Old 11th April 2017, 00:23   #14801  |  Link
FuzzyNutz
Encoding 7.1 lossless audio to 5.1 lossy
Is v1.19.6 configured to automatically mix in surround (rear) channels when encoding to AC3 or AAC 5.1 from a 6.1 or 7.1 lossless source?
FuzzyNutz is offline   Reply With Quote
Old 11th April 2017, 01:21   #14802  |  Link
nexxai
Probably a stupid question but if I wanted to do a test encode, is there a way to specify that I only want to render out, say, 5 minutes to make sure the quality is where I expect it? I just don't want to have to encode the whole thing, find out I chose a wrong setting, only to have to wait for a few more hours again.
nexxai is offline   Reply With Quote
Old 11th April 2017, 01:25   #14803  |  Link
FuzzyNutz
Create a small segment, perhaps 3 minutes, of the source file for your test using tsmuxer's "split & cut" option.
Old 11th April 2017, 01:29   #14804  |  Link
nexxai
I realize that Ripbot is not the "absolutely everything for everyone" solution, but I was really hoping this feature was already a part of the package, since it seems like it is so important to get an encode right.
Atak: Any chance I could request this as a feature?
Old 11th April 2017, 01:31   #14805  |  Link
FuzzyNutz
You just did.
Old 11th April 2017, 01:47   #14806  |  Link
soneca
Fresh install and the source used is blu-ray(structured folders).
Old 11th April 2017, 01:49   #14807  |  Link
burt123
burt123's Avatar
Originally Posted by soneca View Post
Atak, I made the update from Flac to version 1.3.2 and it works correctly with RipBot.
Did you get tested?
http://www.rarewares.org/files/lossless/
Which one did you use, and where to you put it ???
burt123 is offline   Reply With Quote
Old 11th April 2017, 02:01   #14808  |  Link
FuzzyNutz
I've since refreshed my install of ye olde maximus-Ripboticus v1.19.6 as well as it's external supporting software, yet .mkv and BD stucture sources with dtsma still don't appear in the audio selection box. I have to use the "..." to the right. TrueHD tracks are showing up in the audio selection, but they are coreless.
Old 11th April 2017, 02:04   #14809  |  Link
soneca
You have to use the 32-bit version, this one.
Replace or save the original by inserting the new one in tools>eac3to.
Old 11th April 2017, 02:08   #14810  |  Link
FuzzyNutz
I'm more interested in what "soneca" thinks "Atak" needed to get tested for.
Old 11th April 2017, 02:21   #14811  |  Link
soneca
English is not my language ... but from what I understand you say that when you select(demux) TrueHD it appears without a core?
Demux = integral = lossless. But with core, which can not be extracted in this case, only converted.
Old 11th April 2017, 02:30   #14812  |  Link
FuzzyNutz
I suspect the demuxed TrueHD tracks are now coreless for all Ripbot264 users. The GUI does not reflect this. Analyzing the .thd file in the jobx folder with MediaInfo or the likes, reveals this. I encourage you to try an example.
This isn't an issue unless you're creating a BD or AVCHD with the TrueHD stream, in which case, the core must be present. This can be overcome by a post-Ripbot remux using the stream from the original source.
Old 11th April 2017, 02:38   #14813  |  Link
burt123
burt123's Avatar
Thankyou
This is what is in the downloaded file:- libFLAC_dynamic.dll
But the one in tools'/eacto, is:- libFLAC.dll
What to do ??
Old 11th April 2017, 02:40   #14814  |  Link
soneca
@Atak,
If I add a job and resolve to quit by clicking "X" to close the window "Blu-ray Structure" RipBot freezes, does not close.
Old 11th April 2017, 02:42   #14815  |  Link
soneca
I'll compare the tracks taken from Ripbot264 and Eac3to.
Old 11th April 2017, 02:54   #14816  |  Link
soneca
Thankyou
What to do ??
Just rename it.
Old 11th April 2017, 03:24   #14817  |  Link
burt123
burt123's Avatar
Just rename it.
Old 11th April 2017, 04:57   #14818  |  Link
soneca
They are identical.
Old 11th April 2017, 05:02   #14819  |  Link
soneca
Problems demuxing the movie Suicide Squad... TrueHD?...
Old 11th April 2017, 06:52   #14820  |  Link
burt123
burt123's Avatar
Just loaded a DTS-HD MA 7.1 movie into v1.19.6, and it shows 8 channels, using Copy Stream. (also using Flac 1.3.2)
