10th July 2013, 02:06 | #17622 | Link |
Hello,
is there any way to increase BDRB processing speed? My machine is a siemens fujitsu rx600 server with 4 x intel xeon 3 GHz - each of them can handle two threads. Even BDRB uses all eight threads the overall processor load is only about 42 %. How can I change that? Greetings from Germany |
10th July 2013, 02:27 | #17623 | Link | |
[Edit] Be careful, though. Pass 2 uses more CPU than pass 1 -- and setting MULTIPROCESS too high can actually give you diminishing returns. Last edited by jdobbs; 10th July 2013 at 12:53. |
10th July 2013, 18:37 | #17624 | Link |
BD Rebuilder v0.44.15 (beta)
I've updated the first post of this thread with a link to the latest release of BD-RB (v0.44.15). Changes for this version:
- Added a new hidden setting. SUP_3D_DEPTH can be adjusted to add addition depth to subtitles Any value of 0 to 50 can be used. The higher the value, the closer the subtitles appear to the viewer. - Changed chapter detection in DVD import so that is if pulled from PTS headers in cells rather than IFO times (to correct for poor authoring found on some DVDs). - Corrected an issue in which the wrong resizing algorithm was used for downsizing 1920x1080 to 1440x1080. - Updated algorithm to provide a better starting CRF value when resizing to 1440x1080 and 720p. Only applies to one-pass CRF mode. - Corrected CRF prediction so that a quick hit does not result in an off-target final approximation. - Fixed an issue in which outputting to an intact MKV file from a telecined source could result in audio/video out-of-sync. - Added a workaround for a problem in ALTERNATE DVD-5 output in which a working path containing a "&" character could cause rebuilding to fail. - Fixed an issue in which importing series DVDs that have multiple episodes within a single PGC could have a continually increasing audio de- sychronization. - Corrected a problem in which certain very rare authoring circumstances could cause BD-RB to lock in a forever loop. - Updated BD-RB and INSPECT to accept an newer version of FFDSHOW (r4504) as "correct". - Updated the included version of X264.EXE to the latest release (r2345). - Updated the included version of X264-64.EXE to the latest release (r2345). - Other minor corrections and cosmetic fixes. |
11th July 2013, 01:23 | #17626 | Link | |
Thanks |
11th July 2013, 02:55 | #17627 | Link | |
I usually run an FFDSHOW release for a month or two before adding it to the list, and then start testing another one. Some of the issues I've experienced in the past took a while to manifest (needing some unique circumstances) and that's why I test it for so long. |
11th July 2013, 03:16 | #17630 | Link | |
11th July 2013, 03:49 | #17631 | Link | ||
OK. So if I can't use PiP there is no point in encoding it onto the back-up 25GB BD disc and taking up space and reducing the quality of the main movie. Can anyone tell me how to exclude all the PiP videos from the BD-Rebuilder list to re-encode, please. |
11th July 2013, 05:26 | #17632 | Link |
You asked Yes, you said you "Prefer" free. But I was simply giving my 2 cents. It may be "Expensive", but it is a pretty versatile player
11th July 2013, 23:42 | #17636 | Link |
Discovered a problematic title: House at the End of the Street (2012), by 20th Century Fox. English DTS-HD MA 5.1 audio, with English and Spanish subs. Disc contains both Theatrical and Unrated cuts by splitting the movie into several small files. A while back I ran a Full Backup of the disc on 0.44.xx (before 0.44.14) and the output suffered from very glitchy video. I decided to wait for a new version of BD-RB to try again later.
A couple of weeks ago I tried to make a movie-only "1080p with Intact Audio" MKV of the shorter movie on 0.44.14 (2-pass, target size 8100MB). The process failed during "Building Alternate Output Structure" with error message "ERROR in attempt to mux (MKVMERGE)". Again, I put the disc aside to wait for a new version of BD-RB. Today I ran the same MKV output task again on 0.44.15, with the same result. Here's the log: Code:
[07.11.13] BD Rebuilder v0.44.15 (beta) [19:48:40] Source: HOUSE_AT_THE_END_OF_STREET_2012_00130 - Input BD size: 24,70 GB - Approximate total content: [01:40:45.914] - Windows Version: 6.1 [7601] - MOVIE-ONLY/ALTERNATE OUTPUT mode enabled - Mode: MKV Container, 1920x1080, Intact Audio - X264 Tweak(s) enabled - Decoding/Frame serving: X264/LAVF - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [19:48:41] PHASE ONE, Encoding - [19:48:41] Processing: VID_00155 (1 of 13) - [19:48:41] Extracting A/V streams [VID_00155] - [19:55:32] Reencoding video [VID_00155] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 2*633 frames - Bitrate: 6*368 Kbs - [19:55:32] Reencoding: VID_00155, Pass 1 of 2 - [19:56:19] Reencoding: VID_00155, Pass 2 of 2 - [19:59:40] Video Encode complete - [19:59:40] Processing audio tracks - Track 4352 (eng): Keeping original audio - [19:59:40] Processing: VID_00168 (2 of 13) - [19:59:40] Extracting A/V streams [VID_00168] - [19:59:58] Reencoding video [VID_00168] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 4*151 frames - Bitrate: 7*535 Kbs - [19:59:58] Reencoding: VID_00168, Pass 1 of 2 - [20:01:28] Reencoding: VID_00168, Pass 2 of 2 - [20:08:14] Video Encode complete - [20:08:14] Processing: VID_00156 (3 of 13) - [20:08:14] Extracting A/V streams [VID_00156] - [20:10:26] Reencoding video [VID_00156] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 34*999 frames - Bitrate: 7*504 Kbs - [20:10:26] Reencoding: VID_00156, Pass 1 of 2 - [20:14:52] Reencoding: VID_00156, Pass 2 of 2 - [21:01:54] Video Encode complete - [21:01:54] Processing: VID_00169 (4 of 13) - [21:01:54] Extracting A/V streams [VID_00169] - [21:02:02] Reencoding video [VID_00169] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 1*267 frames - Bitrate: 7*537 Kbs - [21:02:02] Reencoding: VID_00169, Pass 1 of 2 - [21:02:34] Reencoding: VID_00169, Pass 2 of 2 - [21:04:53] Video Encode complete - [21:04:53] Processing: VID_00157 (5 of 13) - [21:04:53] Extracting A/V streams [VID_00157] - [21:07:15] Reencoding video [VID_00157] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 44*642 frames - Bitrate: 7*509 Kbs - [21:07:15] Reencoding: VID_00157, Pass 1 of 2 - [21:23:34] Reencoding: VID_00157, Pass 2 of 2 - [22:43:04] Video Encode complete - [22:43:04] Processing: VID_00170 (6 of 13) - [22:43:04] Extracting A/V streams [VID_00170] - [22:43:16] Reencoding video [VID_00170] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 2*197 frames - Bitrate: 7*589 Kbs - [22:43:16] Reencoding: VID_00170, Pass 1 of 2 - [22:44:05] Reencoding: VID_00170, Pass 2 of 2 - [22:47:57] Video Encode complete - [22:47:57] Processing: VID_00158 (7 of 13) - [22:47:57] Extracting A/V streams [VID_00158] - [22:49:09] Reencoding video [VID_00158] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 20*121 frames - Bitrate: 7*498 Kbs - [22:49:09] Reencoding: VID_00158, Pass 1 of 2 - [22:56:16] Reencoding: VID_00158, Pass 2 of 2 - [23:32:42] Video Encode complete - [23:32:42] Processing: VID_00171 (8 of 13) - [23:32:42] Extracting A/V streams [VID_00171] - [23:33:05] Reencoding video [VID_00171] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 3*954 frames - Bitrate: 7*503 Kbs - [23:33:05] Reencoding: VID_00171, Pass 1 of 2 - [23:34:30] Reencoding: VID_00171, Pass 2 of 2 - [23:41:35] Video Encode complete - [23:41:35] Processing: VID_00159 (9 of 13) - [23:41:35] Extracting A/V streams [VID_00159] - [23:41:48] Reencoding video [VID_00159] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 2*057 frames - Bitrate: 7*621 Kbs - [23:41:48] Reencoding: VID_00159, Pass 1 of 2 - [23:42:33] Reencoding: VID_00159, Pass 2 of 2 - [23:46:15] Video Encode complete - [23:46:15] Processing: VID_00172 (10 of 13) - [23:46:15] Extracting A/V streams [VID_00172] - [23:46:21] Reencoding video [VID_00172] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 714 frames - Bitrate: 7*621 Kbs - [23:46:21] Reencoding: VID_00172, Pass 1 of 2 - [23:46:38] Reencoding: VID_00172, Pass 2 of 2 - [23:47:59] Video Encode complete - [23:47:59] Processing: VID_00160 (11 of 13) - [23:47:59] Extracting A/V streams [VID_00160] - [23:48:19] Reencoding video [VID_00160] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 4*761 frames - Bitrate: 7*604 Kbs - [23:48:19] Reencoding: VID_00160, Pass 1 of 2 - [23:50:04] Reencoding: VID_00160, Pass 2 of 2 - [23:58:34] Video Encode complete - [23:58:34] Processing: VID_00173 (12 of 13) - [23:58:34] Extracting A/V streams [VID_00173] - [23:58:45] Reencoding video [VID_00173] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 1*941 frames - Bitrate: 7*587 Kbs - [23:58:45] Reencoding: VID_00173, Pass 1 of 2 - [23:59:28] Reencoding: VID_00173, Pass 2 of 2 - [00:03:00] Video Encode complete - [00:03:00] Processing: VID_00161 (13 of 13) - [00:03:00] Extracting A/V streams [VID_00161] - [00:04:18] Reencoding video [VID_00161] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 21*520 frames - Bitrate: 7*259 Kbs - [00:04:18] Reencoding: VID_00161, Pass 1 of 2 - [00:10:59] Reencoding: VID_00161, Pass 2 of 2 - [00:39:15] Video Encode complete [00:39:15]PHASE ONE complete [00:39:15]PHASE TWO - Rebuild Started - [00:39:15] Building ALTERNATE OUTPUT Structure - ERROR in attempt to mux (MKVMERGE) [00:50:21] - Failed to REBUILD MUXOPT --no-pcr-on-video-pid --new-audio-pes --demux --vbr --vbv-len=500 V_MPEG4/ISO/AVC, "E:\_BDRB_OUTPUT\WORKFILES\VID_00155.AVS.264"+"E:\_BDRB_OUTPUT\WORKFILES\VID_00168.AVS.264"+ "E:\_BDRB_OUTPUT\WORKFILES\VID_00156.AVS.264"+"E:\_BDRB_OUTPUT\WORKFILES\VID_00169.AVS.264"+ "E:\_BDRB_OUTPUT\WORKFILES\VID_00157.AVS.264"+"E:\_BDRB_OUTPUT\WORKFILES\VID_00170.AVS.264"+ "E:\_BDRB_OUTPUT\WORKFILES\VID_00158.AVS.264"+"E:\_BDRB_OUTPUT\WORKFILES\VID_00171.AVS.264"+ "E:\_BDRB_OUTPUT\WORKFILES\VID_00159.AVS.264"+"E:\_BDRB_OUTPUT\WORKFILES\VID_00172.AVS.264"+ "E:\_BDRB_OUTPUT\WORKFILES\VID_00160.AVS.264"+"E:\_BDRB_OUTPUT\WORKFILES\VID_00173.AVS.264"+ "E:\_BDRB_OUTPUT\WORKFILES\VID_00161.AVS.264", fps=23.976, insertSEI, contSPS, track=4113 Also, noticed there's actually a (broken) 3.68GB MKV in the temp directory, so BD-RB errored out in the middle of the task. Last edited by jdobbs; 12th July 2013 at 00:37. |
12th July 2013, 14:44 | #17638 | Link |
I am also getting a Failed To Rebuild message for Taken 2. (I've rebuilt many movies and never encountered this problem before...)
I have attached the log, although it doesn't have much information. Please let me know if there is something else that I can provide that would help. This is a wonderful tool and I truly appreciate all of your hard work with it! Code:
[07/11/13] BD Rebuilder v0.44.03 (beta) [17:46:30] Source: TAKEN_2_00000 - Input BD size: 20.31 GB - Approximate total content: [01:32:07.896] - Windows Version: 6.2 [9200] - MOVIE-ONLY/ALTERNATE OUTPUT mode enabled - Mode: MKV Container, 1280x720, 448Kbs DD5.1 - Decoding/Frame serving: DirectShow - Audio Settings: AC3=1 DTS=1 HD=1 Kbs=640 [17:46:30] PHASE ONE, Encoding - [17:46:30] Processing: VID_00940 (1 of 22) - [17:46:30] Extracting A/V streams [VID_00940] - [17:51:57] Reencoding video [VID_00940] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 10,662 frames - [17:51:57] Reencoding: VID_00940, Pass 1 of 1 - [18:03:27] Video Encode complete - [18:03:27] Processing audio tracks - Track 4352 (eng): Reencoding audio to AC3... - [18:09:48] Processing: VID_00960 (2 of 22) - [18:09:48] Extracting A/V streams [VID_00960] - [18:10:35] Reencoding video [VID_00960] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 8,604 frames - [18:10:36] Reencoding: VID_00960, Pass 1 of 1 - [18:19:50] Video Encode complete - [18:19:50] Processing: VID_00942 (3 of 22) - [18:19:50] Extracting A/V streams [VID_00942] - [18:20:33] Reencoding video [VID_00942] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 8,571 frames - [18:20:33] Reencoding: VID_00942, Pass 1 of 1 - [18:29:38] Video Encode complete - [18:29:38] Processing: VID_00961 (4 of 22) - [18:29:38] Extracting A/V streams [VID_00961] - [18:30:03] Reencoding video [VID_00961] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 4,325 frames - [18:30:03] Reencoding: VID_00961, Pass 1 of 1 - [18:34:40] Video Encode complete - [18:34:40] Processing: VID_00944 (5 of 22) - [18:34:40] Extracting A/V streams [VID_00944] - [18:34:50] Reencoding video [VID_00944] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 1,188 frames - [18:34:51] Reencoding: VID_00944, Pass 1 of 1 - [18:36:10] Video Encode complete - [18:36:10] Processing: VID_00962 (6 of 22) - [18:36:10] Extracting A/V streams [VID_00962] - [18:37:09] Reencoding video [VID_00962] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 12,108 frames - [18:37:09] Reencoding: VID_00962, Pass 1 of 1 - [18:49:59] Video Encode complete - [18:49:59] Processing: VID_00946 (7 of 22) - [18:49:59] Extracting A/V streams [VID_00946] - [18:50:44] Reencoding video [VID_00946] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 8,906 frames - [18:50:44] Reencoding: VID_00946, Pass 1 of 1 - [19:00:08] Video Encode complete - [19:00:08] Processing: VID_00963 (8 of 22) - [19:00:08] Extracting A/V streams [VID_00963] - [19:00:17] Reencoding video [VID_00963] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 787 frames - [19:00:17] Reencoding: VID_00963, Pass 1 of 1 - [19:01:12] Video Encode complete - [19:01:12] Processing: VID_00948 (9 of 22) - [19:01:12] Extracting A/V streams [VID_00948] - [19:02:08] Reencoding video [VID_00948] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 8,926 frames - [19:02:08] Reencoding: VID_00948, Pass 1 of 1 - [19:11:41] Video Encode complete - [19:11:41] Processing: VID_00964 (10 of 22) - [19:11:41] Extracting A/V streams [VID_00964] - [19:11:55] Reencoding video [VID_00964] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 2,222 frames - [19:11:55] Reencoding: VID_00964, Pass 1 of 1 - [19:14:19] Video Encode complete - [19:14:19] Processing: VID_00950 (11 of 22) - [19:14:19] Extracting A/V streams [VID_00950] - [19:15:08] Reencoding video [VID_00950] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 8,439 frames - [19:15:08] Reencoding: VID_00950, Pass 1 of 1 - [19:24:07] Video Encode complete - [19:24:07] Processing: VID_00965 (12 of 22) - [19:24:07] Extracting A/V streams [VID_00965] - [19:24:32] Reencoding video [VID_00965] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 4,542 frames - [19:24:32] Reencoding: VID_00965, Pass 1 of 1 - [19:29:24] Video Encode complete - [19:29:24] Processing: VID_00952 (13 of 22) - [19:29:24] Extracting A/V streams [VID_00952] - [19:29:43] Reencoding video [VID_00952] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 3,140 frames - [19:29:43] Reencoding: VID_00952, Pass 1 of 1 - [19:33:06] Video Encode complete - [19:33:06] Processing: VID_00966 (14 of 22) - [19:33:06] Extracting A/V streams [VID_00966] - [19:33:33] Reencoding video [VID_00966] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 4,830 frames - [19:33:33] Reencoding: VID_00966, Pass 1 of 1 - [19:38:43] Video Encode complete - [19:38:43] Processing: VID_00954 (15 of 22) - [19:38:43] Extracting A/V streams [VID_00954] - [19:39:28] Reencoding video [VID_00954] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 9,300 frames - [19:39:28] Reencoding: VID_00954, Pass 1 of 1 - [19:49:19] Video Encode complete - [19:49:19] Processing: VID_00967 (16 of 22) - [19:49:19] Extracting A/V streams [VID_00967] - [19:50:19] Reencoding video [VID_00967] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 12,292 frames - [19:50:19] Reencoding: VID_00967, Pass 1 of 1 - [20:03:23] Video Encode complete - [20:03:23] Processing: VID_00956 (17 of 22) - [20:03:23] Extracting A/V streams [VID_00956] - [20:03:38] Reencoding video [VID_00956] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 2,106 frames - [20:03:38] Reencoding: VID_00956, Pass 1 of 1 - [20:05:56] Video Encode complete - [20:05:56] Processing: VID_00968 (18 of 22) - [20:05:56] Extracting A/V streams [VID_00968] - [20:06:09] Reencoding video [VID_00968] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 2,055 frames - [20:06:09] Reencoding: VID_00968, Pass 1 of 1 - [20:08:24] Video Encode complete - [20:08:24] Processing: VID_00958 (19 of 22) - [20:08:24] Extracting A/V streams [VID_00958] - [20:08:47] Reencoding video [VID_00958] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 4,064 frames - [20:08:47] Reencoding: VID_00958, Pass 1 of 1 - [20:13:11] Video Encode complete - [20:13:11] Processing: VID_00969 (20 of 22) - [20:13:11] Extracting A/V streams [VID_00969] - [20:13:21] Reencoding video [VID_00969] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 1,398 frames - [20:13:21] Reencoding: VID_00969, Pass 1 of 1 - [20:14:53] Video Encode complete - [20:14:53] Processing: VID_00971 (21 of 22) - [20:14:53] Extracting A/V streams [VID_00971] - [20:15:22] Reencoding video [VID_00971] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 4,983 frames - [20:15:22] Reencoding: VID_00971, Pass 1 of 1 - [20:20:41] Video Encode complete - [20:20:41] Processing: VID_00970 (22 of 22) - [20:20:41] Extracting A/V streams [VID_00970] - [20:21:25] Reencoding video [VID_00970] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 9,089 frames - [20:21:25] Reencoding: VID_00970, Pass 1 of 1 - [20:30:47] Video Encode complete [20:30:47]PHASE ONE complete [20:30:47]PHASE TWO - Rebuild Started - [20:30:47] Building ALTERNATE OUTPUT Structure [20:35:15] - Failed to REBUILD Last edited by HomeDepot4; 12th July 2013 at 14:47. Reason: added code tags |
