24th April 2019, 18:59 | #55921 | Link | |
And if you have a 2160p TV, there shouldn't be any resolution loss either. |
24th April 2019, 21:19 | #55924 | Link | |
24th April 2019, 21:55 | #55925 | Link | |
But I think I have found the culprit. So when using madvr with mpc-hc I set LAV to D3D11 native. But I noticed when I use EVR LAV settings are different. So does anyone know if Madvr and EVR carry their own unique settings for LAV? And as a side note why do I not receive email notifications from my subscribed threads on this forum? I set all to "instant"
3700X - RTX2070 - 970EVO - EVGA Supernova 750W Gold - Sony KD55X720E |
25th April 2019, 03:58 | #55928 | Link | |
I change something in settings and it works, then doesnt. Then it will just work on its own. Totally random. Frustrated.
25th April 2019, 08:24 | #55930 | Link | |
You can find the latest 3DVision drivers in this location: C:\Program Files\NVIDIA Corporation\Installer2\Display.3DVision.{......................................} Inside that folder there is "3DVision.exe" file that you can right click and extract with WinRAR. After extracting you will find the all the 3DVision installation files. Code:
[3D Vision Experience] <DIR> 09/04/2019 14:57 -a- [amd64] <DIR> 09/04/2019 14:46 -a- layout.bin 491 09/04/2019 14:55 -a- data1.cab 6,223,040 09/04/2019 14:55 -a- data2.cab 512 09/04/2019 14:55 -a- _setup.dll 335,672 09/04/2019 14:57 -a- ISSetup.dll 551,920 09/04/2019 14:57 -a- npnv3dv.dll 808,488 09/04/2019 14:55 -a- npnv3dvstreaming.dll 293,632 09/04/2019 14:56 -a- Nv3DVisionIePlugin.dll 274,176 09/04/2019 14:56 -a- Nv3DVisionIePlugin64.dll 326,400 09/04/2019 14:56 -a- Nv3DVStreaming.dll 141,808 09/04/2019 14:56 -a- Nv3DVStreaming64.dll 171,776 09/04/2019 14:56 -a- Nv3DVStreamingIePlugin.dll 198,920 09/04/2019 14:56 -a- Nv3DVStreamingIePlugin64.dll 169,784 09/04/2019 14:56 -a- nvImage.dll 1,028,680 09/04/2019 14:56 -a- nvImage64.dll 1,333,832 09/04/2019 14:56 -a- NvSCPAPI.dll 649,288 09/04/2019 14:56 -a- NvSCPAPI64.dll 738,888 09/04/2019 14:56 -a- nvstapisvr.dll 378,952 09/04/2019 14:56 -a- nvstapisvr64.dll 413,768 09/04/2019 14:56 -a- nvStereoApiI.dll 329,800 09/04/2019 14:56 -a- nvStereoApiI64.dll 380,728 09/04/2019 14:56 -a- NvStRes.dll 3,745,592 09/04/2019 14:56 -a- NvStRes64.dll 3,636,024 09/04/2019 14:56 -a- NvStWizRes.dll 7,380,792 09/04/2019 14:56 -a- nvwl.dll 117,048 09/04/2019 14:56 -a- nvwl64.dll 130,872 09/04/2019 14:56 -a- NvStereoUtilityOGL.exe 1,146,440 09/04/2019 14:56 -a- nvStInst.exe 407,112 09/04/2019 14:56 -a- nvstlink.exe 2,373,704 09/04/2019 14:56 -a- nvStreaming.exe 141,384 09/04/2019 14:56 -a- nvStReg.exe 819,272 09/04/2019 14:56 -a- NvStTest.exe 2,754,360 09/04/2019 14:56 -a- NvStView.exe 4,403,000 09/04/2019 14:56 -a- NvStWiz.exe 442,680 09/04/2019 14:56 -a- setup.exe 388,464 09/04/2019 14:57 -a- data1.hdr 28,868 09/04/2019 14:55 -a- NVSTEREO.INF 7,405 22/03/2019 19:35 -a- nvTimings.ini 107,200 09/04/2019 14:53 -a- setup.ini 841 09/04/2019 14:55 -a- setup.inx 263,759 09/04/2019 14:53 -a- setup.isn 76,009 19/04/2007 05:47 -a- setup.iss 418 22/03/2019 19:35 -a- NvStDef.reg 1,755 22/03/2019 19:35 -a- OGLStReg.reg 10,217 09/04/2019 14:50 -a- 42,122 k in 44 files Edit: Maybe we can use the Windows 10 3D mode API instead of nVidia's one? https://docs.microsoft.com/en-us/win...tereoscopic-3d Can madVR or LAV or MPC-BE use that API instead? . Last edited by FDisk80; 25th April 2019 at 09:30. |
25th April 2019, 10:54 | #55932 | Link |
continue the 3D discussion here, this is what I created it for, its a 3D issue but it affects MADVR playback -
https://forum.doom9.org/showthread.php?t=175769
25th April 2019, 11:02 | #55933 | Link |
My E6 supports both in UHD, but I'm really not into 3D so I haven't looked if any others do, I just assumed since it's such a simple feature when the TV already supports 3D. If it's a rare feature, then it's obviously no solution for most people.
25th April 2019, 12:50 | #55934 | Link |
the E6 was the last gen which suopported 3D on the OLED side, samsung gave up on 3D LED a year before that, I have an EF950 OLED which also supports 3D in UHD mode, you only get 2k though but as all 3D is 1080p thats no issue.
I can even get 3D in HDR mode, but obviously there are no 3D / HDR movies anyway but it works...
26th April 2019, 01:14 | #55938 | Link |
I'm not pushing my luck right now. I've been tinkering away trying to get the best settings for quality with madVR itself without going overboard on the settings. I'm just so happy it stopped stuttering. The frustration that came along with getting this card and have that going on non-stop with no real fix for it.
26th April 2019, 05:02 | #55939 | Link |
Hi, I have a W10, I5, 8gb and RTX 2070. Under this configuration, a 1080 movie in a 4k TV applayng (under chroma and image upsampling) any NGU upsampling options, it sttuters and I think this is not normal. Can this improved if I overclock my card?, what is the best that I can do with my RTX 2070 card?. Thanks in advance for your input.
26th April 2019, 05:31 | #55940 | Link | |
I dont think OCing the card is gonna help much. I have NGU AA on both of those options and it runs.
