26th December 2017, 18:27 | #2802 | Link |
can someone help me out with an issue, staxrip 1.7 specifically using x264 blurs the top and bottom of my encodes for some reason, I can't figure out what the issue is, grainy vids are the worse as the top and bottom few pixels in an encode are completely devoid of grain and stand out like a sore thumb... Any help is greatly appreciated, here are some pics which show the issue https://imgur.com/a/xJMmZ
27th December 2017, 21:51 | #2803 | Link |
@suprasaiyan123:
I can see the washed out borders. Please save your screenshots as png in the future. Because jpg compression adds all kind of artefacts to the picture. Did you crop or upscale the source file? Maybe a sample from the original and a mediainfo report? And your settings for x264. and, and, and..... Without any more information nobody will/can help you. |
28th December 2017, 15:42 | #2804 | Link | |
28th December 2017, 18:07 | #2805 | Link |
@suprasaiyan123
I can see the distorted lines on both = original and encoded file Did you try with different crop parameters or resizers? And why did you crop down to 816 ? Did you apply the black bars later on to go back to 1080? Your stills are perfect 1920/1080 16:9 (with the black borders). I dont think it is a encoder error. Your x264 settings should be almost transparent at crf 15. So we can sort this out. Any way, this has nothing to do with StaxRip. Maybe the avisynth or vapoursynth decoder faults on your sources. Without a sample of your source and your exact avisynth/vapoursynth script nobody can help you. And mediainfo report of source and encode might be beneficial. |
29th December 2017, 21:35 | #2806 | Link | |
30th December 2017, 23:36 | #2807 | Link |
I found awasharp2 ported from avisynth to vaporsynth. Can someone tell me the proper syntax so it would work in staxrip?
warp.AWarpSharp2(clip clip[, int thresh=128, int blur=2, int type=0, int depth=16, int chroma=0, int[] planes=<all>, bint opt=True])
3rd January 2018, 18:52 | #2809 | Link |
Happy new year Mark and everybody, I'm fine thanks. I'm not very exciting about coding at the moment, especially not with VB.NET/WinForms, if somebody 20 years younger wants to step in and maintain staxrip would be best because I don't encode much if anything, otherwise I will maintain it like I promised.
5th January 2018, 15:37 | #2811 | Link |
I jsut updated from the ancient 1.3.7.0 to the latest 1.7.0.4 version and now I'm missing the "Demux and index before creating jobs" options in the file batch menu. Is this on purpose or can I somehow manually enable this option again?
5th January 2018, 22:16 | #2812 | Link | |
Go to "Project" > "Templates" and select " Manual Workflow" Then go again to "Project " > " Save as Template " > and tick the " Load template on Startup " Option, and save. By default it is now set to "Automatic Workflow ", following the steps above and it will be back to manual mode like before |
6th January 2018, 09:26 | #2813 | Link | |
I even reset the templates to make sure I didn't mess anything up but still after adding files via Files Batch option it just creates a job but doesn't automatically demux and index the files before adding the job. |
6th January 2018, 13:28 | #2814 | Link |
Ah i think i understand now, still cannot see the screenshot you attached to your post, still pending approval,
for the batch mode it seems i can't trigger this either, using manual workflow, having the project option "Hide dialogs for demux" disabled like in the following picture : + still in the project settings, the demux options for video and subtitles set to "Show Dialog" but it skips the manual demuxing, not sure if it's on purpose for batch more or if I'm missing something obvious or else. For now you select batch mode and all is automatically processed once the jobs list is started it seems, not sure how it was done in older versions. Only Stax could answer this i guess :/ Last edited by Yanak; 22nd January 2018 at 23:30. |
6th January 2018, 14:47 | #2815 | Link |
Thanks again. Unfortunately it still won't work. Whether I tick the box from your screenschot or not it still just adds a job. I also set the Demux option on audio and subitles to "All" but still nothing.
Here are 2 screenshots to show which box I mean is missing: Old: New: It seems to be by design. Maybe one day when Stax has the time he can give a short answer or even release something new but until then we have to live with it. No biggie. |
10th January 2018, 14:06 | #2817 | Link |
Hi Stax
Happy New Year to you too. It's a bad thing that you're not going to continue, the support especially last year was sensational. I would be very happy if someone would find someone to continue the project. Even if it is only so far that the newest tools and versions are installed. I still need Staxrip every day and that won't change that soon. |
14th January 2018, 15:51 | #2819 | Link |
haven't touched StaxRip for about 4 weeks. I mainly use it to convert h264 1920x1080 50fps progressive material from Camcorder quick and dirty to h264 1280x720 50fps progressive. Using a template for NVEnc with hardware resizing. All over sudden video playback of the encoded files is stuttering. Using StaxRip-x64-1.7.0.4-test. The only thing I have changed are the GPU drivers. Didn't touch the Stax directory for weeks. Stuttering occurs on default NVEnc settings and modified ones. Older encodes with the same settings dont show this behaviour. Any help for troubleshooting is really appreciated. Trying newer/older nvidia GPU drivers for now. |
14th January 2018, 16:28 | #2820 | Link | |
