14th January 2014, 00:30 | #18821 | Link | |
FRIMDecode.exe -i::mvc 00098.track_4113.264 00098.track_4114.mvc -tab -o - | x264.exe - --demuxer raw --sar 1:1 --crf 18 --input-res 1920x2160 --sar 1:1 --video-filter resize:width=1920,height=1080,sar=1:1,method=bilinear --fps 23.976 --output "C:\temp\FRIMtox264-OU.h264" |
14th January 2014, 00:57 | #18822 | Link |
Ok, commencing test sequence. I will start with avatar and see how it comes out.
If you fail to plan; you plan to fail, would you not agree? Think about it. Last edited by HWK; 14th January 2014 at 01:04. |
14th January 2014, 01:04 | #18823 | Link | |
14th January 2014, 01:13 | #18824 | Link |
Thanks, after close examination I realized as long as we have Vc-1 ffdshow is going nowhere, unless jdobbs is also working on developing decoder for all supported formats.
If you fail to plan; you plan to fail, would you not agree? Think about it. Last edited by HWK; 14th January 2014 at 01:20. |
14th January 2014, 01:59 | #18825 | Link | |
One other limitation of feeding X264 directly is that, even though you can resize internally, there aren't any common releases that include the ability to pad -- so some of BD-RB's features (like resizing 4:3 into a 16:9 window) might still need AVISYNTH. I'm looking for a workaround. There are patches that filter, so I guess I could always start creating my own builds. I just hate to do that. |
14th January 2014, 02:25 | #18826 | Link | |
14th January 2014, 02:37 | #18827 | Link | |
1. Max bitrate allowed is up to 60000, you have set 35000 isn't that low for both views combined. 2. Tsmuxer is extracting all subtitle from disc, even though option of having one was selected in BD-RB. 3. What does MKV have to do with this according VID_00001 file #Created by BD Rebuilder - v0.46.03 (beta) DirectshowSource("E:\BD_OUT\WORKFILES\00001.track_4113.mkv", fps=23.976, framecount=232608, ConvertFPS=true, audio=false) ConvertToYV12().AssumeFPS(24000,1001)
If you fail to plan; you plan to fail, would you not agree? Think about it. Last edited by HWK; 14th January 2014 at 03:22. |
14th January 2014, 02:58 | #18828 | Link | |
14th January 2014, 03:03 | #18829 | Link | |
Frim quality scale goes from 1-7, 1 highest quality and 7 optimized for speed and 4 is balanced. As a result when you change quality setting BD-RB automatically set scale in encoder to predetermined value.
If you fail to plan; you plan to fail, would you not agree? Think about it. Last edited by HWK; 14th January 2014 at 03:25. |
14th January 2014, 06:28 | #18831 | Link | |
14th January 2014, 15:36 | #18833 | Link | |
Acerjen |
14th January 2014, 16:40 | #18834 | Link | |
14th January 2014, 17:10 | #18835 | Link | |
14th January 2014, 18:45 | #18837 | Link |
Jdobbs, Can you also check why BD-RB is extracting all subtitle stream (6) in case of avatar. Even though I want English only in final output. This one doesn't include one with 80mb + size.
14th January 2014, 18:58 | #18839 | Link |
Another update. After having success with a rebuild of Hugo 3D to BD-25, I retried a rebuild to BD-9. The video encode failed on three separate attempts. This may not have anything to do with the failures, but BD-Rebuilder Priority was set on idle and I was doing other CPU/GPU intensive things on the PC while the rebuild was happening (i.e. playing Civilization 5). The reason I mention this is that when I ran two BD-9 rebuilds of the same movie with different quality settings in batch mode overnight, they both completed successfully. I usually run rebuilds in the background while doing other things on the PC without an issue.
14th January 2014, 19:02 | #18840 | Link |
Hmm, interesting find. So it seems OS is having difficulty locating CPU time to applications or it would seem so with game. What is even more interesting is I am gamer as well and never came across such a thing.
