13th January 2011, 21:06 | #61 | Link |
Here is what I use: arcdec185 (Archive password: doom9) I don't take any credits for stolen shłt, but the batch files were created by bobdynlan. (Thanks!)
It contains every decoders. Some of them can be useful too, the video decoder is very flexible (DXVA 1/2, CUDA, StreamSDK, support, etc). Run the Put_TMT2 to get the TMT2 files and optionally run the Put_TMT3 to update the filters to TMT3 versions. |
13th January 2011, 22:46 | #63 | Link |
TMT3.0.1.185
i got a real problem with 24bit here to... if i check ArcSoft audio decoder hd or reclock it says 16bit but if i enable "32 bit integer" (and 24bit is always enabled) in ffdshow output i get 32bit in reclock but i have NEVER seen it show 24bit if if ffdshow is set enabled for 24bit in and out. and yes this time it is a 96/24bit source.
Gigabyte G1.Sniper Z87, I7 4770K (3.5ghz), Gigabyte Radeon 280x, Win8.1 x64, ATI 15.7.1, MPC-HC BE 1.4.6 1478, MadVR v0.90.21, LAV Filters 0.68.1, XySubFilter 3.1.0.746 |
13th January 2011, 23:15 | #65 | Link |
I still have a problem using the TMT2 then updated TMT3 dlls. Still not getting 24bit in DirectSound.
Filter : DirectSound: Speakers / Headphones (IDT High Definition Audio CODEC) - CLSID : {79376820-07D0-11CF-A24D-0020AFD79767} - Connected to: CLSID: {1A89085B-B654-4ED8-8831-5AC629A05FF5} Filter: ArcSoft Audio Decoder HD Pin: XForm Out - Connection media type: Audio: WAVE_FORMAT_EXTENSIBLE 48000Hz 6ch 4608kbps AM_MEDIA_TYPE: majortype: MEDIATYPE_Audio {73647561-0000-0010-8000-00AA00389B71} subtype: MEDIASUBTYPE_PCM {00000001-0000-0010-8000-00AA00389B71} formattype: FORMAT_WaveFormatEx {05589F81-C356-11CE-BF01-00AA0055595A} bFixedSizeSamples: 1 bTemporalCompression: 0 lSampleSize: 4608 cbFormat: 40 WAVEFORMATEX: wFormatTag: 0xfffe nChannels: 6 nSamplesPerSec: 48000 nAvgBytesPerSec: 576000 nBlockAlign: 12 wBitsPerSample: 16 cbSize: 22 (extra bytes) WAVEFORMATEXTENSIBLE: wValidBitsPerSample: 16 dwChannelMask: 0x0000003f SubFormat: {00000001-0000-0010-8000-00AA00389B71} pbFormat: 0000: fe ff 06 00 80 bb 00 00 00 ca 08 00 0c 00 10 00 þÿ..€»...Ê...... 0010: 16 00 10 00 3f 00 00 00 01 00 00 00 00 00 10 00 ....?........... 0020: 80 00 00 aa 00 38 9b 71 €..ª.8›q - Enumerated media type 0: Audio AM_MEDIA_TYPE: majortype: MEDIATYPE_Audio {73647561-0000-0010-8000-00AA00389B71} subtype: TIME_FORMAT_NONE {00000000-0000-0000-0000-000000000000} formattype: TIME_FORMAT_NONE {00000000-0000-0000-0000-000000000000} bFixedSizeSamples: 1 bTemporalCompression: 0 lSampleSize: 1 cbFormat: 0 |
13th January 2011, 23:33 | #66 | Link |
i have not tested the dansrfe uninstaller. but i removed the files from syswow64 and dts-ma decoding stopped to work so i restarted then installed 185 again and it worked in every other aspect. (wasapi and so on.)
13th January 2011, 23:45 | #67 | Link |
im not 100% sure if this is related but check this out: http://forum.doom9.org/showthread.ph...41#post1367141
14th January 2011, 00:15 | #68 | Link | |
14th January 2011, 00:22 | #69 | Link | |
So, I suggest you to do this: - Use dansrfe's uninstaller. (No matter if you think you deleted every files, just do it!) - Use the uninstaller from "my" package (Again, just do it!) - Use the Put_TMT2 and Put_TMT3 from "my" package. (In this order.) And I forgot to include a batch file to re-register your actual filter (may be necessary to work until all those uninstalls...). Place a whatever.bat file in your */Program Files (x86)/Common files/Arcsoft/MPEG Engine, and fill it with these lines and run it: Code:
@echo off if not exist ASAudioHD.ax goto no_codec echo ASAudioHD.ax found. echo Unregistering ASAudioHD. regsvr32 /u /s ASAudioHD.ax echo Registering ASAudioHD. regsvr32 ASAudioHD.ax echo Done. goto end :no_codec echo ASAudioHD.ax was not found! :end I think you should use ReClock to downmix the channels, it can do it just fine. |
14th January 2011, 00:22 | #70 | Link |
bjd: that could not be optimal?
14th January 2011, 00:28 | #71 | Link |
Janos666: i will give it a try but just so you know.. (in 20min)
14th January 2011, 01:46 | #72 | Link |
Janos666: i gave your solution a try and with the same results i still have sound and reclock tells me "48000 Hz, 2 channel(s), 32 bits PCM" and if i deselect 16bit and 32bit in ffdshow output i get a WASAPI error "initialize wasapiclient failed unknown error 8889000f"
and back to reclock says part: "48000 Hz, 2 channel(s), 32 bits PCM" that is just ffdshow making a mess.... (no prof that i got 24bit, is it?) is there another way to know for sure?
14th January 2011, 02:13 | #73 | Link |
oh and another thing.... over att slysoft (reclock) there is a installation warning...
Note: * ReClock must be installed *after* PowerDVD or Arcsoft TMT 3/TMT 5 * Whenever PowerDVD or Arcsoft TMT 3/ TMT 5 is updated or reinstalled, ReClock must be reinstalled * ReClock replaces the ASAudioRenderer.dll in the TMT 3/ TMT 5 Codec directory. A backup ASAudioRenderer_bak.dll will be created. Do not delete this file, it is required! is that just for usage inside the program TMT3/TMT5? or is this important for us?
14th January 2011, 02:31 | #74 | Link | |
I have similar setup like you, but dont use Haali ( will explain why ), but the new LAVFsplitter. I have 99percent of all videos in m2ts container. Now, what works in lavfsplitter/arcsoft/madvr/wasapi/reclock 24bit mode is: VC-1 + DTS-HD or TrueHD or DTS or AC3 H.264 +DTS-HD or TrueHD or DTS or AC3 For example I have a VC-1 video with one DTS-HD stream. Reclock info: 23.976 fps, 1920x1080p, YV12 12 bits 48000 Hz, 6 channel(s), 24 bits PCM Video: madVideoRenderer Audio: WASAPI excl. Arcsoft Pin info (I assume its showing correctly) gives this: Pin: Audio - Connection media type: Audio: DTS 48000Hz 6ch 1536kbps And then when I look into Reclock Pin info table I see: Pin: Out - Connection media type: Audio: WAVE_FORMAT_EXTENSIBLE 48000Hz 6ch 6912kbps Bugs of LAVFsplitter in madvr mode, which I experience: - using LAVFsplitter, if m2ts does have PGS subtitles, it causes crashing of MPC-HC at startup ( confirmed also in evr cp mode ) - seekbar remaining time bug ( will have to find out if its a ffmpeg issue in ffdshow video dec or its a splitter bug, I think splitter ). Movie simply does not show correct lenght in the seekbar ( only first minutes or so, then continues ). Internal MPC-HC splitter shows correct lenght/remaining time at its seekbar. - LPCM audio streams ( can not find out how to connect them to the Arcsoft decoder ) -LAVsplitter does not connect them to Arcsoft HD audio decoder, ffdshow audio decoder steps in, but the result is diginoise and reclock changes automaticly to directsound ( because its in wasapi mode and ffdshow does not work in wasapi 24bit output decoding mode as Arcsoft can provide ). Using internal MPC-HC splitter - ffdshow audio steps in, but the result is downpitched sound with interruptions ( can someone help me with this? ) 2 questions: - how can you see DTS HD MA using Haali splitter, when Haali as a splitter can not see DTS-HD at all? - you mentioned LPCM, how did you manage ( using whatever splitter ) to get connect the LPCM audio stream to Arcsoft decoder and output in 24bit mode with full bitrate? Thanks Pluto Last edited by Plutotype; 14th January 2011 at 02:33. Reason: grammar |
14th January 2011, 03:05 | #75 | Link | |
I think ReClock sabotage the ArcSoft renderer so he can step on it's place. |
15th January 2011, 19:51 | #76 | Link | |
15th January 2011, 20:47 | #77 | Link |
This is all bs. The point of ArcSoft or the reason why everyone wants to use it is for one simple reason. To decode the audio as is, without alteration. After that whatever it goes to should be the decision of the user. madshi needs to release his algorithm that controls ArcSoft to decode the audio as is for eac3to, without manipulation.
29th January 2011, 18:17 | #78 | Link |
Well using the arcdec185.7z and the hex editing of mpc-hc, I can use arcsoft hd audio to decode dts-hd My only query is, when checking the pin info for arcsoft audio decoder while mpc-hc is playing, the Pin In says
Audio: DTS 48000Hz 6ch 1509kbps while the pin out says Audio: PCM 48000Hz stereo 1536kbps But ffdshow and reclock which come after it both say 48000 Hz, 6 channel, 24bit. Is the pin out info of the arcsoft decoder wrong? The decoders gui shows 16bit selected from a combo box, yet it is outputting 24bit according to ffdshow / reclock.. |
29th January 2011, 20:23 | #79 | Link |
anybody can explain me if we can decode dts-hd audio stream or not with analogical output (without bitstream) and mpc-hc?
If yes, how? I ask that because I don't understand the discussion into the 4st pages; PS: I don't use reclock but I use mpc-hc and ffdhsow video and audio decoder. |
29th January 2011, 20:57 | #80 | Link | |
decoding, dts-ma |
