Old 12th June 2021, 13:46   #1741  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
Apparently you are using Windows 8.0, rather than Windows 8.1.
Window 8.0 has reached end of life in 2016, i.e. 5 years ago. Just update to Windows 8.1, which is essentially a Service Pack to Windows 8 and will be supported with security fixes by Microsoft until 2023.
At this point, I won't put any effort into testing or supporting Windows 8.0. The same applies to Windows 7 without SP-1, or Windows XP without SP-3.
(BTW: Please don't post ultra-large screenshots as attachments. It breaks the layout.)
Is There a Difference Between 8 and 8.1?
The answer is no, not really. Windows 8.1 is considered a service pack for Windows 8. This means Windows 8.1 is a part of Windows 8 and is included in that life cycle.
Old 12th June 2021, 16:16   #1742  |  Link
K4sum1
K4sum1's Avatar
8.0 is better than 7 and 8.1 in various ways. It has a better DWM than 7, but without the activation system of 8.1. It can be easily modded to use the 7 explorer, while 8.1 has buggy start menu replacements. It has the better performance of 8.x without the telemetry updates of 8.1.
Also, about support, 8.0 Embedded gets support until 2023 as well, and 8.0 embedded updates work on regular 8.0.
K4sum1 is offline   Reply With Quote
Old 12th June 2021, 18:30   #1743  |  Link
LoRd_MuldeR
Software Developer
Fell free to use whatever outdated and end-of-live operating system you like – it is you who has to live with the implications. I could go on to elaborate on how irresponsibly it is to use an end-of-live operating system. But I know that trying to "proselytize" notorious update refusers is a totally pointless endeavor. So, do what you want, but do not expect software developers to care about such super-exotic configuration. Windows 8.x generally is a lost cause, because it never gained much popularity and was quickly superseded by Windows 10. But Windows 8.0 without the Windows 8.1 service pack in particular is such a niche configuration that it's not worth bothering...
(BTW: You are the first person to ever try running this software on Windows 8.0, and report back. I think that says it all.)
Old 20th July 2021, 03:04   #1744  |  Link
shades
Dear LoRd_MuldeR
Latest nightly build LameXP-RC10.2021-06-27.Release-Static.Build-2316 seems to be broken on extraction of the file wvunpack.exe
Extracting file: wvunpack.x64-avx.exe -> wvunpack.exe
Failedto open file on first attempt, retrying...
QFile::remove: Empty or null file name
BaseTask exception error:
File 'lxp_curl.exe' could not be locked
GURU MEDITATION !!! <- (NICE! :-D AMIGA throwback?? lol )
shades is offline   Reply With Quote
Old 21st July 2021, 21:22   #1745  |  Link
LoRd_MuldeR
Software Developer
Originally Posted by shades View Post
Dear LoRd_MuldeR
Probably yet another case of "anti-virus" software gone nuts
If you run any "anti-virus" software, please turn it off (or, even better: uninstall) in order to confirm that the root cause of the problem indeed is a buggy "anti-virus" software. Then report the problem to then vendor.
(Should the problem persist after any "anti-virus" software has been eradicated from the system, then I may investigate further)
Old 23rd July 2021, 00:18   #1746  |  Link
shades
You are of course, correct.
Rotten Windows 10 simple pattern matching crap.
I placed an exception for the entire folder for MuldeR and it's frikken fine as.
thanks for the time in answering.
Old 12th August 2021, 19:01   #1747  |  Link
danlock
intent to support attached .webp album covers?
(title)
Details: @LoRd_MuldeR Do you intend to support .webp album covers in LameXP (so they will be transferred from the source to the destination file(s) for supported formats/containers)? If so, do you have a timeline or a version number in mind when that will be implemented?
Thank you very much!
danlock is offline   Reply With Quote
Old 14th August 2021, 19:22   #1748  |  Link
LoRd_MuldeR
Software Developer
Not currently planned. There are many open questions regarding WebP:
  1. Does Qt support the WebP format? I think Qt 4, which LameXP is currently based on, does not. Probably current Qt 5 does. But then, porting LameXP to Qt 5 will be a big project for the future
  2. Do the various audio formats that we support in LameXP support the WebP format in their meta data? For example, MP3 embeds meta data in the form of ID3 tags. And, to the best of my knowledge, ID3v2 "officially" only supports JPEG and PNG. Which is obvious, because at the time that ID3v2 was created WebP didn't even exist! And that's only MP3. What about all the other formats?
  3. Even if some of the audio formats that we support actually do support WebP in their meta data, do the encoders that we use support WebP as input? What do we do with the other formats?
Old 15th August 2021, 07:34   #1749  |  Link
danlock
Understandable. Thank you again!
Foobar 2000 can read .webp files in metadata (and add or remove .webp files as metadata). That was first implemented by pointing Fb2k to an external file, and later added internally (September 2000). That's a program which was coded from the ground up to support plugins and other features, though, and Peter can alter his code base or plugins to add/remove support for different things anytime. It's possible other players/encoders can read .webp metadata as well, but I can't think of any. I presumed any other relatively-decent player would discard the .webp image data as extraneous. A poorly-coded player, on the other hand, would see the "extra" data and crash or claim the file is bad, but (come to think of it) since metadata exists as a separate, resizable part of the file (whether as part of the audio file or in an external tag file), it probably just wouldn't be displayed.
As small as lossy .webp (and the next version, .webp2) files are compared to most other image formats with similar quality, it's a space savings to use .webp format in audio files (lossless .webp files obviously don't compress as much). For maximum compatibility and even more space, I should probably just use an external image in the directory and put only textual metadata in the files.
Support in QT seems to be the biggest hurdle. I had not considered that. Thanks for reminding me of LameXP's usage of QT!
Well, for the purposes of this forum and LameXP, the future is approaching at a fixed speed. End users like me will probably learn of support for any new formats whenever any porting to a newer version of QT occurs, since the tagging is typically handled by the external components for which LameXP provides the interface. And those decoder/encoder combinations that don't support .webp would output a file that doesn't contain the image, of course, like they already do.
Something will change when those included external decoders work for newer metadata or LameXP itself can copy metadata in (.webp/etc.) whatever formats are present in the file, in the future, whenever it happens.
Speaking of time, I've allowed far too much of it to march past me while I typed this message! (Muss los!)
Last edited by danlock; 23rd August 2021 at 22:18. Reason: minor details, reducing ambiguity (hopefully)
Old 29th August 2021, 19:09   #1750  |  Link
LoRd_MuldeR
Software Developer
LameXP v4.19 has been released
https://github.com/lordmulder/LameXP/releases/latest
Changes between v4.18 and v4.19 [2021-08-29]:
* Updated LAME encoder to v3.100.1-SVN (2020-08-25), compiled with ICL 19.1 and MSVC 15.9
* Updated Vorbis encoder to OggEnc v2.88 (2020-07-07), using libvorbis v1.3.7 with aoTuV beta-6.03
* Updated Monkey's Audio binary to v6.29 (2021-05-25), compiled with ICL 19.2 and MSVC 15.9
* Updated mpg123 decoder to v1.26.4 (2020-12-24), compiled with GCC 10.2.0
* Updated MediaInfo to v21.03 (2021-03-26), compiled with ICL 2021.2 and MSVC 15.9
* Updated cURL to v7.77.0 (2021-05-26), with libcurl v7.77.0 and OpenSSL v1.1.1k
* Updated the Windows SDK version used for release builds (Visual Studio 2017) to 10.0.14393.0
* Added Bulgarian (български) translation, thanks to Симеон Илиянов Цветков <sicvetkov@uni-sofia.bg>
* Added command-line switch --no-splash, which can be used to hide the "splash" screen at startup
* Added a workaround for missing normaliz.dll to the installer (Windows XP only)
* GnuPG has been replaced by CodeSign verification tool for checking the auto-update signatures
Old 31st August 2021, 16:58   #1751  |  Link
SeeMoreDigital
SeeMoreDigital's Avatar
Hi LoRd_MuldeR,
I've just tried installing the new release but for some reason Windows 10 Home (Version: 21H1, OS Build: 19043.1165) reports the following: -
Old 31st August 2021, 18:16   #1752  |  Link
LoRd_MuldeR
Software Developer
As a long term member, I probably don't have to explain to you what a FALSE POSITIVE is and who you need to report the problem in their software to, if you want a chance for this to be fixed
Also, I probably don't have to explain that even though cURL could be abused by "attackers" to do evil things (like pretty much any non-trivial program can be abused!) it still is a perfectly legitimate software that must not be blocked
See also:
http://lamexp.sourceforge.net/doc/Ma...ti-virus-notes
(Note: Since we have been through this a zillion of times, that is as much as I'm going to say about the topic)
Old 31st August 2021, 18:52   #1753  |  Link
jpsdr
For me, Kaspersky didn't like lxp_curl.exe created in temp directory when lamexp is running. Contacted them, confirmed as false positive, will be fixed very shortly in their database. I had to do the same exact same process for the exact same file with previous lamexp version, and probably will with next version...
But lamexp is very good at trigging false positive...
My github.
Old 1st September 2021, 19:22   #1754  |  Link
manolito
manolito's Avatar
Sorry for late replay. This has already been addressed for the upcoming release.
Thanks for the new version
The new behavior after starting the software when it is more than 1 yeaur old is very welcome...
Old 12th October 2021, 13:11   #1755  |  Link
K4sum1
K4sum1's Avatar
Is there no way to encode in ALAC?
Old 12th October 2021, 14:56   #1756  |  Link
SeeMoreDigital
See here: https://forum.doom9.org/showthread.p...59#post1859759
