Old 24th July 2009, 18:37   #2021  |  Link
kemuri-_9
Compiling Encoder
kemuri-_9's Avatar
i used my compiles of gcc 4.4.1 to compile both x86 and x64 versions of x264 and it works fine.
compiling from the svn can be a dual edged sword - bugs are likely to appear as other ones are fixed,
this is why i only use official releases now.
(plus it saves time from building from weekly snaps and such)
custom x264 builds & patches | F@H | My Specs
kemuri-_9 is offline   Reply With Quote
Old 26th July 2009, 10:35   #2022  |  Link
Audionut
Subme10
http://git.videolan.org/?p=x264.git;...d2a394b2a2b713
http://www.7-zip.org/
Audionut is offline   Reply With Quote
Old 26th July 2009, 13:58   #2023  |  Link
Tarutaru
A deadly Taru!
Tarutaru's Avatar
x264.0.68.1189M.x86.exe
* patch -p1 < x264_hrd_pulldown.14_interlace.diff
* patch -p1 < x264_win_zone_parse_fix_05.diff
* pthread, gpac
* fprofiled, -msse4.2, -march=native(core i7)
Tarutaru is offline   Reply With Quote
Old 26th July 2009, 14:44   #2024  |  Link
JEEB
もこたんインしたお!
JEEB's Avatar
x264 r1189 32bit
download ; release notes
  • built on Jul 26 2009, gcc: 4.3.4 20090220 (prerelease) (x32.generic.Komisar)
  • fprofiled, -march=i686
x264 r1189 64bit
  • built on Jul 26 2009, gcc: 4.3.4 20090220 (prerelease) (x64.generic.Komisar)
  • fprofiled, -march=core2
patched with:
  • x264_win_zone_parse_fix_05.diff
  • x264_hrd_pulldown.14_interlace.diff
[I'm human, no debug]
Old 27th July 2009, 14:01   #2025  |  Link
imk
|ン、)
imk's Avatar
x264-r1190M-imk-win.7z
win_build_info.txt
imk is offline   Reply With Quote
Old 27th July 2009, 15:20   #2026  |  Link
bob0r
Pain and suffering
bob0r's Avatar
Need someone who can compile x264 64bit fprofiled from GIT (no patches), gcc prefered.
Techouse seems very busy.
If you can provide this please host it on a http host (i can provide if needed):
http://yourhost.com/whatever/revisionXXXX/x264.exe
Like that.
Also include:
md5sum x264.exe | awk '{print $1}' >x264.md5
please, thats the file i use and check for updates.
( http://yourhost.com/whatever/revisionXXXX/x264.md5 )
If you can provide this please post for me x264.exe --version, so i can update x264.nl
Maybe JEEB?
bob0r is offline   Reply With Quote
Old 27th July 2009, 18:10   #2027  |  Link
juGGaKNot
juGGaKNot's Avatar
Originally Posted by JEEB View Post
x264 r1189 32bit
x264 r1189 64bit
patched with:
Was autovaq commited or still diff ?
A subme 10 build with autovaq ?
juGGaKNot is offline   Reply With Quote
Old 27th July 2009, 18:13   #2028  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
Yes. Look at the GIT
http://git.videolan.org/gitweb.cgi?p...5752da9f2cd032
You don't need a "SubME 10" build. SubME=10 is available in all regular builds (r1187 and later). Note that it requires Trellis=2.
Old 27th July 2009, 19:41   #2029  |  Link
juGGaKNot
juGGaKNot's Avatar
subme 10 + autovaq ( that is if autovaq was not commited )
anyway tested, guess this means death to deathzones.
will the --preset be edited so that subme 10 is on @ slower and placebo ?
Old 27th July 2009, 19:53   #2030  |  Link
LoRd_MuldeR
Software Developer
That is what you get with "--aq-mode 2" + "--trellis 2" + "--subme 10" using a standard (unpatched) build.
The "slower" preset uses Trellis=2 + SubMe=9, but "placebo" already uses Trellis=2 + SubMe=10.
I wonder whether SubMe=10 really is a "placebo" setting?
Old 27th July 2009, 20:09   #2031  |  Link
juGGaKNot
juGGaKNot's Avatar
Well yes if its not a diff anymore
What does the zone parse fix do ? now that autovaq is in i can move to a unpatched build.
We will see when subme 11 is out i'm going to use it.
Originally Posted by Dark Shikari View Post
I do not have amps :|
Old 27th July 2009, 20:11   #2032  |  Link
Dark Shikari
x264 developer
Dark Shikari's Avatar
Does that mean it's any louder?
Old 27th July 2009, 20:38   #2033  |  Link
LoRd_MuldeR
Software Developer
As said before, AutoVAQ is committed
See this post:
http://forum.doom9.org/showpost.php?...92&postcount=7
You don't need to have an amp at home to understand the joke
Old 27th July 2009, 21:45   #2034  |  Link
Selur
Selur's Avatar
not before hrd_pulldown_interlace get's stable and finds it way into the maintree
Old 27th July 2009, 22:24   #2035  |  Link
JEEB
もこたんインしたお!
JEEB's Avatar
x264 r1190 64bit unpatched:
download ; hash
________________________________________________________________________________
x264 r1190 32bit
  • built on Jul 28 2009, gcc: 4.3.4 20090220 (prerelease) (x32.generic.Komisar)
x264 r1190 64bit
  • built on Jul 28 2009, gcc: 4.3.4 20090220 (prerelease) (x64.generic.Komisar)
patched with:
  • x264_hrd_pulldown.15_interlace.diff
Old 28th July 2009, 05:04   #2036  |  Link
XhmikosR
Using JEEB's builds, r1190, r1189 and r1184 I get the following when x264 crashes:
avis [info]: 1280x720 @ 23.98 fps (1442 frames)
Assertion failed: dpb_output_delay < pow( 2, sps->vui.nal_hrd_parameters.i_dpb_o
utput_delay_length ), file encoder/set.c, line 643
This application has requested the Runtime to terminate it in an unusual way.
Please contact the application's support team for more information.
cmd used:
x264 --profile high --slow-firstpass --pass 1 --quiet --bitrate 5000 --stats "1.stats" --level 4.1 --keyint 24 --min-keyint 1 --ref 1 --no-mixed-refs --bframes 3 --no-weightb --direct auto --chroma-qp-offset 0 --subme 1 --trellis 0 --analyse none --no-8x8dct --ipratio 1.1 --pbratio 1.1 --vbv-bufsize 50000 --vbv-maxrate 50000 --qcomp 0.5 --me dia --threads auto --thread-input --sar 1:1 --output NUL "test.avs" --mvrange 511 --aud --nal-hrd
If I use imk's build r1190 everything is fine.
XhmikosR is offline   Reply With Quote
Old 28th July 2009, 05:10   #2037  |  Link
Dark Shikari
x264 developer
Note where it terminates. It's a bug in the nal-hrd patch.
Old 28th July 2009, 05:15   #2038  |  Link
XhmikosR
Yes, but the odd thing is that the same script, same cmd, same patches used, all the same, only the compiler is different, with imk's build I get no crashes. Anyway, I didn't know where else to report it. I hope it gets fixed.
Old 28th July 2009, 05:52   #2039  |  Link
Trahald
Wewkiee
Trahald's Avatar
thats why i put the assert in there rather the encoder die than a decoder down the line. (because w/out the assert the encode would have completed). will have a patch out shortly.
...yeah...but...why on earth would I compare apples with apples?
Trahald is offline   Reply With Quote
Old 28th July 2009, 06:42   #2040  |  Link
Trahald
Wewkiee
Trahald's Avatar
Hrd 15.
h.264, x264, x264 builds, x264 patches, x264 unofficial builds
