17th April 2009, 11:54 | #161 | Link |
Other 1920 x 1080p movies have been okay. When I played the video after uncropMKV there was no video. The file mkv file size was a little larger than DTS audio file. What I had to do was resize to 1280 x 720. That worked fine. Took about 3 hours to complete. Gary |
18th April 2009, 08:21 | #164 | Link | |
Programmer (or just 教务长)
19th April 2009, 14:21 | #166 | Link |
It should be used by mkvmerge to create a mkv file... don't you have an -uncropped.mkv in the output folder?
if not - use tsmuxer or mkvgui and add this .264 file.. add audio and you're done. Do you have the full download and mkvmerge in \tools folder? |
19th April 2009, 19:47 | #169 | Link |
Yes, you need to disable all pre/post processing in ffdshow...
Just start your movie and right-click on the ffdshow icon and click on subtitles to disable the plugin... them run uncropmkv and it won't show them. |
19th April 2009, 22:40 | #170 | Link | |
One other question, i have a problem, after i put the files in AVCHD format normaly they "grow" and will not fit in a DVD5 or DVD9 like the original MKV. How can i calculate the bitrate for the resulting file? |
20th April 2009, 08:01 | #171 | Link |
uncropMKV usually creates a bit smaller MKV that after converting to m2ts fits... It depends on your audio but usual overhead is about 7%. RipBot can help you with bitrate calculation.
21st April 2009, 17:15 | #172 | Link | |
388,341 movie.mkv 5,005,056,235 movie.264 I tried tsmuxer with both files but the output was unplayable? Last edited by odwoh; 22nd April 2009 at 08:21. |
21st April 2009, 17:22 | #173 | Link |
Run it again and watch what's going on... There may be x264 exception error and it stops encoding... may be you didn't download the full package... may be your PC is too weak and you don't have enough memory.
21st April 2009, 20:49 | #176 | Link | |
Did download full package Progress of sorts. Tried it on another .mkv movie and got: 6,710,532,196 movieX.mkv 5,226,904,567 movieX.264 Ran the cropped .mkv and it works and looks/sounds great. I then ran tsmuxer 1.9.9 to output avchd folders. But when I play the movie its now in 4:3 aspect and theres no sound!?? Last edited by odwoh; 22nd April 2009 at 08:20. |
22nd April 2009, 08:03 | #179 | Link | |
avchd, bdmv, compliant, mkv, multiavchd |
