15th February 2014, 08:16 | #19201 | Link |
Hi Guys,
sadly another one with that annoying error: ---------------------- [02.15.14] BD Rebuilder v0.46.11 (beta) [07:48:46] Source: RED_2 - Input BD size: 35,32 GB - Approximate total content: [03:00:15.596] - Target BD size: 22,95 GB - Windows Version: 6.2 [9200] - Auto Quality: Good (Very Fast), ABR - Decoding/Frame serving: DGDecNV - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [07:48:46] PHASE ONE, Encoding - [07:48:46] Processing: VID_00027 (1 of 4) - [07:48:46] Extracting A/V streams [VID_00027] - [07:48:51] Reencoding video [VID_00027] - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 107 frames - [07:48:51] Reencoding: VID_00027, Pass 1 of 1 - [07:48:51] Video Encode complete - [07:48:51] Processing audio tracks - [07:48:51] Multiplexing M2TS - [07:48:55] Processing: VID_00026 (2 of 4) - [07:48:55] Extracting A/V streams [VID_00026] - [07:49:02] Reencoding video [VID_00026] - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 2.959 frames - [07:49:02] Reencoding: VID_00026, Pass 1 of 1 - [07:49:16] Video Encode complete - [07:49:16] Processing audio tracks - Track 4352 (deu): Keeping original audio - [07:49:16] Multiplexing M2TS - [07:49:20] Processing: VID_00001 (3 of 4) - [07:49:20] Extracting A/V streams [VID_00001] - [07:50:08] Reencoding video [VID_00001] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 49.931 frames - Bitrate: 12.223 Kbs - [07:50:08] Reencoding: VID_00001, Pass 1 of 1 - [07:55:44] Video Encode complete - [07:55:44] Processing audio tracks - Track 4352 (eng): Keeping original audio - [07:55:44] Multiplexing M2TS - [07:56:05] Processing: VID_00000 (4 of 4) - [07:56:05] Extracting A/V streams [VID_00000] - Error in attempt to extract audio/subs. - [07:58:22] - Failed to retrieve audio, aborted Since ALL my Rips seems to have problem now (only in BDRB it seems) I took a shot and tried that file in tsmuxer as that is usually the problem described when that error appears. But tsmuxer is not the problem it seems: SmartLabs tsMuxeR. Version 1.10.6 http://www.smlabs.net Decoding H264 stream (track 1): Profile: High@4.1 Resolution: 1920:1080p Frame rate: 23.976 H.264 stream does not contain fps field. Muxing fps=23.976 Decoding DTS-HD stream (track 2): Bitrate: 1536Kbps core + MLP data.Sample Rate: 48KHz Channels: 7.1 (DTS Master Audio) Decoding DTS-HD stream (track 3): Bitrate: 1536Kbps core + MLP data.Sample Rate: 48KHz Channels: 7.1 (DTS Master Audio) Decoding PGS stream (track 5): Resolution: 1920:1080 Frame rate: 23.976 Decoding PGS stream (track 4): Resolution: 1920:1080 Frame rate: 23.976 Decoding PGS stream (track 6): Resolution: 1920:1080 Frame rate: 23.976 Processed 166993 video frames Demux complete. Demuxing time: 1 min 22 sec Full BD-Backup. Iīm trying Movie only to see if that helps. Until now every time BDRB showed that message I ALWAYS was able to "save" the movie only with BDtoAVCHD. And it shows me a working progress with VID_00000 instead of stopping with an error. I really think this is a problem of BDRB. Whatever it is see here: [02.15.14] BD Rebuilder v0.46.11 (beta) [08:13:32] Source: RED_2_00000 - Input BD size: 24,95 GB - Approximate total content: [01:56:04.999] - Target BD size: 22,95 GB - Windows Version: 6.2 [9200] - MOVIE-ONLY mode enabled - Auto Quality: Good (Very Fast), ABR - Decoding/Frame serving: DGDecNV - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [08:13:34] PHASE ONE, Encoding - [08:13:34] Processing: VID_00000 (1 of 1) - [08:13:34] Extracting A/V streams [VID_00000] - [08:16:55] Reencoding video [VID_00000] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 166.993 frames - Bitrate: 20.916 Kbs - [08:16:55] Reencoding: VID_00000, Pass 1 of 1 Anyone got an idea why that happens? |
15th February 2014, 09:16 | #19202 | Link | |
Then, no more burning program complains rum. PS: If I use tsMuxeR solo, that does not happen when I Muxe a mkv to AVCHD. Teste just BD_Rebuilder if it happens there, as I have already noticed with these additional two files. Last edited by inge70; 15th February 2014 at 09:22. |
15th February 2014, 12:38 | #19203 | Link |
I bumped into something which is very likely not a bug with BD-RB, but it's vexing nevertheless. I did a full backup of The Americans disc 2 on 0.46.11, and the deleted scenes came out somewhat messed up again. The four relevant m2ts files are 00300, 00301, 00302 and 00303.
Since the backup came out a bit undersized and there was enough space for them, I decided to replace the four messed up files with the originals. So I copied the four m2ts files to the backup, followed by the .clpi and .mpls files, also named 00300, 00301, 00302 and 00303. I also replaced the backups with originals in the BDMV / Backup directory. But all that wasn't enough, because the backup does not play correctly. Deleted scenes start in the middle, play for a second, then skip to the next one. What did I miss or mess up? |
15th February 2014, 15:17 | #19204 | Link | |
Can you give me a specific sequence that will cause it? Last edited by jdobbs; 15th February 2014 at 15:37. |
15th February 2014, 15:48 | #19206 | Link | |
Source is original Blu-ray rip. |
15th February 2014, 15:54 | #19207 | Link |
RE:Info
Hi there Jdobbs,
cleared my harddrive up su just started a new run to deliver an ini file. INSPECT: - Windows Version: 6.2 [9200] - AVISYNTH Version: [2.6.0.3], not recommended version - HAALI Splitter: [1.9.42.1], Ok - FFDSHOW: [4504], Ok - FFDSHOW VC-1 set incorrectly: [19] - FFDSHOW MPEG2 set incorrectly: [19] - FFDSHOW AVC set incorrectly: [19] - AnyDVD settings check: Ok. - BD-RB v0.46.0.11, not current INFO FFDSHOW Errors = Intel Quicksync is set ============================================== Complete Verbose Log of Project: [02.15.14] BD Rebuilder v0.46.11 (beta) [15:45:41] Source: RED_2_00000 - Input BD size: 24,95 GB - Approximate total content: [01:56:04.999] - Target BD size: 22,95 GB - Windows Version: 6.2 [9200] - MOVIE-ONLY mode enabled - Auto Quality: Good (Very Fast), ABR - Decoding/Frame serving: DGDecNV - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [15:45:41] PHASE ONE, Encoding - [15:45:41] Processing: VID_00000 (1 of 1) - [15:45:41] Extracting A/V streams [VID_00000] [15:45:46]PHASE ONE aborted by user request ---------------------- [02.15.14] BD Rebuilder v0.46.11 (beta) [15:45:53] Source: RED_2 - Input BD size: 35,32 GB - Approximate total content: [03:00:15.596] - Target BD size: 22,95 GB - Windows Version: 6.2 [9200] - Auto Quality: Good (Very Fast), ABR - Decoding/Frame serving: DGDecNV - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [15:45:54] PHASE ONE, Encoding - [15:45:54] Processing: VID_00027 (1 of 4) - [15:45:54] Extracting A/V streams [VID_00027] - [15:45:59] Reencoding video [VID_00027] - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 107 frames - [15:45:59] Reencoding: VID_00027, Pass 1 of 1 - [15:45:59] Video Encode complete - [15:45:59] Processing audio tracks - [15:45:59] Multiplexing M2TS - [15:46:03] Processing: VID_00026 (2 of 4) - [15:46:03] Extracting A/V streams [VID_00026] - [15:46:10] Reencoding video [VID_00026] - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 2.959 frames - [15:46:10] Reencoding: VID_00026, Pass 1 of 1 - [15:46:24] Video Encode complete - [15:46:24] Processing audio tracks - Track 4352 (deu): Keeping original audio - [15:46:24] Multiplexing M2TS - [15:46:28] Processing: VID_00001 (3 of 4) - [15:46:28] Extracting A/V streams [VID_00001] - [15:47:10] Reencoding video [VID_00001] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 49.931 frames - Bitrate: 12.223 Kbs - [15:47:10] Reencoding: VID_00001, Pass 1 of 1 [02.15.14] Checking System Settings - BD-Rebuilder v0.46.11 (beta) - Windows Version: 6.2 [9200] - AVISYNTH Version: 2.6.0.3, not recommended version - HAALI Splitter: 1.9.42.1, Ok - FFDSHOW: 4504, Ok - FFDSHOW VC-1 set incorrectly: [19] - FFDSHOW MPEG2 set incorrectly: [19] - FFDSHOW AVC set incorrectly: [19] - AnyDVD settings check: Ok. - X264: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok - FRIMEncode: Ok - FRIMDecode: Ok [02.15.14] Systems Settings Check complete - [15:52:48] Video Encode complete - [15:52:48] Processing audio tracks - Track 4352 (eng): Keeping original audio - [15:52:48] Multiplexing M2TS - [15:53:09] Processing: VID_00000 (4 of 4) - [15:53:09] Extracting A/V streams [VID_00000] - Error in attempt to extract audio/subs. - [15:55:26] - Failed to retrieve audio, aborted TRYING MOVIE ONLY BACKUP Completet Verbose Log: 02.15.14] BD Rebuilder v0.46.11 (beta) [15:56:18] Source: RED_2_00000 - Input BD size: 24,95 GB - Approximate total content: [01:56:04.999] - Target BD size: 22,95 GB - Windows Version: 6.2 [9200] - MOVIE-ONLY mode enabled - Auto Quality: Good (Very Fast), ABR - Decoding/Frame serving: DGDecNV - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [15:56:20] PHASE ONE, Encoding - [15:56:20] Processing: VID_00000 (1 of 1) - [15:56:20] Extracting A/V streams [VID_00000] - [15:59:38] Reencoding video [VID_00000] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 166.993 frames - Bitrate: 20.916 Kbs - [15:59:38] Reencoding: VID_00000, Pass 1 of 1 NOW it is NO PROBLEM ??? Last edited by Rodger; 15th February 2014 at 16:10. Reason: forgot ini-file |
15th February 2014, 16:24 | #19208 | Link |
The FFDSHOW settings won't really matter when you are using DGDecNV, so that's no big deal. But I'm confused as to how you could possibly get the "BD-RB v0.46.0.11, not current" message? The INSPECT in the HELP menu doesn't even check that???
What do you mean by "NOW it is NO PROBLEM"? |
15th February 2014, 16:45 | #19211 | Link |
Sorry,
thought youīd figure it out. The Inspect part was from the external inspect.exe There is a inspect from inside BDRB in the Logs of my last post. So to prevent further confusion.... [02.15.14] Checking System Settings - BD-Rebuilder v0.46.11 (beta) - Windows Version: 6.2 [9200] - AVISYNTH Version: 2.6.0.3, not recommended version - HAALI Splitter: 1.9.42.1, Ok - FFDSHOW: 4504, Ok - FFDSHOW VC-1 set incorrectly: [19] - FFDSHOW MPEG2 set incorrectly: [19] - FFDSHOW AVC set incorrectly: [19] - AnyDVD settings check: Ok. - X264: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok - FRIMEncode: Ok - FRIMDecode: Ok [02.15.14] Systems Settings Check complete Now it is no problem was related to the fact that BDRD is unable to work with VID_00000 while making a full backup but when making a movie only backup it is obviously no problem since it started to reencode it. See the Logs in my last post. Last edited by Rodger; 15th February 2014 at 16:50. |
15th February 2014, 18:01 | #19212 | Link | |
@Rodger
It also doesn't look like the structure of my disc matches yours... probably because they are different regions. I notice that you are using the alpha version of AVISYNTH v2.6 -- which is not recommended for BD-RB. But... AVISYNTH isn't involved in the extraction of audio/subs, so I'll ignore that for now. Do you have a copy of the AUD_00000.META file from the full backup attempt? I'd like to see if it has any anomalies. In fact, it might be useful to compare that file from both of the two attempts. Last edited by jdobbs; 15th February 2014 at 18:10. |
15th February 2014, 20:09 | #19214 | Link |
Sorry my bad!
Didnīt read carefully enough I guess You may compare the disc sizes...maybe the different disc releases are already that easy to compare. All requested files in the new zip. + ERROR When BackUp MOVIE ONLY!!! Reencoding does work but final Muxing gives error!!! See files / Logs for Info Since it is globally mentioned... SHOULD I use DGdeNV or am I better off without it when processing BDs with BDRB? MY experience is that AVIsynth 2.6.x is faster than 2.5.8 since I can use the MT tweaked version from SEt in other programs. see here: http://forum.doom9.org/showthread.php?t=148782 + It has been perfectly stable for me Whatīs your opinion on this? /EDIT: STOP!!! Please wait for me to give further Info via PM before waisting your time (anymore) /EDIT: I AM SO EMBARRASSED! And so sorry for waisting your time. There is nothing in the whole world you could do but to tell the idiot (me) to check for enough space left on the harddrive. Last edited by Rodger; 15th February 2014 at 20:36. |
15th February 2014, 20:52 | #19216 | Link |
Thanks for your kind answer
But please give me your opinion on my two questions: SHOULD I use DGdeNV or am I better off without it when processing BDs with BDRB? MY experience is that AVIsynth 2.6.x is faster than 2.5.8 since I can use the MT tweaked version from SEt in other programs. see here: http://forum.doom9.org/showthread.php?t=148782 + It has been perfectly stable for me |
15th February 2014, 20:56 | #19217 | Link | |
There has never been a doubt about your finding and fixing capabilities. |
15th February 2014, 21:05 | #19218 | Link | ||||
This happens, strangely enough, only with BD_Rebuilder currently. After completion appear "00000.clpi" and ".clpi" in CLIPINF folder. same for "00000.mpls" and ".mpls" in the playlist folder. Why this is, I can not see from the bd_rebuilder-log and. Inf unfortunately. Everything looks normal there. Quote:
Maybe the error occurs when BD_rebuilder works with tsMuxeR v2.6.12 together. TsMuxeR solo does not write the additional file. But now no test completed with tsMuxeR v1.10.6 v2.6.11 or to further isolate the error. Last edited by inge70; 15th February 2014 at 21:13. |
15th February 2014, 21:38 | #19219 | Link | |
It's up to you with AVISYNTH, but you'll find I'm very hesitant to respond to bug reports when alpha software is in use that might be the cause, and may require a switch to v2.58 before accepting it as a bug. Last edited by jdobbs; 15th February 2014 at 21:40. |
15th February 2014, 21:42 | #19220 | Link | |
