Old 21st September 2021, 19:18   #181  |  Link
ReinerSchweinlin
I have a small request:
When batch transcoding, would it be possible to set "autogain" so every audio is normalized?
Thanx for considering !
Old 10th October 2021, 19:40   #182  |  Link
JeffStronger
Hello, where can I choose 10bit color rendition, with nvenc encoding?
JeffStronger is offline   Reply With Quote
Old 12th March 2022, 01:18   #183  |  Link
Fishman0919
FishmanMod Android Dev
Fishman0919's Avatar
-pix_fmt yuv420p10le
Put the above code in the "Params:" line and set profile to main10
"Cinderella story, out of nowhere,
former greenskeeper, now about
to become the Masters champion.
It looks like a mirac- it's in the hole!"
Fishman0919 is offline   Reply With Quote
Old 8th November 2022, 09:19   #184  |  Link
mdalacu
mdalacu's Avatar
Originally Posted by Fishman0919 View Post
Attachment 18062
And you can save it as a profile for a later more convenient use.
mdalacu is offline   Reply With Quote
Old 8th November 2022, 09:35   #185  |  Link
mdalacu
mdalacu's Avatar
Hi! Version v2.4.6 is up. Some bugs fixed and a new metadata import options, useful for bulk convert when you need to preserve creation_time of files for example. It will import metadata from fist added file.
For windows look for dmMediaConverter_v2.4.6_w32_ff64.zip in drive folder.
For linux just overwrite de executable with the one in GDrive without extention.
http://dmsimpleapps.blogspot.com/201...converter.html
Please provide feedback.
P.S. I highly recommend to use ffmpeg binarys form JellyFin media library.
https://repo.jellyfin.org/releases/s...dows_win64.zip
https://repo.jellyfin.org/releases/s...fmpeg/5.1.2-4/
For linux install the deb and create simlinks so the ffmpeg and ffprobe appear in the folder indicated in "Options/Latest".
Old 9th November 2022, 07:39   #186  |  Link
mdalacu
mdalacu's Avatar
It will be present in v2.5.0.
Old 18th November 2022, 22:02   #187  |  Link
ReinerSchweinlin
fantastic You are back
dmmediaconverter still is one of my favourites when it comes to fast & easy batch conversions.. Since I recently got an ARC770, I am looking into QSVENC now. Last time I cheched, QSVENC from rigaya was supperior in quality than the ffmpeg implementation - but if its en par now.... then I am looking forward to blazingly fast batch encoding with dmmeediaconverter ...
Old 21st November 2022, 19:01   #188  |  Link
jones1913
random user
Hi, another great addition would be a more fine control over bulk audio encoding.
For example:
Track 1 -> copy
Track 2 -> AC3
Track 3 -> AAC
It is currently not possible if im not mistaken.
BeHappy Audio Transcoder > <Doom9 forum> <Gleitz forum> <GitHub>
MP4.tool GUI for MP4Box & L-SMASH muxer > https://www.mediafire.com/folder/3i6y6cbkyhblm/MP4.tool
jones1913 is offline   Reply With Quote
Old 24th November 2022, 15:02   #189  |  Link
Fishman0919
Audio Request
It would be nice to be able to use fdk-aac if the FFmpeg used contains it.
Old 25th November 2022, 08:58   #190  |  Link
manolito
manolito's Avatar
Hi Fishman,
long time no see, good to hear from you after a long time...
After a stroke last year I am no longer the smart person I used to be, but I try to find my way back step by step. And your request for the Fraunhofer AAC encoder for dmMediaConverter sounds pamiliar to me. This AAC codec is way better than the standard AAC encoder, it just cannot be included in standard distributions due to the incompatible Fraunhofer license.
The latest version with complete documentation is here:
https://files.videohelp.com/u/172211...aConverter.zip
And Reino´s FFmpeg versions are here:
https://rwijnsma.home.xs4all.nl/files/ffmpeg/?C=M;O=D
Good luck and cheers
Manolito
Last edited by manolito; 15th February 2023 at 18:53. Reason: Updated to the latest version 14th February 2023
Old 25th November 2022, 10:47   #191  |  Link
mdalacu
mdalacu's Avatar
For example:
Track 1 -> copy
Track 2 -> AC3
Track 3 -> AAC
Sorry, but this is not on my TODO list.
Way to much work to implement it.
Old 25th November 2022, 10:50   #192  |  Link
mdalacu
mdalacu's Avatar
Search for dmMediaConverter.ini and in [GENERAL] section add this line or modify it to look like this:
AudioEnablelibFDK=1
Usually the configuration file is here:
c:\Users\xxx\AppData\Local\dmMediaConverter\Config\
I hope it helps.
Old 26th November 2022, 02:03   #193  |  Link
Fishman0919
AudioEnablelibFDK=1
I hope it helps.
Thank You... should have been the first place I looked
Old 26th November 2022, 02:14   #194  |  Link
Fishman0919
Originally Posted by manolito View Post
Hi Fishman,
I uploaded a quite recent version from Jan. 2022 here:
https://files.videohelp.com/u/172211/Fishman.zip
Some more info:
https://forum.doom9.org/showthread.p...72#post1894872
The slightly older version with complete documentation is here:
Manolito
Nice hearing from you also... and Thank You for the links.
Sorry to hear about your stroke and glad you are doing better my friend.
The reason I ask is because I have been building my own FFmpeg with fdk-aac for awhile now and sometimes I just don't feel like writing a script for encoding a movie. I've been using dmMediaConverter for awhile and the only reason I stopped was the lack of fdk-aac support. I should have asked sooner or maybe just looked a little.
Old 26th November 2022, 08:00   #195  |  Link
manolito
manolito's Avatar
Thanks Fishman for the kind words...
Maybe a short note about how I modified the original script to remove the default low cutoff frequeny of 14 kHz because I believe that the Fraunhofer codec handles HF up to 18 kHz just fine:
@ECHO off
REM Must be compiled in Console Mode
SET FF_DRIVE=%~d0
SET FF_PATH=%~p0
%FF_DRIVE%
CD "%FF_PATH%"
SET ORIGINAL=%*
ECHO.%ORIGINAL% | %SYSTEMROOT%\system32\FIND /C "libfdk_aac" /I
IF ERRORLEVEL 1 goto quit
SET ORIGINAL=%ORIGINAL:!=_$$§§$$_%
SETLOCAL EnableDelayedExpansion
FOR /L %%a IN (0,1,9) DO SET ORIGINAL=!ORIGINAL: -vbr:a:%%a 4 = -vbr:a:%%a 4 -cutoff 18000 !
FOR /L %%a IN (0,1,9) DO (
    FOR %%b IN (128 160 192 224 256 320 384 448 512 576 640 768 960 1152 1344 1536) DO (
        SET ORIGINAL=!ORIGINAL: -b:a:%%a %%bk = -b:a:%%a %%bk -cutoff 18000 !
Setlocal DisableDelayedExpansion
SET ORIGINAL=%ORIGINAL:_$$§§$$_=!%
:quit
_ffmpeg.exe %ORIGINAL% 2>&1
From the FFmpeg Wiki: https://trac.ffmpeg.org/wiki/Encode/AAC
Note: libfdk_aac defaults to a low-pass filter of around 14kHz (http://wiki.hydrogenaud.io/index.php..._AAC#Bandwidth). If you want to preserve higher frequencies, use -cutoff 18000. Adjust the number to the upper frequency limit only if you need to; keeping in mind that a higher limit may audibly reduce the overall quality.
I use this setting for some time now without ever experiencing any problms.
Cheers
manolito
Old 26th November 2022, 17:55   #196  |  Link
Fishman0919
@ECHO off
REM Muss im Console Modus kompiliert werden
SET FF_DRIVE=%~d0
SET FF_PATH=%~p0
%FF_DRIVE%
CD "%FF_PATH%"
SET ORIGINAL=%*
:quit
Note: libfdk_aac defaults to a low-pass filter of around 14kHz (?details). If you want to preserve higher frequencies, use -cutoff 18000. Adjust the number to the upper frequency limit only if you need to; keeping in mind that a higher limit may audibly reduce the overall quality.
Cheers
manolito
Thank You kind sir....
Old 10th January 2023, 08:40   #197  |  Link
manolito
manolito's Avatar
This post is over 2 months old, any ETA for v2.5.0?
One thing I could not figure out. Is there an easy way to add chapters (only simple chapters after a fixed time) within dmMediaConverter? I cannot find any option to do that, so I always use a different software (MkvToolNix) to achieve this in another conversion step.
Thanks again for this very useful software, I use it almost every day...
Cheers
manolito
Old 11th January 2023, 08:25   #198  |  Link
mdalacu
mdalacu's Avatar
Cheers
manolito
Hi. Sorry but no chapter editor yet...i have never used chapters ...
Please test autogain and provide feedback.
Just overwrite the exe file with "dmmediaconverter.exe" from here:
https://drive.google.com/drive/folde...9A&usp=sharing
Thx
Old 11th January 2023, 17:48   #199  |  Link
manolito
manolito's Avatar
I do need chapters to make up for some stupid players which provide no way to navigate within longer clips.
Not sure what exactly you want me to test...
I tested three different clips. First I let the software determine the peak levels and determine the correction value. Then I started the encode and grabbed the ffmpeg command line. The results were identical for all three source files between the latest test version and the older version 2.4.1 . Hope this helps...
Cheers
manolito
Old 11th January 2023, 18:06   #200  |  Link
mdalacu
mdalacu's Avatar
Cheers
manolito
Hi!
Just to be clear, we are talking about Bulk mode, right?
Thanks!
ffmpeg, frontend, gui, handbrake, linux
