1st March 2018, 00:03 | #5121 | Link |
It's planned - but need time to implement
1st March 2018, 04:27 | #5122 | Link | |
http://p3.cdn.img9.top/ipfs/Qmd1S5vJ...ebGrnXkU?3.gif |
1st March 2018, 05:33 | #5124 | Link |
Show filters list.
2nd March 2018, 10:18 | #5125 | Link |
The developer of StreamBuffRe whom is making a plugin for it that uses MPC-BE for the viewing of streams/videos buffered by it has ran into some issues. They are as follows:
1. Starting multiple MPCs (Instead of starting a new instance, the old instance plays the new stream) 2. It seems not possible to change the player title (to show what the actual stream name is) It would be nice if someone could tell me how to fix one/both of them and I'll let the developer know. |
2nd March 2018, 15:23 | #5127 | Link | |
EDIT: There was a feature request for MPC-HC which requested the ability to use /title to change its title that never got implemented. Maybe the developer of MPC-BE could implement it soon. Last edited by Zero3K; 2nd March 2018 at 19:33. |
2nd March 2018, 21:45 | #5128 | Link |
MKV and tools user
MPC-BE rotation of MKV
Thanks for having MPC-BE finally able to auto-rotate Matroska videos / MKV. It's a fantastic ability. I just downloaded and tested MPC-BE.1.5.2.3445.x64.
I often remux many videos of different formats into the MKV container so that I could embed an external XML rotation tag. For example, there are many videos which were shot sideways. Thus, I don't have to manually rotate those videos every time during playback. Thanks again! |
5th March 2018, 00:16 | #5131 | Link | |
6th March 2018, 16:37 | #5136 | Link |
MPC-BE does not support any plug-ins.
6th March 2018, 17:24 | #5137 | Link | |
6th March 2018, 19:52 | #5138 | Link | |
1. Livestreams take some time to load sometimes 2. Closing MPC-BE directly makes it hang for a short time. (Could be an MPC-BE problem) 3. The "play in running player" option is not working as intended due to the way new streams are opened in MPC-BE. 4. The name of the stream is not shown in MPC-BEs title bar. 5. Resizing and moving player window can fail in certain cases (needs more testing to find which cases these are). 6. The end of Streams is not yet detected, could be problematic for auto play. 7. Setting another Audio device is possible but will most likely fail due to an MPC-BE specific error (at least on my machines...). Maybe I remove the setting from the PlayerProfile. 8. Closing MPC-BE can cause sending an invalid time for the current stream corrupting the Playlist entry and making it unplayable ( for now just remove and re-add the entry). |
6th March 2018, 20:22 | #5140 | Link | |
