Go Back   Doom9's Forum > Video Encoding > MPEG-4 ASP
Old 17th May 2005, 12:02   #201  |  Link
bond
Originally posted by Flashmeister
So, MPEG4 Modifier should open it, no?
if its really xvid than yes
Between the weak and the strong one it is the freedom which oppresses and the law that liberates (Jean Jacques Rousseau)
I know, that I know nothing (Socrates)
MPEG-4 ASP FAQ | AVC/H.264 FAQ | AAC FAQ | MP4 FAQ | MP4Menu stores DVD Menus in MP4 (guide)
Ogg Theora | Ogg Vorbis
use WM9 today and get Micro$oft controlling the A/V market tomorrow for free
bond is offline   Reply With Quote
Old 17th May 2005, 12:43   #202  |  Link
Leak
ffdshow/AviSynth wrangler
Leak's Avatar
...unless the file is an OpenDML AVI, which is currently biting me in the rectum...
np: Metamatics - Rapala Shad (From Death To Passwords Where You're A Paper Aeroplane)
Leak is offline   Reply With Quote
Old 24th May 2005, 12:36   #203  |  Link
Infirmus
Infirmus's Avatar
My player (Zensonic Z330) just got a firware upgrade that allows it to play packed bitstream! Yay! Dont need to use MPEG4 Modifier anymore..! Thanks for the very usefull tool while I still needed it Moitah.
Infirmus is offline   Reply With Quote
Old 29th May 2005, 15:59   #204  |  Link
BigJim
Can someoe tell me how the use this prog?
I have an AVI standalone player (yamada DVX 6600) and the XVID support isn't that good.The XVID movies are played back jerky.
This programm could fix the jerky playback except I don't know excactly what to change or modify.Should I just unpack the film?
Is there a tutorial somewhere??
Sincerely
Simon
BigJim is offline   Reply With Quote
Old 30th May 2005, 21:08   #205  |  Link
Birdy1
[Browse...] for the file, check the [unpack] checkbox, [save...] the file
Birdy1 is offline   Reply With Quote
Old 31st May 2005, 17:53   #206  |  Link
derevo
i tried to modify xvid's aspect ratio, but it does not change. when i modified file by this program and i open this file in mpeg4 midifier and see video info there aspect ratio is changed, but when i watch it in any player aspect ratio is same that it was in non modified file. where is problem??
derevo is offline   Reply With Quote
Old 31st May 2005, 18:04   #207  |  Link
Birdy1
The only player I know of that supports the aspect ratio is VLC media player
Old 31st May 2005, 18:05   #208  |  Link
SeeMoreDigital
Life's clearer in 4K UHD
SeeMoreDigital's Avatar
Originally Posted by derevo
... but when i watch it in any player aspect ratio is same that it was in non modified file. where is problem??
What "direct-show" decoder filter are you using with your software media player?
If you can try these 16:9 AR Signalling Test Encodes and these 4:3 AR Signalling Test Encodes please!
EDIT:
So does Nero's ShowTime 2 Player. And so do 3ivx's, XviD (newest beta) and DivX's (5.3.0.1461) DSdec filters...
Cheers
Old 31st May 2005, 18:20   #209  |  Link
derevo
i don't know what is direct-show decoder filter.
where i can look it and change??
Old 31st May 2005, 19:10   #210  |  Link
SeeMoreDigital
If you are using say, Windows Media Player, it's stated under: "Files" then "Properties"... And you should see it here: -
Cheers
Old 31st May 2005, 19:30   #211  |  Link
derevo
in my file it is also "XviD MPEG-4 Video Decoder".
in file wich come from satellite resolution is 720x576 and aspect ratio is 3:4,
but when i compress it in xvid aspect ratio becomes to 5:4.
here is screenshots:
http://www.saunalahti.fi/isos/5.4.gif
http://www.saunalahti.fi/isos/4.3.gif
mpeg4 modifier does not change it.
Old 31st May 2005, 20:15   #212  |  Link
SeeMoreDigital
When you visit XviD's "Configure Decoder" settings, does the GUI look similar this one?
Cheers
Old 31st May 2005, 20:50   #213  |  Link
derevo
not, it is an other.
here is screenshot:
Old 31st May 2005, 21:04   #214  |  Link
ChronoCross
Does it really matter?
ChronoCross's Avatar
That's the encoder screen. you can access the decoder config in Start Menu -> Programs -> Xvid -> Configure Decoder.
ChronoCross is offline   Reply With Quote
Old 31st May 2005, 21:05   #215  |  Link
SeeMoreDigital
That's XviD's "decoder" panel, which is available via the "encoder"!
The "decoder" GUI I'm talking about is accessable via the "Start" button... Then, Programs/XviD/Configure Decoder (or something similar)
Cheers
Old 31st May 2005, 22:01   #216  |  Link
derevo
yes, encoder is same as that on your screenshot.
Old 31st May 2005, 22:08   #217  |  Link
derevo
i tried to change options in there windows and now aspect ratio is right
thanks for answer.
it is very difficult to use computers.
Old 9th June 2005, 02:53   #218  |  Link
Vladdy
Will we see a version that supports the openDML format?
I have some 2+ gb avi's that have an embedded AR and can't use this app
Vladdy is offline   Reply With Quote
Old 9th June 2005, 10:27   #219  |  Link
dimitrik
OpenDML DML support would be greatly appreciated.
I also have a lot of older files that I would like to convert. I guess openDML was very popular at one time
for the great tool!
dimitrik is offline   Reply With Quote
Old 10th June 2005, 12:32   #220  |  Link
Vladdy
for the great tool!
More to the point, standard avi files only support up to 2gb in size. You need to save avis in opendml format when you go over 2gb.
