Old 19th October 2019, 16:15   #57641  |  Link
el Filou
el Filou's Avatar
I use a media center app that never exits even when putting the HTPC to sleep so it frequently runs for a month non-stop between Windows updates, and I've never had a problem with system or graphics memory leaks when using madVR with it. I have a very different software setup though.
@Blight Have you tested other players just to check if the same thing happens with them too or if it's just with ZoomPlayer?
Old 22nd October 2019, 10:07   #57642  |  Link
mclingo
I havent been following the other HDR thread, out of interest has there been any news on the next MADVR update, V1.0, I thought it was coming soon.
Old 22nd October 2019, 10:55   #57643  |  Link
SamuriHL
SamuriHL's Avatar
I very much doubt it'll be soon but they're still working on tone mapping. And making huge gains.
Sent from my SM-G975U using Tapatalk
Old 22nd October 2019, 12:57   #57644  |  Link
BetA13
cosmic entity
BetA13's Avatar
@Blight
i also have Windows 7 (fully patched) and using an gtx670 with 2gb Vram and i didnt notice those issues..
Since we have both win7 and a 2gb GFX Card, im offering my help for any testing if needed..
Best Regards, BeTa
BetA13 is offline   Reply With Quote
Old 22nd October 2019, 14:53   #57645  |  Link
Siso
Soul Seeker
Siso's Avatar
Does anyone encountered an issue - madvr detects the monitor as new, after each restart. I have to point the 3dlut path everytime, and to choose the display as a digital monitor.
Old 22nd October 2019, 15:29   #57646  |  Link
Manni
I had a similar issue with build 1806 that went away when I upgraded windows to build 1903. That's with the latest nVidia driver and the latest madVR test build. If you bring everything back in time it should work again
Win11 Pro x64 b23H2
madVR/LAV/jRiver/MyMovies/CMC
Old 22nd October 2019, 15:35   #57647  |  Link
Siso
Soul Seeker
Siso's Avatar
I'm on windows 7 ultimate 64 bit. Video drivers 385.28.
Old 22nd October 2019, 15:45   #57648  |  Link
Manni
No idea then, unless you're using more than one monitor, which can cause similar issues.
Win11 Pro x64 b23H2
Old 22nd October 2019, 15:48   #57649  |  Link
mclingo
I was hoping MADHI would at some point soon start looking into to better compression / streaming artefact algos to help with poorly compressed streamed material and some poorly mastered blurays, there hasnt been a major dev on anything but tone mapping for ages.
Old 22nd October 2019, 16:13   #57650  |  Link
what's wrong with the current ones?
that's the usual way things happen here he finished something after month -years of worl and then it is like this for a long time.
the best way to change madshi mind is to proof there is something wrong with the current implementation that was done countless times in the past and is done right now with tone mapping.
tone mapping work will not change anytime soon a product he works on is supposed to be shipped in this year.
Old 22nd October 2019, 17:25   #57651  |  Link
Siso
Soul Seeker
Siso's Avatar
Only one monitor and that's all. I'm thinking it might be happening after shutdown of the pc, tried with restart again and it was ok, I'll test with shutdown again later.
Old 22nd October 2019, 17:29   #57652  |  Link
mclingo
The current algos are great with light banding, no issues there are all, these can stay as they are. Howeve they are not suitable for near black macro blocking and other near black issues because the algo works on the entire picture so if you have to go heavy to deal with really bad near black issues it destroys the rest of the image.
We really need something that just works at near black, lighter areas of the picture dont get compressed as much and tend to look ok.
The final game of thrones seaon is a good example, it was totally unwatchable at times on OLED but it wasnt much better on high end LCD's either.
An example bluray is Snowpeircer, here is a clip, its all kinds of awful.
https://1drv.ms/v/s!AgvFafeelEBijd4j...KfkWw?e=8p04yS
Old 22nd October 2019, 18:08   #57653  |  Link
a blu ray encoded with 1 ref frame and 11 mbit combined with 32 kbit mono AAC and cropped?
why do i even get a feeling this is CBR encoded from someone that has ittle to no clue what they are doing which will make dark scenes even worse.
Old 22nd October 2019, 19:11   #57654  |  Link
mclingo
yes its a quck and dirty rip, but hey, why not throw in a totally unnecessary insult , that always helps doesnt it....
its looks identical to the bluray which I also have.
Old 22nd October 2019, 19:19   #57655  |  Link
mclingo
bluray
https://1drv.ms/u/s!AgvFafeelEBij5kH...K6NKg?e=BWDUzW
dirty rip
https://1drv.ms/u/s!AgvFafeelEBij5kG...uDFtA?e=xBYcGQ
Old 22nd October 2019, 19:27   #57656  |  Link
so having little to no clue what someone is doing in something like this is an insult?
an tool like mkvtoolkit can cut files without any reencoding and it should be faster too.
Old 22nd October 2019, 19:38   #57657  |  Link
can you plz make sure it is the same frame. you can navigate per frame by using control + arrow key left right in mpc-HC.
both are still cropped and that's not allowed on a blu ray.
BTW. you don't have to provide a sample from a blu ray your reencode is fine too but you should specify that because if you don't the first question should be if the encoded is bad because it is not a blu ray so a problem with an reencode.
edit: plz lossless images like png we want to judge rendered images not images that are again compressed.
Old 22nd October 2019, 19:43   #57658  |  Link
mclingo
you've pointed out a percieved inadequcy with a clip ive posted which turned out to be wrong, the clip was perfectly adequate for the intented purpose as you can see in the screen shots, therefore I knew exactly what I was doing when I made it several years ago, if I made it again now, it might be different but its totally fine.
But that isnt really the problem, its your abraisive manner, you could have simply said " are you sure that clip is a good enough representation of the bluray", but no, you want straight into accuse mode.
Do you even know when you are being abraisive, are you deliberately trying to wind people up or is there a language barrier here?
Old 22nd October 2019, 19:47   #57659  |  Link
you just posted jpg of different frames.
so again you have no clue what you are doing good day sir.
Old 22nd October 2019, 20:14   #57660  |  Link
mclingo
it should be clear to everyone that the compression artefacts are so bad that its irrelvant that they dont share the same frame, this was meant as a comparison shot to show that the clip was close enough to the bluray.
stop being so petty and puerile.
