#13282 | Link |
![]() Join Date: Oct 2001
Yeah. I don't own "Lion King" yet and frankly my donations aren't even coming close to covering my losses in purchases... and I'm having trouble justifying any more "only for testing" buys. I bought three new movies for testing this week alone (none of which were movies I personally wanted) -- and have to balance that against a single donation that doesn't even cover one of them.
So I'm not sure how long it will be before I can test it. In the meantime I guess I can look at the code and see if I can find an error in my sizing algorithms. But that's about all I can do. Sorry. Last edited by jdobbs; 22nd October 2011 at 04:57. |
#13283 | Link |
Oh no problem at all ^_^. I didn't know if there were too many posts and you missed mine by accident! For these testing only backup that you need to confirm, why don't you just go to blockbuster and rent them to test and return the bluray? I know this is "pirating" but it's not like you're distributing these back up and making a profit, you're just using your wits but do not have the financial to do so. I don't think it make sense for you to buy everyone's failed backup and testing them because that is absurd, and cost a ridiculous amount of money!
#13284 | Link | |
#13285 | Link |
Subtitles Always On - Was this resolved?
I have run across an issue, that I know was reported a few months back, where subtitles are always on. I was making a "Movie & Menus Backup" of Star Trek VI to a BD-25 and the completed backup has subtitles on even though they are set to off. I looked at those older posts but I didn't see if any resolution to the issue had been found. Was there any resolution to this issue, or would you like me to provide additional info to help track it down? If it hasn't been resolved I'd be happy to make more back-ups to see if it helps.
#13286 | Link |
Jdobbs its ok np.. That just my 2 cents. Do you think it has something to do with it detecting dif frames in that bluray? I have noticed before when I did a backup with usually 3 audio track(commentaries and main) it goes over to 110%, then at the end it come to 100%.
#13287 | Link |
@ xterminater n RE: It came out to 8.89GB ... All my other back up were fine beside this one, and other one was oversized too! But we'll take care of this one first!
Thanks To: omegaman7's post (http://forum.doom9.org/showpost.php?...ostcount=13211) I've noticed with some Blu Ray discs, the output size is sometimes smaller than ~22.5Gb by about the same size I've blanked. E.g. blank 1Gb, and it's 21.5Gb. So yes, the output size is somewhat erratic. However, I find it to be within reason. Ones that I've blanked, with NO_REENCODE, and then rerun through Bd-rebuilder, yield a better output size. Haven't tried star wars. I'm a trekkie :S I had replied that I was getting consistantly undersized or oversized output also using Movie & Menus & Backup mode. I started doing like omegaman7 suggested. Run Movie & Menu mode with target set at 50,000. This results in keeping the original video, no recode, and only takes about 20 or 30 minutes to finish. Then run it back thru BD_Rebuilder in full backup and set to whatever you originally targeted for the size of your backup. This has worked for me and always gets really close to the target I set for 24,200 size. I always get 98% or 99% of the BD-R disk full. It works great and it's worth the extra 20 minutes to not spend hours getting undersized or especially OVERSIZED output. Many thanks to jdobbs for this great peice of kit, and thanks to omegaman7 for his tip. |
#13288 | Link |
@ Chuckwagon RE: Subtitles Always On - Was this resolved?
I seem to get this problem at times where BD_RB changes the order of the subs that are kept and turned on in the finished encode. The last one I did was, "A Better LIfe", which had the #1 English sub turned on. Instead the disk played the always on screen #2 sub. I don't know why the order of the subs were changed but if you run the finished encode back thru BD_RD again and select the #2 sub as the one turned on it will only take 20 minutes to fix the problem. Good Luck, worknstiff |
#13289 | Link | |
#13290 | Link | |
#13292 | Link | |
![]() [Edit] I just went back through the threads. There was a problem with DTS decoding on True Blood (which I fixed via DirectshowSource), but I don't see where I could repeat a problem with subtitles. I'm not even sure how that could happen since they are simply demuxed and remuxed (unless resized). Last edited by jdobbs; 22nd October 2011 at 17:18. |
#13293 | Link | |
I can't remember for sure, but I will search too. ![]() You reported here: http://forum.doom9.org/showthread.php?t=143716&page=622 Last edited by Capsbackup; 22nd October 2011 at 16:26. |
#13295 | Link | ||
On my setup BDRB is only keeping 1 subtitle track for each language (is that the default setting, I can't remember) and in this case, since the disc seems to force subs on all the time, the one it keeps is the one that always has text for all the speaking parts. If the 3rd track is manually selected instead of the 1st one, then things behave "normally." So for this disc, the solution would be to keep at least those two subs tracks instead of only one for English. I don't know if this solution works for the other discs that have shown similar behavior, but it seems worknstiff also may have seen a similar solution, where it's just a matter of which sub track the movie would normally be forcing on, one that has text all the time vs one that only subs intermittently. So my issue is resolved, but I don't know if this fixes the other's subs always on issues. Last edited by Chuckwagon; 22nd October 2011 at 20:32. |
#13296 | Link |
is 18.6 GB considered an undersize concern? The original video was 33 GB (target BD-25). Settings was on auto and it did (easy) but two passes. This was VC-1, I think I did another VC-1 BD a month ago and it also outputed 18.6 GB.
#13297 | Link | |
While it's completely legal to do it that way, the more common method is to have a single stream of subtitles -- but set the "force on" flag for instances that are required (like foreign languages such as Klingon). That's probably the reason this happens so rarely. I personally never see it because I always keep all subtitles. Unfortunately there's really no way I can think of to know when this is being done. |
#13298 | Link |
If it reencodes and comes out to 18.6GB -- yes, it is a concern. If it says "keeping original video" and comes out small then no, because it is simply using the original video size and the undersize is due to removed tracks. If I understand correctly yours is reencoding. That means there is a problem.
#13299 | Link |
yes it is, here's a log.
[Status] LABEL=JURASSIC_PARK_1993_BLU-RAY VERSION=v0.39.01 (beta) SOURCE_SIZE=42480602907 SOURCE_VIDEO_SIZE=42093699072 TARGET_SIZE=24641536000 REDUCTION=.576205767127122 RESIZE_1080=0 AUDIO_TO_KEEP=eng; KEEP_HD_AUDIO=-1 SUBS_TO_KEEP=eng;fra;fre; BACKUP_MODE=0 MOVIEONLY_TYPE=0 USE_LAVF=0 QUICK=0 ENCODE_STEP=0 COMPLETED=27 REBUILD_COMPLETE=1 [00800] AUDIO=100 PGS=10101 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=20448571994 RATE=13921 NSTART=27000000 NEND=368846400 NSIZE=19620845568 FLINK=0 MLINK=0 Does everything check out? |
