27th August 2019, 17:40 | #441 | Link |
Maybe my workaround package from this link is for you:
https://forum.doom9.org/showthread.p...31#post1881431 Maybe you can even help me to make it more "universal", that means working under more local Windows versions. When you mix an older MKVToolnix GUI with newer CLI versions, Toolnix will pop up a warning. My package clicks aways this warning, but for this to work it needs a substring which is part of the warning window title. I started with "Problem" as the substring to look for, but I later changed it to "robl" because the "P" can be lowercase or uppercase depending on the language, and the "e" character is different in French (it has an accent grave). You did not say where you come from, can you test it and tell me what the window title of this warning message is for you? Cheers manolito |
29th August 2019, 16:20 | #442 | Link | |
MKVToolNix author
Feel free to compile the package yourself. I cannot tell you if a Pi4 has enough resources for that, though.
Latest MKVToolNix is v83.0 If I ever ask you to upload something, please use my file server. |
29th August 2019, 17:46 | #443 | Link | |
https://flatpak.org/setup/Raspbian/
29th August 2019, 21:15 | #444 | Link |
MKVToolNix author
Oh right, the Flatpak! I totally forgot about that. Thanks for thinking of it.
3rd September 2019, 23:11 | #445 | Link |
Would it be okay to bundle the MKVToolNix command line tools in my Inviska MKV Extract AppImage?
It seems more people are using the MKVToolNix Snap and AppImage, which Inviska MKV Extract won't work with. After being contacted a few times asking how to get it working, I started to think it would be better to include the MKVToolNix command line tools in my AppImage, but I didn't know if this would be okay with you. Would you have any problems with me bundling the MKVToolNix command line tools in my AppImage? Edit: I just released a new version with the MKVToolNix command-land tools bundled in the AppImage. If this is a problem I can delete it and do another release without the tools included. Last edited by Inviska; 9th September 2019 at 19:16. |
5th September 2019, 21:01 | #446 | Link |
Hello, first I apologize if this is not the right place to post beginner questions. If not, please indicate the right place.
But if my question can be answered in this topic, here it goes: For many years I have been using MKVToolNix-gui under Windows. I also used a gui to extract .MKV files. The interface for extract, if I'm not mistaken, was not installed. I just copied .DLL and .EXE files to the same folder where MKVToolNix-gui had installed itself and created a link to .EXE on the desktop. Even so, I never clicked on the extract. I directly clicked on the .MKV file and from the context menu chose to open it with the extract. But now I'm using Linux Mint. I am new to Linux although I worked from 1978 until a few years ago as a COBOL mainframe computer programmer (IBM / 370, 4341 etc.). That is, all my knowledge today is obsolete, maybe useless, but maybe I can recognize a command line, for example. Well, using the Linux Mint Application Manager (19.2), I found MKVToolNix-gui, installed it and it is working fine. But I don't know how to update it or how to install the gui for MKVExtract (or something). I read the page at "https://mkvtoolnix.download/downloads.html#ubuntu", copied and pasted the following lines into Terminal: 1 - wget -q -O - https://mkvtoolnix.download/gpg-pub-moritzbunkus.txt | sudo apt-key add - 2 - /etc/apt/sources.list.d/mkvtoolnix.download.list 3 - deb https://mkvtoolnix.download/ubuntu/ bionic main 4 - deb-src https://mkvtoolnix.download/ubuntu/ bionic main Only the first line worked but the others... I have the impression that "wget" is a command, that the second line is a file but I don't know what the third and fourth line are. Anyway, to avoid bothering you, I would like you to help me upgrade MKVToolNix-gui (installed version is 19 but the program asks me to upgrade to 37) and install gMKVExtract (I think it was This is the program but I may be wrong). As I said before, I apologize for the difficulty and although I want to know at least the basics of Linux, in this message, if you can help me just install and update the MKV programs I would be very grateful. |
6th September 2019, 01:07 | #447 | Link |
On Ubuntu (presumably any Debian variant, but I dunno for sure), after running the wget piping command, do
sudo add-apt-repository "deb https://mkvtoolnix.download/ubuntu/ bionic main" Which will perform the requisite steps to add that to the sources and update the lists. This avoids having to make the user muddle around in config files. |
7th September 2019, 23:09 | #448 | Link | |
And a last question: I'd like to do what I did under Windows: right-click in the .MKV file then the option to open it with gMKVExtract Gui. I did that way because in the first time I try to open a .MKV file, I choose the .EXE in a folder. Now I don't know neither where or which file I have to point to open with an extract gui. |
10th September 2019, 17:53 | #449 | Link | |
MKVToolNix author
That being said: MKVToolNix is licensed under the GPLv2. This allows you to do a lot of things wit the software, including re-distributing it either on its own or as part of a larger package. The website ChooseALicense.com contains a nice & concise list of things you may do & things you must do. Here's the list of things you must do and my additional information about it:
Basically it's really easy, especially if you only distribute an unmodified copy of MKVToolNix. In that case include the license & README & point to them in your package's own documentation as described in point 2, and you'll be good to go.
10th September 2019, 18:01 | #450 | Link | |
MKVToolNix author
Now: you're correct that "wget" is a command. It's used to download files from the internet. In this case, the whole command downloads a file from my web server with "wget" and feeds the file directly to a second command, "apt-key". What's downloaded is the GPG key that's used to cryptographically sign the locations where you will later download MKVToolNix from. That GPG key is fed to "apt-key", which installs that key as a trusted key for this type of operation (downloading & installing software from locations that are signed with that key). The second line is indeed the name of a file which you must create. Lines three & four are the content you should place in said file. That file will configure the location where to download MKVToolNix from. That location is the one that's signed with the GPG key downloaded in step 1. What qtyo27 posted is an alternative to creating that file manually. It runs another command, "add-apt-repository", which will create that file for you if it doesn't exist already and add the location information to it. It's slightly easier to use, but not available everywhere, which is why I'm not mentioning it on my web site. That's something that has nothing to do with MKVToolNix. In fact, it has everything to do with the desktop environment you're using (on Linux there are tons of different desktop environments out there, unlike Windows where there's basically only one: Window's own). You should ask such a question on one of Linux Mint's forums. You'll likely have much better luck getting an answer there than here (e.g. I cannot answer your question as (1) I don't know which desktop environment Linux Mint uses by default as there are two or three possibilities and (2) even if I did, I only know how to do it in KDE/Plasma, and that's definitely not what Linux Mint is using).
11th September 2019, 02:42 | #451 | Link | |
I've uploaded a new version of the AppImage with MKVToolNix removed. Thanks a lot for the information about my obligations under the GPLv2 licence. For now I won't bundle MKVToolNix and will see how things progress. If Snaps and FlatPaks start to take off more I might have to include it, in which case I'll follow your instructions so it's done properly. Again, sorry for uploading the other version without waiting for your response. |
11th September 2019, 17:04 | #452 | Link |
MKVToolNix author
No problem; I'm not mad or something
13th September 2019, 08:21 | #453 | Link |
I am putting together a new PC build that will also be used for working with mkvtoolnix. Is there a benefit to using an Intel processor with more cores/threads in that machine with regard to processing times with mkvtoolnix?
I would get a k-processor with at least 4 cores anyhow but there is also the option to go up to 6 or 8 cores and the question whether it makes much of a difference to go for a processor with hyperthreading - seems that hyperthreading increases temperature substantially and due to that it limits maximum stable overclock. |
13th September 2019, 09:33 | #454 | Link |
mkvmerge is single-threaded and usually not CPU-bound, so hyperthreading doesn't really matter. The only thing against AMD that I can think of are recent bugs that resulted in crashes, but they seem to have been fixed already and when you buy a new one, you should already get the fix (see here).
17th September 2019, 06:10 | #457 | Link |
Does mkvextract support long paths on Win 10? First test showed it doesn't, might as well be an issue in staxrip though.
23rd September 2019, 17:14 | #458 | Link |
I had written some code which could detect the stretching that worked with some old mkvinfo version, but since I used it last a bunch of stuff must have changed with the output of mkvinfo, so that code doesn't work any more.
So before I start to try to figure out what that code really indented to do and how it would need to be adjusted I wonder: Is there an 'easy' way to detect whether an mkv contains a, by mkvtoolnix, strechted stream and by how much the stream was stretched (so that one can take the stretch into account when remuxing/reencoding such a file into another container)? Cu Selur |
23rd September 2019, 18:09 | #459 | Link |
There is no one field you can just read. For video tracks you could look into the bitstream (e.g. AVC or HEVC time_scale and num_units_in_ticks). For audio tracks you could see whether the frames overlap or have gaps i.e. if [number of frames]*[duration of one single frame] matches the duration in the container. If you are lucky maybe by reading the DefaultDuration and comparing it to the frame size (if frame sizes for the given codec are constant, and if DefaultDuration is set in the first place). Without track statistic tags this potentially involves a lot of parsing. For subtitles it may be impossible (maybe one can find a pattern in the roundings?).
Are you sure your app was able to do such things? Last edited by sneaker_ger; 23rd September 2019 at 18:18. |
23rd September 2019, 19:33 | #460 | Link | ||
a. get the mkvinfo output b. for each stream (only audio&video) collect it's raw length and the length in the container c. compare raw and container size Cu Selur |
matroska |
