9th September 2009, 03:59 | #5081 | Link | |
I don't use .NET because I don't want to use .NET. It may cause a couple of headaches and I have to actually write code to fix it, but in the long run its worth it to me. Last edited by jdobbs; 9th September 2009 at 04:18. |
9th September 2009, 04:07 | #5082 | Link | |
I think it was a typo. |
9th September 2009, 04:11 | #5083 | Link |
lol actually i was half asleep when doing that post. no im using bdrebuilder and its the stargate blu-ray not dvd sorry guys. however i have used dvd rebuilder for ages now. but ive done a few blu-ray backups first time i have this issue. ill try again and post the log file afterwards.
9th September 2009, 04:48 | #5084 | Link |
@Jdobbs
Is it conceivable that perhaps something in the Windows Updates might be what's throwing BDRB for a loop? I always keep my system as current as the OS allows, but I'm aware of several people (my wife included) who stick to the "why improve what ain't broke?" philosophy, and keep automatic updates turned off. This might explain why some of us report what others (using what on a forum appears to be similiar systems) don't have any issue whatsoever with. I'm more than happy to supply whatever information you feel might help. In all honesty, I don't recall a single hicup on Windows 7 X64 while I used it (after, of course, tweaking the directshow setting to allow FFdshow to run as it should). The only reason I've reinstalled XP X64 is that my Windows 7 Upgrade disk will be showing up in another month, and I needed something to upgrade FROM to install it. If it means anything to you... the Braveheart disk works. It fails to show the menu buttons on PowerDVD9 (which is installed on the same system that's running Windows XP X64), but on Arcsoft TotalMedia Theatre (which is on my HTPC), it's fine. Leaving it alone resulted in a very good BD9 copy--better than I expected with such a long movie.
Isn't it a bit unnerving that doctors call what they do "practice?" --George Carlin |
9th September 2009, 09:23 | #5085 | Link | |
9th September 2009, 09:57 | #5086 | Link | |
To all Windows 7 users (like me): Could you guys please be so kind and tell me what decoders you use for BD Rebuilder in Win7 for H.264 and VC-1 and what your experiences are so far? I've tried Win7's own (Microsoft) H.264 decoder so far with very good results. And for VC-1 movies I'm not sure yet if I should use WMP9 or libavcodec (of course I deleted the 'prefered' folder in the registry, otherwise VC-1 won't work). I'm not even sure which VC-1 decoder is used when I select WMP9 in ffdshow. Is the most up-to-date MS decoder (WMP12?) used or is it really the 'old' WMP9 decoder like it says? |
9th September 2009, 11:41 | #5087 | Link | |
I use windows 7 x64. regards |
9th September 2009, 13:37 | #5089 | Link |
I've been using BD Rebuilder for a few months now, but with the dutch retail of Pinocchio I came across an error that I haven't seen in the forum. I hope someone can help. My OS is win7, all drives are NTFS. I used all quality settings and the new version (and two previous ones as well). The error message is as follows: ----------------------- [17:10:27] BD Rebuilder v0.29.01 (beta) - Source: PINOCCHIO_GBR_D1 - Input BD size: 31,82 GB - Approximate total content: [01:52:11.558] - Target BD size: 22,46 GB [17:10:27] PHASE ONE, Encoding - [17:10:27] Extracting A/V streams [VID_00001] - [17:27:21] Reencoding: VID_00001 (1 of 18) - [17:27:21] Reencoding secondary video [TRK_02] - [17:33:36] Collecting video information - Video: 1920x1080, 23,976fps, 126.216 frames - Bitrate: 16.246 Kbs - [17:33:36] Reencoding: VID_00001, Pass 1 of 2 - [19:01:00] Reencoding: VID_00001, Pass 2 of 2 - [22:05:52] Video Encode complete - [22:05:52] Reencoding audio tracks (if req'd) - [22:05:52] Multiplexing M2TS - Error in attempt to multiplex: MUX_00001.meta - Pes packet len too large ( >100Mb). Bad stream or invalid codec speciffed. [22:06:58] - Failed to build structure, aborted Thanks for any insights on this issue. |
9th September 2009, 14:03 | #5090 | Link | |
9th September 2009, 14:27 | #5091 | Link |
Hello - I saw some of the posts about the dreaded
'GUI issue, no hWnd returned' I recieved it in version 0.29.03 and in 0.29.02. Been using the program since the begining and never saw this error before. I did see where you made a fix for this in the latest version so I wanted to share this log. ----------------------- [01:13:37] BD Rebuilder v0.29.03 (beta) - Source: FAST_AND_FURIOUS - Input BD size: 43.94 GB - Approximate total content: [04:05:13.498] - Target BD size: 22.46 GB [01:13:49] PHASE ONE, Encoding - [01:13:49] Extracting A/V streams [VID_00238] - [01:13:49] Reencoding: VID_00238 (1 of 35) - [01:13:57] Extracting A/V streams [VID_00236] - [01:13:57] Reencoding: VID_00236 (2 of 35) - [01:14:04] Extracting A/V streams [VID_00237] - [01:14:05] Reencoding: VID_00237 (3 of 35) - [01:14:12] Extracting A/V streams [VID_00078] - [01:14:13] Reencoding: VID_00078 (4 of 35) - [01:14:56] Extracting A/V streams [VID_00061] - [01:14:59] Reencoding: VID_00061 (5 of 35) - [01:15:45] Extracting A/V streams [VID_00050] - [01:15:47] Reencoding: VID_00050 (6 of 35) - [01:16:41] Extracting A/V streams [VID_00062] - [01:16:44] Reencoding: VID_00062 (7 of 35) - [01:17:41] Extracting A/V streams [VID_00064] - [01:17:44] Reencoding: VID_00064 (8 of 35) - [01:18:55] Extracting A/V streams [VID_00212] - [01:19:00] Reencoding: VID_00212 (9 of 35) - [01:19:58] Extracting A/V streams [VID_00214] - [01:20:02] Reencoding: VID_00214 (10 of 35) - [01:21:32] Extracting A/V streams [VID_00225] - [01:21:45] Reencoding: VID_00225 (11 of 35) - [01:22:55] Extracting A/V streams [VID_00202] - [01:23:02] Reencoding: VID_00202 (12 of 35) - [01:24:37] Extracting A/V streams [VID_00215] - [01:24:42] Reencoding: VID_00215 (13 of 35) - [01:26:57] Extracting A/V streams [VID_00228] - [01:27:17] Reencoding: VID_00228 (14 of 35) - [01:29:03] Extracting A/V streams [VID_00216] - [01:29:11] Reencoding: VID_00216 (15 of 35) - [01:31:29] Extracting A/V streams [VID_00221] - [01:31:51] Reencoding: VID_00221 (16 of 35) - [01:33:49] Extracting A/V streams [VID_00217] - [01:34:12] Reencoding: VID_00217 (17 of 35) - [01:36:25] Extracting A/V streams [VID_00224] - [01:36:47] Reencoding: VID_00224 (18 of 35) - [01:38:46] Extracting A/V streams [VID_00223] - [01:39:15] Reencoding: VID_00223 (19 of 35) - [01:41:16] Extracting A/V streams [VID_00220] - [01:41:40] Reencoding: VID_00220 (20 of 35) - [01:43:43] Extracting A/V streams [VID_00226] - [01:44:05] Reencoding: VID_00226 (21 of 35) - [01:46:13] Extracting A/V streams [VID_00211] - [01:46:48] Reencoding: VID_00211 (22 of 35) - [01:49:00] Extracting A/V streams [VID_00219] - [01:49:25] Reencoding: VID_00219 (23 of 35) - [01:52:06] Extracting A/V streams [VID_00207] - [01:52:42] Reencoding: VID_00207 (24 of 35) - [01:55:34] Extracting A/V streams [VID_00011] - [01:56:07] Reencoding: VID_00011 (25 of 35) - [02:00:03] Extracting A/V streams [VID_00205] - [02:00:41] Reencoding: VID_00205 (26 of 35) - [02:04:34] Extracting A/V streams [VID_00204] - [02:05:26] Reencoding: VID_00204 (27 of 35) - [02:10:45] Extracting A/V streams [VID_00227] - [02:11:56] Reencoding: VID_00227 (28 of 35) - [02:17:52] Extracting A/V streams [VID_00222] - [02:18:58] Reencoding: VID_00222 (29 of 35) - [02:25:05] Extracting A/V streams [VID_00218] - [02:26:52] Reencoding: VID_00218 (30 of 35) - [02:27:57] GUI issue, no hWnd returned. - Encode failed. Retrying. - Encode failed. Retrying. - Reached retry limit. Aborting. [02:30:53] - Failed video encode, aborted Using Windows Vista Ultimate 64 bit Encoder settings = Idle/Highest/No One Pass Setup = Color Boost Checked Going to try it with the 0.29.01 version and see if it does it. Last edited by h8t3d1; 9th September 2009 at 15:47. |
9th September 2009, 16:26 | #5092 | Link | |
V_MPEG4/ISO/AVC, "F:\BD25 REENCODES\FULL REENCODE\PINOCCHIO\WORKFILES\VID_00001.AVS.MKV", fps=23.976, track=1, insertSEI, contSPS V_MPEG4/ISO/AVC, "F:\BD25 REENCODES\FULL REENCODE\PINOCCHIO\WORKFILES\VID_00001_2.AVS.MKV", fps=23.976, track=1, secondary, insertSEI, contSPS A_DTS, "F:\BD25 REENCODES\FULL REENCODE\PINOCCHIO\WORKFILES\00001.track_4352.DTS", lang=eng A_DTS, "F:\BD25 REENCODES\FULL REENCODE\PINOCCHIO\WORKFILES\00001.track_4353.DTS", lang=ita A_DTS, "F:\BD25 REENCODES\FULL REENCODE\PINOCCHIO\WORKFILES\00001.track_4354.DTS", lang=spa A_DTS, "F:\BD25 REENCODES\FULL REENCODE\PINOCCHIO\WORKFILES\00001.track_4355.DTS", lang=nld A_AC3, "F:\BD25 REENCODES\FULL REENCODE\PINOCCHIO\WORKFILES\00001.track_4356.AC3", lang=eng A_AC3, "F:\BD25 REENCODES\FULL REENCODE\PINOCCHIO\WORKFILES\00001.track_4357.AC3", lang=ita A_AC3, "F:\BD25 REENCODES\FULL REENCODE\PINOCCHIO\WORKFILES\00001.track_4358.AC3", lang=spa A_AC3, "F:\BD25 REENCODES\FULL REENCODE\PINOCCHIO\WORKFILES\00001.track_4359.AC3", lang=nld S_HDMV/PGS, "F:\BD25 REENCODES\FULL REENCODE\PINOCCHIO\WORKFILES\00001.track_4608.sup", fps=23.976, lang=eng S_HDMV/PGS, "F:\BD25 REENCODES\FULL REENCODE\PINOCCHIO\WORKFILES\00001.track_4609.sup", fps=23.976, lang=eng S_HDMV/PGS, "F:\BD25 REENCODES\FULL REENCODE\PINOCCHIO\WORKFILES\00001.track_4610.sup", fps=23.976, lang=ita S_HDMV/PGS, "F:\BD25 REENCODES\FULL REENCODE\PINOCCHIO\WORKFILES\00001.track_4611.sup", fps=23.976, lang=spa S_HDMV/PGS, "F:\BD25 REENCODES\FULL REENCODE\PINOCCHIO\WORKFILES\00001.track_4612.sup", fps=23.976, lang=nld S_HDMV/PGS, "F:\BD25 REENCODES\FULL REENCODE\PINOCCHIO\WORKFILES\00001.track_4613.sup", fps=23.976, lang=ita S_HDMV/PGS, "F:\BD25 REENCODES\FULL REENCODE\PINOCCHIO\WORKFILES\00001.track_4614.sup", fps=23.976, lang=spa S_HDMV/PGS, "F:\BD25 REENCODES\FULL REENCODE\PINOCCHIO\WORKFILES\00001.track_4615.sup", fps=23.976, lang=nld S_HDMV/PGS, "F:\BD25 REENCODES\FULL REENCODE\PINOCCHIO\WORKFILES\00001.track_4616.sup", fps=23.976, lang=eng S_HDMV/PGS, "F:\BD25 REENCODES\FULL REENCODE\PINOCCHIO\WORKFILES\00001.track_4617.sup", fps=23.976, lang=ita S_HDMV/PGS, "F:\BD25 REENCODES\FULL REENCODE\PINOCCHIO\WORKFILES\00001.track_4618.sup", fps=23.976, lang=spa S_HDMV/PGS, "F:\BD25 REENCODES\FULL REENCODE\PINOCCHIO\WORKFILES\00001.track_4619.sup", fps=23.976, lang=nld S_HDMV/PGS, "F:\BD25 REENCODES\FULL REENCODE\PINOCCHIO\WORKFILES\00001.track_4620.sup", fps=23.976, lang=eng S_HDMV/PGS, "F:\BD25 REENCODES\FULL REENCODE\PINOCCHIO\WORKFILES\00001.track_4621.sup", fps=23.976, lang=ita S_HDMV/PGS, "F:\BD25 REENCODES\FULL REENCODE\PINOCCHIO\WORKFILES\00001.track_4622.sup", fps=23.976, lang=spa S_HDMV/PGS, "F:\BD25 REENCODES\FULL REENCODE\PINOCCHIO\WORKFILES\00001.track_4623.sup", fps=23.976, lang=nld |
9th September 2009, 20:04 | #5093 | Link | |
9th September 2009, 20:44 | #5094 | Link | |
9th September 2009, 22:38 | #5095 | Link |
Could be a playback issue too, e.g. for some reason my Samsung BR player uses 1080p/24 mode for extras that BD rebuilder deinterlaced (1080i->1080p) without keep_interlacing=1. However, the framerate is tagged 29.97 in clipinfo/playlist so it shouldn't actually use 1080p/24. Of course the playback then is jerky. My PS3 is using 1080p(60) mode instead, which looks fine. This is not a field order issue (at least I never had problem with the avisynth/decomb.dll deinterlacing itself) or a bug with bd rebuilder but another reason why I'd like to keep interlacing.
10th September 2009, 01:00 | #5096 | Link |
Artemis Trojan?
Here's an error message I got today from McAfee when I tried to start v2.8.04...
McAfee has automatically blocked and removed a Trojan. About this Trojan Detected: Artemis!2EA64543AD3E (Trojan), Artemis!2EA64543AD3E (Trojan) Location: C:\BD_Rebuilder\BD_Rebuilder.exe Trojans appear as legitimate programs but can damage valuable files, disrupt performance, and allow unauthorized access to your computer.
Phenom II 940 GA-MA790FS-DS5 plus ATI 480 4 x 2 GB Mushkin Windows 7 64-bit 3.5 Terabytes Mass Storage 2 BD Burners, 2 DVD burners Lots of other "Stuff" Last edited by Imperial Zeppelin; 10th September 2009 at 01:04. |
10th September 2009, 01:18 | #5098 | Link | |
10th September 2009, 13:34 | #5099 | Link | |
x264 is somehow "corrupting" interlaced content. To me, this is a HUGE issue! What's the point if you get "right sized" vid that you CAN'T WATCH 'cause it looks like DUMP? Are there any "beta testers" out there with this "Live From Abbey Road" disc that can process it default to BD-25 & see what they get?? |
10th September 2009, 16:16 | #5100 | Link | |
The problem seems to be that BDRB is not deinterlacing to 60fps and then performing interlaced encoding as it should. It's missing out the deinterlacing part so we just get some crappy zig zag video. This is basic stuff! |
