Old 30th April 2016, 19:52   #37641  |  Link
baii
Originally Posted by Georgel View Post
I was thinking of buying a laptop with desktop GPU GTX980. (Not 980M). My question regarding madVR, is: would an i7-6700K + GTX980 be able to run NNEDI at 256 Neurons and add edge sharpening + edge thinning + debanding + 4K upscaling with AR and sigmoidal light using Jinc ?
I am a bit curious if anyone tried, because I was thinking of getting a P870 from Clkevo, and while it is a power house of a laptop, I am afraid that for using madVR in these conditions, I should probably wait a bit more for the new generation of GPUs to appear. Especially that I will be always upscaling FHD to 4K.
256 neuron luma nnedi3? No, let alone all the enhancement.
With no enhancement a 980ti / fury x can do 128 for 1080p while gimping everything else. Anyways, cramping all the option on doesn't always make it "look better".
Btw, if you push the gpu hard on laptop, the fan noise can be pretty annoying unless you have headphone on all time.
baii is offline   Reply With Quote
Old 30th April 2016, 19:53   #37642  |  Link
Originally Posted by Patrik G View Post
dont you need a tv with 10 bit panel to see steps above 255?
that panasonic plasma is only 8 bit right ?
sure it will be clipping.
get a 500M instead
true 10bit panel
plasma are technically 1 bit and noisy compared to LCD screens.
and of cause you don't need more bit deep to show steps higher than x that's not how this works.
Old 30th April 2016, 20:04   #37643  |  Link
aufkrawall
1080p NNEDI3 32 doubling already requires much performance, GTX 980 can do 1080p 30fps NNEDI3 64 doubling + some very lightweight postprocessing at most. When you output 4k resolution, deband with max quality isn't low on resources either and neither is sharpen edges.
Don't buy an expensive notebook now, probably already in June or July you can buy notebooks with Polaris 10 or GP104/106 GPU which will be a huge technology update in general over current GPUs (HEVC 10 bit, HDR, Display Port 1.3...).
Old 30th April 2016, 20:15   #37644  |  Link
Uoppi
The only other option is madVR 16-235 and the GPU full, but this clips your desktop.
This is the recommended combination if desktop colors are of no concern, right?
I'm getting confused once again because some on the other hand say to use madVR full and GPU full.
I have madVR limited, GPU full and HDMI black level "low" on my Samsung TV (can't remember if low meant full or limited but I'm guessing low = full). Can someone confirm if this is opimal? Black levels look alright on test clips at least.
Uoppi is offline   Reply With Quote
Old 30th April 2016, 20:25   #37645  |  Link
baii
yet Another TV color range question, so confusing grr
Samsung TV hdmi in
Intel HD
I have full range gpu, pc mode tv (should be full IDK...), hdmi normal, madvr set to full, AVS hd709 black clipping flashing at 17+.
hdmi low with full on gpu will crush black. (no flash)
Does this sound right~?
And 1080p 59hz vs 60hz?
I hate TV...
seems like I am on the same boat like uoppi,lols.
edit
Going to go with this~~ from AVS zoyd
http://www.avsforum.com/forum/139-di...l#post33427002
For me would be the second one.
Old 30th April 2016, 21:58   #37646  |  Link
trueunborn
Help with 3D
Hi all, Got the 3D player working great with Latest LAV and Mavr but Reclock does not detect correctly the refresh rate that MAdVr is forcing. Reclock thinks it is 24hz while MAdvr forces 23hz (x2 in reality...)... the result is a lot of dropped frames. Tried a lot of things with no luck.Any idea?
BTW, I have an nvidia card with drivers 364,47.
trueunborn is offline   Reply With Quote
Old 30th April 2016, 22:21   #37647  |  Link
JamPS
Originally Posted by trueunborn View Post
...Reclock thinks it is 24hz while MAdvr forces 23hz (x2 in reality...)... the result is a lot of dropped frames. Tried a lot of things with no luck.Any idea?
Try setting ReClock on manual fps.
JamPS is offline   Reply With Quote
Old 30th April 2016, 22:34   #37648  |  Link
Warner306
I'd set everything to full range so desktop levels remain accurate and the GPU doesn't have to do a range conversion for the display -- after madVR, the output is straight passthrough.
Your configuration is considered optimal because madVR doesn't clip anything and all output is passed-through as is to the display. But I doubt it has any real advantage over setting everything full range; especially when your desktop levels will be off and look distracting.
Can anyone claim superiority for setting madVR to 16-235?
Old 30th April 2016, 23:12   #37649  |  Link
Asmodian
There is some banding introduced by expanding 16-235 to 0-255 but madVR's dithering prevents this being an issue (it results in extra dither noise instead of banding), at least on most displays.
madVR options explained
Old 30th April 2016, 23:53   #37650  |  Link
Warner306
If the display is set to 16-235, does it clip 0-15 or 236-255? I'm still editing this section in my own guide.
Old 1st May 2016, 00:56   #37651  |  Link
Georgel
Visual Novel Dev.
Georgel's Avatar
I thought that an ultra fast GPU could do a bit more.
I do wear headphones almost all the time. I am one of those audiophools who invests in headphones too. Afterall my project is about audio reproduction, and music quality and fidelity.
Georgel is offline   Reply With Quote
Old 1st May 2016, 00:57   #37652  |  Link
Georgel
Visual Novel Dev.
Georgel's Avatar
IF you have display set 16-235, it normally clips all values outside of this, so yes, they should look like clipping.
Old 1st May 2016, 01:02   #37653  |  Link
Georgel
Visual Novel Dev.
Georgel's Avatar
I was studying the new generation of GPUs. I am a member of Notebookreview, and their thread for Pascal seems to be almost the most fired up on the internet.
1080M for laptops sadly seems like one of those huge letdowns that you wish you could get over, because all news indicate to 1080M being released a bit later, and they don't indicate a much higher power update.
Well, I mainly need a laptop with 4K display, because I am creating Visual Novels, and need those color accuracy.
But I also abuse my day to day laptop to watch anime, and listen to music and do programming, so having a laptop that has a 4K screen, but on which I can also do powerful gaming and use madVR with full blown potential really sounds sweet. So far, I am able to use anything but not NNEDI algorithms with my GTX860M, so it is not a major letdown, but I am not watching videos in 4K. I am a bit worried that when I will get to 4K I might be disappointed in the performance of that GPU (desktop GTX980).
I want to be able to fluently play games and watch movies in native 4K at 60fps for games, and without drops for madVR.
I also hope that the new link they use for Pascal could make SLI or whatever it will be named to be easier to implement in madVR (or automatic, why not ?)
Old 1st May 2016, 02:04   #37654  |  Link
aufkrawall
NVLink is for professional HPC, not consumer GPUs.
16nm FF+ will also lower power consumption remarkably over 28nm. This is especially useful in notebooks or HTPCs, I can't imagine notebooks with full GM204 chip can actually be close to silent.
Also, with good 1080p sources there's not really any need to use NNEDI3 over super-xbr (anti-bloat) + SuperRes, which requires much less GPU performance. Polaris 10 will most likely be slower than GP104 in games, but it will also cost less and still be sufficient for a lot of things.
GM204 isn't able to decode HEVC 10 bit or VP-9, it will be outdated soon.
Old 1st May 2016, 02:43   #37655  |  Link
Stereodude
get a 500M instead
true 10bit panel
FWIW, I can see an improvement with 10-bit vs. 8-bit on my Samsung plasma with a gradient ramp (madVR dithering turned off).
Old 1st May 2016, 02:49   #37656  |  Link
Georgel
Visual Novel Dev.
Georgel's Avatar
That is useful to know.
I will make sure to wait until they release the desktop version of 1080 and see how much better it is in relation to desktop 980. I need to feel motivated to buy the thing.
Also, Clevo P870, is not exactly your average desktop, it is pretty silent, built like a tank, accepts both desktop CPU and GPU, and rocks one's world.
On the other hand, it is quite expensive and heavy. Really heavy.
This being said, I would still consider P870, because I can get it with G.Skill RAM and Samsung PRO SSDs and other features that you cannot do on non custom laptops.
Old 1st May 2016, 03:33   #37657  |  Link
Asmodian
Right, to properly calibrate for 16-235 you would adjust the display until only 16-235 were visible so everything above and below would be effectively clipped.
MadVR 16-235, GPU 0-255, and adjust the display until only 16-235 are visible.
Old 1st May 2016, 04:03   #37658  |  Link
Asmodian
get a 500M instead
true 10bit panel
This isn't how 10-bit v.s. 8-bit works.
255 8-bit = 1023 10-bit
64-940 in 10-bit is simply 16-235 in 8-bit, the problem is bad banding with a gradient from near 0 to 10,000(!?) nits with only 220 steps.
10,000 nits is crazy but if it was possible you would need at least 12-bit for 3505 steps... hopefully we can get rid of limited range by then too so we could use all 4096 steps.
Old 1st May 2016, 04:58   #37659  |  Link
JarrettH
Is there a string value for hevc or h.265?
Basically what I want to do is create a profile to disable artifact removal if the file format is hevc.
Edit: Maybe this works for now...?
if (not h264) or (not MPEG2) "x265"
Ok that isn't working...what do I need to fix?
Old 1st May 2016, 05:03   #37660  |  Link
Warner306
Ok, I'm finally clear on this topic. Thanks.
