any for certain. Last edited by LigH; 5th December 2015 at 21:56. |
5th December 2015, 22:11 | #4836 | Link |
Ignore my last post. I cannot get it to run, either.
Google: http://stackoverflow.com/questions/1...t-dll-problems |
5th December 2015, 22:22 | #4838 | Link | |
5th December 2015, 22:33 | #4839 | Link |
How did you update L-SMASH Source? Did the MeGUI updater offer a new version? Or did you try to exchange it manually?
__ Interesting. The latest LSMASHSource.dll version in MeGUI\tools\lsmash appears to be a dynamic build with separate libav DLLs... Rather unusual, we used to prefer the static build. Last edited by LigH; 5th December 2015 at 22:48. |
