14th March 2009, 07:56 | #2041 | Link |
what? you just double click on the audio you want, and it adds it. or, in the settings, make sure you have 'limit to one track for each language' unselected, and then it will automatically add all of the different audio for your specific language.
14th March 2009, 09:00 | #2042 | Link | |||
As rmeyers is stating, you could've simply disabled that 2 channel English audio and enabled the TrueHD English stream...
MBK |
14th March 2009, 09:59 | #2043 | Link | |
I can see from the graphic he loaded that it was there -- only not selected. All that would take is a single double-click (or unchecking "Limit to One Track for each language"). Last edited by jdobbs; 14th March 2009 at 10:05. |
14th March 2009, 12:59 | #2044 | Link | |
Brick wall! Last edited by Furiousflea; 14th March 2009 at 13:03. |
14th March 2009, 13:33 | #2045 | Link | |
14th March 2009, 14:48 | #2046 | Link | |
14th March 2009, 18:33 | #2049 | Link | |
14th March 2009, 19:47 | #2050 | Link |
After previously blaming all x264 failures on bad rips, I now have one which is puzzling me, and my detection method. I have a rip of 300 which I was doing full disc, and on an extra it gave the 'x264 stopped working' message. I identified the stream and played it with MPC and sure enough it was blocky and pixelated. Normally I would re-rip it but in this case I double checked by playing the rip with powerdvd. It was perfect and no sign of any damage. Given this I tried to resume the job but I still get x264 errors, although typically at different percentages through.
Am I missing something obvious? |
14th March 2009, 20:01 | #2051 | Link | |
300 was released at the same time as HD DVD version. Virtually all HD DVDs were encoded completely (including extras) in VC1. So basically I bet that the only difference between 300 on bluray is that it has PCM audio on Bluray. What you describe is classic symptoms of interlaced VC1 content. PowerDVD can play it fine because it has the nessacary inbuilt decoder to decode it correctly, however this decoder is not available outside the program as a direct show filter or whatever so that is why... PowerDVD - plays fine Generic media player using ffdshow codec - blocky mess Edit - just because the extras play as a blocky mess doesn't mean it's a bad rip. They could be interlaced VC1 - or a bad rip. I dunno, I've ripped a fair few blurays and NONE have been "bad rips". The only bad rips I hear of are when the scene release groups get ahead of themselves and upload some crap to usenet with the BD+ protection still on the disc (usually just after BD+ has been updated and AnyDVD HD hasn't). Most "normal" people wouldn't get hold of the disc before AnyDVD HD has been updated to support it anyway. Bad rips are ridiculously rare unless you have some faulty memory\hard drive on the blink. If you're getting them often to a "chkdsk" scan and see what turns up, bad sectors can be marked as bad and you can still use the drive as normal if that is the case. Failing that run "memtest" from a bootable CD and check your memory...Finally if you have got a disc much earlier than release date and it's not working wait for an AnyDVD HD update. Slysoft release updates in their forum before the final releases as stop gap measures. Last edited by Furiousflea; 14th March 2009 at 20:06. |
14th March 2009, 20:48 | #2053 | Link | |
14th March 2009, 21:46 | #2055 | Link | ||
Nobody's fault at all... we've all had those moments datman... sometimes if the answer is too simple we tend to overlook it because we are looking for something complicated as the answer...lol . I'm sure we've all done that. Anyways, furiousflea could easily add screenshots to his guide, that would help more for some.... That would free up JD's time to continue his modifications to the awesome BD-Rebuilder he has created for us...
MBK |
14th March 2009, 23:07 | #2057 | Link | |
14th March 2009, 23:18 | #2058 | Link |
Which build of PowerDVD 8 do you have? The latest build, 2217, which I downloaded directly from Cyberlink 3 days ago doesn't have this problem. Though the build 2521 that is available mainly in torrents have the exact problem you are describing.
14th March 2009, 23:28 | #2059 | Link | ||
I am not sure if my problem is similar to datman's, but with one of the earlier versions (0.18.xx) of BD-RB and a couple of blu-ray that I tested, the audio could not be enabled with mere double clicks. The DTS-HD was simply not on the list of audio options. Unfortunately I forgot which movie it was. I have made many more backup copies since then. Quote:
15th March 2009, 00:03 | #2060 | Link |
We all still have to report what we think are bugs..... if it turns out to be user inflicted, then no worries, easy to fix right...lol
I remember having an issue with The Secret Life of Bees, and reported it as a bug, was kinda pffffttt at because it seemed that there was no way it could be like I reported. However it was, that BD had two main movie playlists, but each with completely different audio streams (both English Multichannel DTS-HD) that could not match up if crossed... and I had chosen the first audio stream but the longer second playlist was chosen by BD-RB... the result was some of the content woith completely wrong audio... When I went back and selected the second main audio stream, with BD-RB choosing the second main movie playlist, the audio then matched up. Completely unique to this Bluray, I reported it as a bug and was in a way accused of pre-processing but I hadn't, ended up that it was indeed an issue if Blurays were authored in this way...... I had to be sure to select the correct main audio stream to match up with the playlist BD-RB chose. So don't feel squemish about reporting what you feel might be a bug, it's the only way to rule it out. Even if it ends up being something you could've fixed yourself, betterr than not saying anything and continuing to live with something that could very easily be adjusted... BTW, I didn't mean to come across as harsh, if I sounded that way, my apologies... I was just mentioning that it was pretty easy to fix. Cheers
MBK |
