11th December 2018, 17:06 | #1381 | Link |
VidCoder Author
The HandBrake library exposes a "default" bitrate when you give it a codec, samplerate and channel layout. In their UI they use it to initially pick the bitrate that's chosen when you load up the source. In VidCoder I use it to power the "Auto" choice. With "Auto" it will always pick the default bitrate for whatever sample rate, mixdown and codec is chosen.
11th December 2018, 18:06 | #1382 | Link |
so the 160 in my example is from handbrake
but the 192 must be from ur UI then 10) can u add the column selection in completed tab just as queued tab? such as qualities audio codecs etc 11) is it possible when u edit a completed task and change the "restored from queue" preset into a "xyz" preset to follow the "xyz" file naming rules? so for instance if i restore a sample i did with light denoise and i select a preset called "strong" that has strong denoise and adds to the filename the {preset} name so instead of "captain fantastic (2016) - 21 - light.mkv" it will switch the name to "captain fantastic (2016) - 21 - medium.mkv" i assume thats must be difficult request due to getting the naming scleme from the picker initially so normally u would expect a brand new "dragged and dropped" movie to name not one already verified by the picker basically is there any way to alter the naming scleme from a "restored from queue" item or is it locked and can only be changed manually? Last edited by napouser; 12th December 2018 at 05:18. |
13th December 2018, 08:00 | #1383 | Link |
VidCoder Author
I just tried editing a completed task and switching the preset and it does update the generated file name. Is that not what you're seeing?
As for #10 I'll put it on the backlog but it could be a while before I get to it. |
14th December 2018, 00:12 | #1384 | Link |
wierd
did u press "edit"? did the task returned as "restored from completed" preset?? what happens when u change the "restored from completed" preset to a "xyz" preset ? does the name change accordingly? mine is stuck. on the contrary when i do samples and i change presets it goes from strong to medium etc and when i slide the qrf bar it changes 21 to 22 etc Last edited by napouser; 14th December 2018 at 03:05. |
15th December 2018, 04:32 | #1385 | Link |
VidCoder Author
Yes I pressed "Edit" and it returned as "restored from completed" preset. After switching to a different one, the name did change.
Not sure it's happening here but if you make a manual edit to the path it can "lock" it to that name and disable the auto-naming. |
15th December 2018, 07:33 | #1386 | Link |
hmmmm
apparently when restoring from queue the general naming options take priority over picker naming if i restore a stadard movie the naming works if i restore a sample it doesnt thats becauze samples have "picker" specific naming scleme while normal movies dont so they fall back to the general options i suppose i can switch the general option to be for samples and make the stadard movies have a specific naming scleme that just uses {source} |
15th December 2018, 09:18 | #1387 | Link |
ok i found it
apparently the "time range selection" locks the auto name feature try creating a picker with time selection 1 00 00 to 1 30 00 drag and drop a movie play with presets a bit queue it then add an other movie queue it now restore the first one cant do autorename |
22nd December 2018, 01:49 | #1389 | Link |
VidCoder Author
Released VidCoder 4.24 Beta:
22nd December 2018, 19:21 | #1391 | Link |
HandBrake v1.2.0 is released.
https://forum.handbrake.fr/viewtopic.php?f=33&t=38539 |
23rd December 2018, 07:22 | #1392 | Link |
VidCoder Author
Released VidCoder 4.25 Beta:
24th December 2018, 14:04 | #1393 | Link |
RyanJ
Is there currently any support for 10-bit encoding by any chance? If not, is there a possibility that this will become available in the future? It may already be there and I've just missed it. There are a lot of options!
Thanks. |
25th December 2018, 03:35 | #1396 | Link |
Released VidCoder 4.20 Beta:
"Added fallback to av_aac for when presets are using fdk_aac but the current build of hb.dll doesn't support it." obviusly this means that if they fallback if and when u restore an fdk_aac build they will stay that way so u have to readd them(or readd the queue from file ...maybe) |
27th December 2018, 06:35 | #1397 | Link |
VidCoder Author
Released VidCoder 4.26 Beta:
28th December 2018, 11:47 | #1398 | Link | |
RyanJ
Thank you |
10th January 2019, 08:35 | #1400 | Link |
VidCoder Author
Released VidCoder 4.27 Beta:
