Old 28th August 2008, 22:23   #61  |  Link
SeeMoreDigital
Life looks better in UHD
SeeMoreDigital's Avatar
Originally Posted by stax View Post
For those who wonder why I often use the TreeView instead of real controls, reasons are: Every option requires a single line code only so it helps to fight bloat, it's quick and easy to code, easy to maintain, easy to change, easy to extend and automatically clean and polished.
Yep.... I prefer this way too!
Old 28th August 2008, 22:46   #62  |  Link
DigitAl56K
Latest StaxRip beta has DivX H.264 support. Compressibility check is missing because there is no constant quality mode. I use crf 22 so not having a constant quality mode is a show stopper for me.
Good point!
Off to download now!
DigitAl56K is offline   Reply With Quote
Old 28th August 2008, 22:48   #63  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
Originally Posted by DigitAl56K View Post
How important to you is constant quality mode and what are the situation under which you'd want to use it?
I personally don't have any "mobile" device, nor do I have a "standalone" player. So I don't care about profiles, I use MPlayer or MPC+ffdshow. I want to archive captured video clips on my HDD and hence I need some "constant quality" mode. My clips are usually between 3 and 10 minutes, mostly live music. Some clips have a LOT of motion, some are more static. I want to have the "same" quality (more or less) in all my clips and I don't care if some clips are MUCH bigger than others. At the moment x264 + Psy-RD does a great job with it's "CRF" mode. So I use CRF=22 for most of my encodes, I rarely use 2-Pass. If you ever want me to consider DivX H.264 as an serious alternative to x264, you'll have to provide some mode like CRF...
Old 29th August 2008, 00:53   #64  |  Link
DigitAl56K
LoRd_MuldeR: Ah Yes! I think there has been some misunderstanding. A CRF-like mode is absolutely something we are considering! I read "constant quality" as fixed qp, although it sounds like Stax still needs a qp mode for compression check.
Old 29th August 2008, 01:06   #65  |  Link
stax76
crf like is fine for comp. check.
Old 29th August 2008, 01:07   #66  |  Link
LoRd_MuldeR
Software Developer
Good news
Old 29th August 2008, 01:19   #67  |  Link
DigitAl56K
Better news!
Old 29th August 2008, 06:51   #68  |  Link
Sorry to disappoint you:
I won't work much further on my GUI as long as there is only an "Alpha version 1".
Means: I may consider more efforts with a next encoder version... Patience. I have less life than ever before.
Old 29th August 2008, 19:23   #69  |  Link
Inventive Software
Turkey Machine
Location: Lowestoft, UK (but visit lots of places with bribes [beer])
Nice going with this BTW! It had to come whilst I was at Greenbelt! How's speed with the same settings as x264 comparable?
On Discworld it is clearly recognized that million-to-one chances happen 9 times out of 10. If the hero did not overcome huge odds, what would be the point? Terry Pratchett - The Science Of Discworld
Inventive Software is offline   Reply With Quote
Old 30th August 2008, 05:08   #70  |  Link
Ajax_Undone
I dont care so should you
Ajax_Undone's Avatar
Wow oss still kick butt Divx got to work a bit harder on that...
My Installer's ||
Ajax_Undone is offline   Reply With Quote
Old 30th August 2008, 05:16   #71  |  Link
Dark Shikari
x264 developer
Dark Shikari's Avatar
Speed can still use a lot of work--in my test DivX goes significantly slower in its fastest mode than x264 goes with psy RD and psy trellis (--subme 6 --trellis 1 --bframes 3 etc). This presents a serious problem, for obvious reasons. DivX has a huge amount of room for improvement here, so one can hope that they'll cover some ground in the next release.
Old 31st August 2008, 20:19   #72  |  Link
RickA
Greets,
Really enjoying testing out the new codec. Quality looks great. Encode times seem reasonable.
@LigH, thanks for the GUI. Very handy.
Cheers,
Rick
Rene: Could you not just wound him a little bit?
Hans: Well now, with a 25 pound shell that is not easy.
'Allo 'Allo
RickA is offline   Reply With Quote
Old 3rd September 2008, 02:11   #73  |  Link
linyx
Un-Registered User
linyx's Avatar
You may want to update a shortcut. Under Start Menu > Programs > DivX > DivX H.264 Codec CLI > Learn about DivX H2.64 Codec CLI, I think it should be "Learn about DivX H.264 Codec CLI"
linyx is offline   Reply With Quote
Old 3rd September 2008, 03:04   #74  |  Link
siva
this is beta
siva is offline   Reply With Quote
Old 3rd September 2008, 07:48   #75  |  Link
Originally Posted by siva View Post
this is beta
Sorry, couldn't resist.
Old 10th January 2009, 11:08   #76  |  Link
Kurtnoise
Swallowed in the Sea
Kurtnoise's Avatar
found a typo at the end of the stdout...
AVI 720x480
AVI frame rate parameters:(30000/1001=29.970030)
DivX H.264/AVC encoder (cli/sdk 0.0.0.5/7.3.0)
Copyright (c) 2008 DivX
[time: 0:00:32] [left: 0:00:00] [speed: 7.4 fps] [frames: 241/241]
Summary information:
Number of coded frames 241
Total encoding time 32496 ms
Average time per frame 134.838 ms
Average speed achieved 7.4 fps
Average bitrate 1987.48 kbit/sec @ 29.970 Hz
Old 10th January 2009, 17:57   #77  |  Link
Sagekilla
x264aholic
Technically that's not completely wrong, Hertz is used as a measure of frequency, in this case frames per second.
You can't call your encoding speed slow until you start measuring in seconds per frame.
Sagekilla is offline   Reply With Quote
Old 10th January 2009, 18:57   #78  |  Link
Kurtnoise
Kurtnoise's Avatar
but quite unsual...
video frame != audio frame
Old 10th January 2009, 19:42   #79  |  Link
IgorC
Hz is generic unit of frequency. It doesn't matter what. Frames per second, samples per second, apples per second, bananas per second - Hz.
Something per second.
IgorC is offline   Reply With Quote
Old 10th January 2009, 20:47   #80  |  Link
Kurtnoise
Kurtnoise's Avatar
hey, I'm not stupid...It was just a notice.
cli, divx, encoder, h.264, tutorial
