22nd May 2016, 12:52 | #841 | Link |
I did a few more tests with x264 and --frame-packing 5, and muxing the frame packed .264 stream to .m2ts with tsMuxeR, setting level 4.1
Encoding: - x264 encodes the interleaved (combined) source using 1-pass CRF mode, and exits finally with error code 1. - tsMuxer muxes the encoded .264 stream to .m2ts without error, frame rate = double (47.952fps) Playback: - I can watch the 3D .m2ts correctly with bino - Stereoscopic Player however swaps the views every about half second (??) - The TV plays the left and right view sequentially (= jittery 2D) So 3D re-encoding of 3D sources using x264 and --frame-packing 5 seems to work, but playback compatibility is poor (only the bino player works in my case). Edit: Some more info on 3D display and HDMI structures is found here: http://www.spectracal.com/downloads/...the%20Home.pdf Last edited by Sharc; 24th May 2016 at 19:17. |
25th May 2016, 13:50 | #842 | Link | |
I am much more interested in MVC since it's an industry standard. And is supported by pretty much any BluRay3D player. (Including the one I have) And I am pretty sure the next gen players will probably be able to do 1080p fullSBS HEVC because of all the 4K support. |
17th July 2016, 16:17 | #843 | Link |
Is there a guide on how to use this? I want to take makemkv mvc output and compress it for space savings. I understand that this tool appears to be the only way to do that, but I can't seem to a find a GUI for it or any instructions. I would simple like to take the makemkv mvc file and shrink it down with burned in subtitles. Is this possible?
20th October 2016, 13:39 | #844 | Link |
I read a lot of problems with this transcoder.
I use DVDfab to shrink 3D movies. The problem with that is that the output size can only be set at either BD25 or BD50 with some small disc size variations. The workaround for this to get the proper output size is a little cumbersome but doable. 1. Rip the 3D movie with MakeMKV. 2. Extract largest audio file as single file as well. 3. Make BD ISO (or file structure) from movie with TSmuxer. 4. Load ISO (or file structure) with DVDfab and set output to BD25 and see what kind of % compression that gives. 5. If you need more compression to obtain your desired file size (animation can be squeezed a lot), mux the extra audio file with MKVtoolnix to moviefile from MakeMKV and make a new ISO with TSmuxer. 6. Repeat step 4 and then 5 until you get the compression ratio you need. 7. Encode. 8. From the encoded ISO extract the movie again with MakeMKV and only select 1 audio stream. Presto. Smaller 3D movie at the size YOU want. |
20th October 2016, 13:51 | #845 | Link | |
What do you do for step two to extract? And what do you do about subtitles?
21st October 2016, 05:26 | #846 | Link |
PgcEdit daemon
You can extract the audio from the original BD with tsMuxeR, or from the MKV created at step 1 with mkvtoolnix and gMkvExtractGUI.
Unless you want to keep a lot of subtitle streams, they are light enough to be ignored for the computation of the final file size. Just include them in the MKV in step 1. IMO, the major drawback with that method is that the 3D-Planes are lost during the re-encoding, and therefore the subtitles will not appear at the correct depth.
27th October 2016, 22:32 | #847 | Link |
Extracting any single stream, be it subs, audio or video, can be done with tsMuxer, but also mkvextractgui (I believe there are two forks or something, 1.6.4.1 and 2.2.2.9).
All the original and important streams are ripped in the first pass with MakeMKV, so subs should be at proper depth. Theoretically you could and any old stream to the mux to enlarge the file and influence the compression ratio, but using the same movie's stream avoids any type of mismatch with length or bitrate or resolution or what not. |
28th October 2016, 16:15 | #848 | Link |
I have a problem encoding with FRIM. If I encode files with FRIM via commandline the output shows many artefacts on Stereoscopic Player and after muxing to BD with TSMuxer on my Sony BDP. Does anyone have an idea what the problem could be?? This is an example command-line I use: FrimDecode -ts -i:h264 00800_3D.m2ts -o \\.\pipe\bdrb.yuv -sw |FRIMEncode -alt 2 -i \\.\pipe\bdrb.yuv -viewoutput -o::mvc "L:\zzz\VID_00000.AVS.264" "L:\zzz\VID_00000.AVS.mvc" -sw -w 1920 -h 1080 -f 23.976 -u 3 -cpbsize 3372 -l 6 -profile high -level 4.1 -vbr 35000 35000 -gop 24 4 0 O -maxdpb 4 Is there any error?? The artefacts are in both base and dependent view, but mostly in dependent view. I don't know what I'm doing wrong. Any help would be appreciated! Thanks! |
29th October 2016, 10:15 | #849 | Link |
PgcEdit daemon
Artefacts were frequent in old versions of the Intel decoder. The bug is fixed now, but if you have the right CPU and you are using an old Intel driver, it might be the culprit. Try to update your drivers or switch to software mode.
Note that this applies to the decoder. I don't know if the encoder has or had the same problem. And, IIRC, the artefacts of the MVC decoder were present in the dependent view only.
29th October 2016, 11:56 | #850 | Link |
Thanks @r0lZ!
I do not have an Intel CPU, therefore I'm already using Software mode. Interesting is that FRIM works fine for me if I encode BD50 to BD25 with BD-Rebuilder. However it is also not working if I encode SBS MKV to MVC with BDRebuilder. As I want to hardcode subtitles on my MVC encodes (in order to Keep depth), I can't use BDRebuilder. I encode to Alternate MKV with hardcoded Subs using your great tool BD3D2MK3D and now I wanted to encode this file to MVC using FRIM. This gives me the artefacts, I tried both FrimSource and FRIMDecode and also DircectShowSource (via avs2yuv). Everything gives me those artefacts.... If anyone has any further ideas I'd really appreciate it |
4th November 2016, 20:44 | #851 | Link |
Porting to linux ??
I know this is a Huge question: Is their any way for you (Videofan3d) to port this lib under Linux (Intel SDK is available under linux) or to make it open source (for the community to port it) Many thanks for reply Rgds |
10th November 2016, 20:21 | #852 | Link | |
I don't use any Linux distribution, and as far as I know, Adobe Premiere is not running on Linux - so there is no reason to port FRIM tools to Linux environment. |
16th November 2016, 00:04 | #854 | Link | |
Please note: - for MPEG2 encoding you can use HCEnc - it is free and probably better quality than Intel Media codec (does anybody still use MPEG2?) - for h.264 encoding you can use x264 - it is free and top image quality - for 3D-MVC ... there is no cheap or free 3D-MVC encoder on the market, but Intel Media, i.e. FRIM :-) Remark: Re-encoding and squeezing of original BD3D is nonsense! 3D video presentation requires BIG screen (80" is minimum, optimum is 100" and more). And big screen implies request for top image quality. Any re-encoding represents degradation - for what? for saving few GB diskspace?. Therefore I consider it wrong and useless approach. Therefore I don't see a reason spending an effort on porting FRIM to Linux. |
24th November 2016, 21:19 | #855 | Link | |||
Rgds |
encoders, mvc |
