Old 31st August 2017, 18:01   #45281  |  Link
Asmodian
Originally Posted by cyber201 View Post
I select this profile, reboot the PC but when i start the video with 23.976 fps, I have always 1 frame repeat every 4.40 min.
Try starting with a different mode, perhaps CVT RB2 as nevcairiel mentioned.
With my display and GPU every set of timings after the first optimization pass measured worse then the first one. The first optimization of CVT RB2 got me to an estimated 18h before a frame drop but subsequent optimizations have measured as bad as 10 minutes. I think exact change in timings for a particular fps is not an exact thing, which is why madVR has to re-measure and re-tune after the first time.
Maybe let it play undisturbed for an hour or so as well, give madVR more time to get accurate measurement.
madVR options explained
Old 31st August 2017, 18:44   #45282  |  Link
cyber201
I have try to play two video for 2h and the stranger things is that the timing profile in the madvr custom table not is the same on video playback. I have find this issue when enable CTRL+J in playback mode and the Display Hz is different of the Display Hz set in the madvr custom mode profile.
It is like the settings are not saved.
If I try CVT RB1 or RB2, my TV screen is flickering.
I must start whit EDID profile.
cyber201 is offline   Reply With Quote
Old 31st August 2017, 19:44   #45283  |  Link
Asmodian
Hmm, that sounds like a driver issue or something. It definitely will not be correct if madVR is not switching to the correct refresh rate. By different do do you mean by 0.002 Hz, 0.1 Hz, or 30 Hz?
Old 31st August 2017, 19:57   #45284  |  Link
Siso
Siso's Avatar
Are these settings ok for downscaling? http://imgur.com/a/V5GBj
Old 31st August 2017, 20:41   #45285  |  Link
Asmodian
Absolutely, you can always trust madVR.
madVR's choices are all decent options relative to the quality selected for luma doubling. If you have a little performance to spare, but not enough to go to medium for luma doubling, you can try to turn it up a little but it is not important.
Old 31st August 2017, 20:43   #45286  |  Link
Siso
Siso's Avatar
I tried medium, and it jumped my rendering time with 4 ms...form 15 ms to 19 ms, I have turned error diffusion 1 for dithering, not sure if I see the difference between ordered dithering and error diffusion. Monitor is 8 bit.
Old 31st August 2017, 20:53   #45287  |  Link
cyber201
No, the display switch correctly to 23Hz but the refresh rate is always the same. Not apply the refresh rate of the custom config.
My display is always 23.95055 Hz.
What you mean "By different do do you mean by 0.002 Hz, 0.1 Hz, or 30 Hz?" ??
Old 31st August 2017, 21:09   #45288  |  Link
Q-the-STORM
As long as you stay under 41ms, you're good.... (Assuming 23.976fps content)
Q-the-STORM is offline   Reply With Quote
Old 31st August 2017, 21:13   #45289  |  Link
aufkrawall
If 8 bit gradients look normal on your display, consider error diffusion a pure waste of performance.
Old 31st August 2017, 21:17   #45290  |  Link
Siso
Siso's Avatar
Any images to test?
Old 31st August 2017, 21:20   #45291  |  Link
http://www.bealecorner.org/red/test-...ient-16bit.png
Old 31st August 2017, 21:21   #45292  |  Link
Siso
Siso's Avatar
I have to test it trough mpc-be? To see if madvr is showing banding?
Old 31st August 2017, 22:03   #45293  |  Link
el Filou
el Filou's Avatar
yes otherwise you're just testing Windows/your picture viewer
Edit: also, for the particular file that huhn posted, enable RGB48 output in LAV Video, or else you'll be testing LAV's dithering too.
HTPC: Windows 10 20H2, MediaPortal 1, LAV Filters/ReClock/madVR. DVB-C TV, Panasonic GT60, Denon 2310, Core 2 Duo E7400, GeForce 1050 Ti 461.92
Old 31st August 2017, 22:14   #45294  |  Link
Siso
Siso's Avatar
Thanks for the info, no banding with ordered and error diffusion, so I guess will push from low to medium, and leave ordered dithering.
Old 31st August 2017, 22:50   #45295  |  Link
StinDaWg
I am giving custom timings a try but it's not working with 59hz. I tried all the optimizations but it won't let me apply after testing. Says "gpu rejected this mode for unknown reasons".
23hz optimized timings works fine. Unfortunately I'm getting a frame drop every ~25 minutes on the default settings for 59hz.
Using GTX 960 and a Samsung plasma.
Any ideas?
StinDaWg is offline   Reply With Quote
Old 1st September 2017, 00:37   #45296  |  Link
Cruzader
I cant play 3D MVC properly when windows in on 4k Resolution. The output seems be so stretched and only shows the magnified upper left part of the video. Any suggestions?
Cruzader is offline   Reply With Quote
Old 1st September 2017, 01:25   #45297  |  Link
žd is not part of the UHD spec try it at 1080p.
Old 1st September 2017, 02:34   #45298  |  Link
Cruzader
it does work on 1080p. but my native resolution is 4k, it's a pain in the ass to keep resetting the resolution when watching 3D Movies
Old 1st September 2017, 02:51   #45299  |  Link
mrcorbo
madVR has an automatic resolution switching feature.
mrcorbo is offline   Reply With Quote
Old 1st September 2017, 05:45   #45300  |  Link
Cruzader
Ummmm... im an idiot, how do I enable this?
