Old 5th April 2006, 14:58   #1021  |  Link
HookedOnTV
Originally Posted by BetaBoy
Not to get to OT... but we also created a new Codec we call 'COSP' (internal name). It is a Panorama based codec... have a look.
DEMO #2 - COSP Panorama Codec DEMO... grab the picture and move it...
COSP Demo 1: http://tcpmp.corecodec.org/demo/first/
COSP Demo 2: http://tcpmp.corecodec.org/demo/second/
This older version still has the FireFox 'crash' after you go to the webpage... this has been fixed in newer version. As well as a new right click menu.
Javascript errors.
HookedOnTV is offline   Reply With Quote
Old 5th April 2006, 16:07   #1022  |  Link
BetaBoy
CoreCodec Founder
BetaBoy's Avatar
yeah... they are basic demos... we have more complex and simplistic examples in the works.
Dan "BetaBoy" Marlin
Ubiquitous Multimedia Technologies and Developer Tools
http://corecodec.com
BetaBoy is offline   Reply With Quote
Old 5th April 2006, 16:14   #1023  |  Link
Sirber
retired developer
Sirber's Avatar
Are you calling a website test a "codec"?
Detritus Software
Sirber is offline   Reply With Quote
Old 5th April 2006, 16:42   #1024  |  Link
SeeMoreDigital
Life's clearer in 4K UHD
SeeMoreDigital's Avatar
This is great fun....
Me thinks you need to start a new thread about it
SeeMoreDigital is online now   Reply With Quote
Old 5th April 2006, 16:51   #1025  |  Link
ChronoCross
Does it really matter?
ChronoCross's Avatar
This looks very similar to the way plone looks. With the exception of the navbar being on the right instead of left.
ChronoCross is offline   Reply With Quote
Old 5th April 2006, 19:05   #1026  |  Link
Abnormal1
I just tried to use one of the early releases of the ds filter and sadly it will not work with mplayer on XBMC. XBMC tries to use the codec but errors.
PHP Code:
05-04-2006 18:57:53 WARNING Unable to resolvekernel32.dll FlsAlloc
05
-04-2006 18:57:53 WARNING Unable to resolvekernel32.dll FlsGetValue
05
-04-2006 18:57:53 WARNING Unable to resolvekernel32.dll FlsSetValue
05
-04-2006 18:57:53 WARNING Unable to resolvekernel32.dll FlsFree
05
-04-2006 18:57:53 WARNING Unable to resolvekernel32.dll EncodePointer
05
05
05
05
05
05
05
-04-2006 18:57:53 WARNING Unable to resolvekernel32.dll DecodePointer
05
05
05
05
05
05
05
05
05
05
05
05
05
05
05
05
05
05
05
-04-2006 18:57:53 WARNING kernel32.dll fake function DisableThreadLibraryCalls called
05
-04-2006 18:57:53 ERROR cmplayer::openfile() smb://##.#.#.#/videos/test.mp4 failed
05-04-2006 18:57:54 ERROR Playlist Playerskipping unplayable item0path [smb://##.#.#.#/videos/test.mp4]
Abnormal1 is offline   Reply With Quote
Old 5th April 2006, 20:00   #1027  |  Link
BetaBoy
CoreCodec Founder
BetaBoy's Avatar
No, we have developed a new panorama codec called 'COSP'. The website is just a demo to show it off.
Old 5th April 2006, 20:07   #1028  |  Link
tomos
hi Dan, any guesstimates for updates to the codec? logged my probs on your site bug reports section (audio sync probs)
tomos is offline   Reply With Quote
Old 5th April 2006, 20:33   #1029  |  Link
Disabled
@Abnormal1 sad to hear it does not work out of the box. But I still have hope that the actual filter does work with it or may work in the future. Unfortunately I don't have a way to test this right now.
I Still would like to have an official statement here...
I did a quick and unfair speed comparison between VLC and CoreAAC.
252secs with AAC audio at 1Mbit/s (the video, not the audio) with every option Nero had to offer.
I just looked how many cpu-time was wasted by the two.
VLC used 1:48 min
MPC + CoreAAC + CoreAVC + Haali used 1:23 min
That results in a speed boost of 30% (or VLC is 25% slower, how you like it)
Quite impressive I think.
Does Nero ShowTime use its own filter? Just benched it and it took also 1:48 min to decode. So the clear winner is CoreAVC.
*edit*
DAMN! (Sorry) I'm able to watch this nice 720p Quicktime trailer. I first tried to play it in its .mov container, that sucked badly, but remuxed to .mkv it played flawlessly: 0 dropped frames, duration: 2:21 CPU-Time: 1:26 => average CPU load: 61% and that with an Athlon XP 2200+ 768MB Ram and sucky old GF2 TI 64MB
Disabled is offline   Reply With Quote
Old 5th April 2006, 21:54   #1030  |  Link
Abnormal1
Aparently mplayer's ability to use Directshow filters is limited so unless mplayer or CoreAVC are altered to work together it will never work.
Old 5th April 2006, 22:01   #1031  |  Link
Eretria-chan
If it works fine in other dshow apps, then it is mplayer's fault, yes? Then something should be done to mplayer.
Eretria-chan is offline   Reply With Quote
Old 5th April 2006, 22:10   #1032  |  Link
nm
Yes, MPlayer has its own DShow interface implementation which is partly based on Wine code. That enables the DShow filters to work on other x86 platforms like Linux, *BSD and probably OS X x86, and not only Windows. Since the interface is not complete and implements only specific parts of the full Win32 API, new binary-only filters usually need some coding work in the MPlayer's side. However, CoreAVC developers are probably more willing to work with the community than the codec manufacturers generally, so getting the filter to work should not be too difficult given some time and effort.
nm is offline   Reply With Quote
Old 5th April 2006, 22:53   #1033  |  Link
ravemax
mac'n'anime loveR
mplayer - coreavc: Since both mplayer and VLC are GPL, a easy way would be to write a stub, which loads CoreAVC using "dlopen". So at the end BetaBoy & Co only would have to release the source of the stub.
ravemax is offline   Reply With Quote
Old 5th April 2006, 23:10   #1034  |  Link
nm
That would be the way to do it, but getting that stub approved to the official MPlayer and VLC code might prove more difficult unless it is only an extension to an existing mechanism, like the DShow loader.
Old 6th April 2006, 05:21   #1035  |  Link
welew
Small bug of CoreAVC (0.0.0.4)
A small bug of CoreAVC (0.0.0.4 beta version):
1, when CoreAVCDecoder.ax put and registered in the non-english directory, it can not be called by filter-based player (MPC, Graphedit, ...)
2, registry entry would be modified to fix the problem, and i write a simple program to do it.
3, do not know CoreAVC commercial version already fixed it.
welew is offline   Reply With Quote
Old 6th April 2006, 13:44   #1036  |  Link
BetaBoy
CoreCodec Founder
BetaBoy's Avatar
welew while I apprecite that report... 0.4 was a test codec. Please only report 1.xx bug reports. You can do so on our bug tracker here:
http://corecodec.org/tracker/?atid=3...64&func=browse
Old 6th April 2006, 19:10   #1037  |  Link
breez
Sorry if this is a stupid question or one already answered, but what about the TCPMP AVC plugin? Is the "1.0" version of it already available and is it a separate purchase from the DS filter?
breez is offline   Reply With Quote
Old 6th April 2006, 19:24   #1038  |  Link
BetaBoy
CoreCodec Founder
BetaBoy's Avatar
CoreAVC will be a included with the FULL version of CorePlayer v1.0. We are pushing the launch to be in mid-may... atm we will launch with versions for Palm, CE, Symbian, and Linux.
Also... BetaPlayer 1.0 will likely be out sooner... We will also offer a 'codec bundle' for all the pay codecs for it as well.
Old 6th April 2006, 19:30   #1039  |  Link
Gnerma
Gnerma's Avatar
So is the plan for a "FFDSHOW like" all in one DirectShow decoding package? Or at least ASP, AVC, AAC, Vorbis and a few other formats?
Gnerma is offline   Reply With Quote
Old 6th April 2006, 20:35   #1040  |  Link
lexor
no windows?
Geforce GTX 260
Windows 7, 64bit, Core i7
MPC-HC, Foobar2000
lexor is offline   Reply With Quote
codec, coreavc, corecodec, coremvc, cuda, decoder, dxva, h.264, mvc, scam
