14th May 2022, 08:37 | #21 | Link |
I decided to compare two different methods in the Grayworld filter. If you do not look closely, the difference is almost not noticeable. Or I am doing something wrong again.
so = DSS2("C:\test\underwater.mkv", fps=30.000) #========================================================== v1 = so.ConvertBits(32) v1 = v1.z_ConvertFormat(pixel_type="RGBPS", colorspace_op="709:709:709:f=>rgb:linear:709:f") v1 = v1.grayworld(cc=0) v1 = v1.z_ConvertFormat(pixel_type="YUV420", colorspace_op="rgb:linear:709:f=>709:709:709:l") #========================================================== v2 = so.ConvertBits(32) v2 = v2.z_ConvertFormat(pixel_type="RGBPS", colorspace_op="709:709:709:f=>rgb:linear:709:f") v2 = v2.grayworld(cc=1) v2 = v2.z_ConvertFormat(pixel_type="YUV420", colorspace_op="rgb:linear:709:f=>709:709:709:l") #========================================================== StackHorizontal(so.AddBorders(0, 0, 0, 20).Subtitle("Source", align=2), \ v1.AddBorders(0, 0, 0, 20).Subtitle("grayworld(cc=0)", align=2), \ v2.AddBorders(0, 0, 0, 20).Subtitle("grayworld(cc=1)", align=2)) Test video: underwater Comparison: underwater_test |
16th May 2022, 02:26 | #22 | Link |
@Arx1meD
I don't think you're doing anything wrong. I tried the 2 modes with the "corals" image from here: https://www.eng.tau.ac.il/~berman/Un...orRestoration/ The difference in this image is not day and night but it is visible. Maybe with certain images the difference is very small. For what it's worth, asd updated the docs and added this to the median mode: "This mode is not affected by extreme values in luminance or chrominance." |
4th September 2022, 17:17 | #24 | Link |
Cork_os, I think not.
Maybe create a clip with compensation for movement. Something like that: Code:
function MC_Clip(clip clp, int "blksize", int "overlap", bool "chroma", bool "truemotion", bool "global") { blksize = Default(blksize, clp.Width()<=720?16:32) overlap = Default(overlap, blksize<=16?2:4) chroma = Default(chroma, true) truemotion = Default(truemotion, true) glob = Default(global, true) sup = MSuper(clp, hpad=8, vpad=8, pel=1, sharp=2, chroma=chroma) bvec1 = MAnalyse(sup, isb=true, blksize=blksize, overlap=overlap, divide=0, delta=1, plevel=0, truemotion=truemotion, global=glob, chroma=chroma) # backward vectors fvec1 = MAnalyse(sup, isb=false, blksize=blksize, overlap=overlap, divide=0, delta=1, plevel=0, truemotion=truemotion, global=glob, chroma=chroma) # forward vectors backw1 = MFlow(clp, sup, bvec1) forw1 = MFlow(clp, sup, fvec1) Interleave(backw1, clp, forw1) } MC_Clip(blksize=32, overlap=16, chroma=true, truemotion=true, global=true) # Your filters are here! SelectEvery(3, 1) |
ffmpeg, filter, grayworld |
