13th February 2017, 17:30 | #14141 | Link |
Hey folks! I apologize if this is the wrong thread for my post.
I have 2 Blu-ray releases of the same movie. They're different editions. I used eac3to to extract the video track from the first disc, and the audio/subtitle tracks from the other, for the purpose of muxing them together into an .mkv. Unfortunately, they don't share the same length. The video from disc #1 is 8 seconds longer than the video from disc #2. So the audio track and subtitles from disc #2 are running ahead of the picture. I calculated the exact delay, and it's 7967 ms. I used mkvmergeGUI to apply the delay in question, but to my surprise the sync was still off for ~half a second. Finally, I set it to 7217 ms and I seem to have hit the spot.. but have I? How can I be certain that I've achieved the perfect sync? Surely there must be a better way of doing this, rather than relying on my own two eyes and guessing/assuming. Is there a method for doing this with eac3to, or perhaps some other application? Thanks in advance! |
13th February 2017, 18:04 | #14143 | Link | |
Don't exist a easy tool to determine the exact amount of delay. You need found the same video frame (after credits) and the time diference is the exact delay than you need.
13th February 2017, 18:04 | #14144 | Link |
Yes, they're the same. There's a Warner Brothers intro that lasts for ~8 seconds in the beginning of my video source. That's what's causing the delay.
@tebasuna51 - You're on point. How do I find the exact video frame, and thus the time difference? Thank you! Okay (2.5hrs later), So I managed to find a frame match in both sources: https://postimg.org/image/lh6y3e68h/ I found the beginning and the ending of this "scene". But I'm confused: 7010 - 7024 - > 6839 - 6852 14 frames - > 13 frames So this still shot from the movie runs for 14 frames on the first source, while on the second one it does so for 13 frames. Do I pick the first frame of each video source and subtract, or? For example - 7010 minus 6839? What am I supposed to do? Thanks! Last edited by gzuz; 13th February 2017 at 20:29. Reason: New information. |
13th February 2017, 22:17 | #14145 | Link |
You have already the time (seems the same frame), the delay is:
4:52.375 - 4:45.243 = 7132 ms You can verify if the delay is the same at end of movie, because if there are differences (14 frames - > 13 frames) along the movie you have a serious problem.
13th February 2017, 22:54 | #14146 | Link | |
Thanks for helping me out guys, it's appreciated! |
19th February 2017, 10:17 | #14149 | Link |
HEVC is a format of video content streams. It has no audio in itself. It may have audio streams in parallel when multiplexed in containers like TS, MP4, MKV. In this case, it should not be very different from AVC video streams. The only difference I would imagine is a decoder delay, due to the higher complexity of the GOP structure and the video encoding algorithms. Would eac3to be able to consider that?
19th February 2017, 13:11 | #14150 | Link | ||
BTW extract, and delay, the audio from a mkv can work even with HEVC video. At least with a simple test: Quote:
19th February 2017, 20:13 | #14151 | Link |
結城有紀
eac3to main.ts main.aac TS, 1 audio track, 0:58:40 1: AAC, 2.0 channels, 198kbps, 48kHz Track 1 is used for destination file "main.aac". a01 Extracting audio track number 1... a01 Creating file "main.aac"... eac3to processing took 1 minute, 52 seconds. Done. I believe it only happens when a TS file is given, as with MKV it seems to work fine.
Projects x265 - Yuuki-Asuna-mod Download / GitHub TS - ADTS AAC Splitter | LATM AAC Splitter | BS4K-ASS Neo AviSynth+ filters - F3KDB | FFT3D | DFTTest | MiniDeen | Temporal Median Last edited by MeteorRain; 19th February 2017 at 20:45. |
25th February 2017, 13:01 | #14152 | Link |
Hey again guys,
I demuxed a TrueHD stream from a BD, and eac3to reported a delay of 125ms in relation to the video stream. That means the 125ms audio delay is originally included in the BD, correct? I assume I don't need to "fix" the delay when muxing into an. mkv, because that's how it got out of the studio. Am I right? Thanks in advance! Last edited by gzuz; 25th February 2017 at 16:29. |
25th February 2017, 18:16 | #14153 | Link | ||
25th February 2017, 23:39 | #14154 | Link | |
eac3to v3.31 ------------------------------------------------------------------------------ M2TS, 2 video tracks, 9 audio tracks, 26 subtitle tracks, 2:20:03, 24p /1.001 1: Chapters, 40 chapters 2: VC-1, 1080p24 /1.001 (16:9) 3: VC-1, 480p24 /1.001 (3:2), 83ms 4: AC3, English, 5.1 channels, 640kbps, 48kHz, dialnorm: -27dB, 125ms 5: TrueHD/AC3, English, 5.1 channels, 48kHz, dialnorm: -27dB, 125ms (embedded: AC3, 5.1 channels, 640kbps, 48kHz, dialnorm: -27dB) 6: AC3, Czech, 5.1 channels, 640kbps, 48kHz, dialnorm: -27dB 7: AC3, Hungarian, 5.1 channels, 640kbps, 48kHz, dialnorm: -27dB 8: AC3, Polish, 5.1 channels, 640kbps, 48kHz, dialnorm: -27dB 9: AC3, Russian, 5.1 channels, 640kbps, 48kHz, dialnorm: -27dB 10: AC3, Thai, 5.1 channels, 640kbps, 48kHz, dialnorm: -27dB 11: AC3, Turkish, 5.1 channels, 640kbps, 48kHz, dialnorm: -27dB 12: E-AC3, English, 2.0 channels, 192kbps, 48kHz, dialnorm: -27dB, 83ms 13: Subtitle (PGS), English 14: Subtitle (PGS), Chinese 15: Subtitle (PGS), Arabic 16: Subtitle (PGS), Indonesian 17: Subtitle (PGS), Bulgarian 18: Subtitle (PGS), Croatian 19: Subtitle (PGS), Czech 20: Subtitle (PGS), Estonian 21: Subtitle (PGS), Modern Greek 22: Subtitle (PGS), Hebrew 23: Subtitle (PGS), Hungarian 24: Subtitle (PGS), Icelandic 25: Subtitle (PGS), Latvian 26: Subtitle (PGS), Lithuanian 27: Subtitle (PGS), Polish 28: Subtitle (PGS), Romanian 29: Subtitle (PGS), Russian 30: Subtitle (PGS), Serbian 31: Subtitle (PGS), Slovenian 32: Subtitle (PGS), Thai 33: Subtitle (PGS), Turkish 34: Subtitle (PGS), Czech 35: Subtitle (PGS), Hungarian 36: Subtitle (PGS), Turkish 37: Subtitle (PGS), English 38: Subtitle (PGS), Chinese Creating file "C:\lol\chap.txt"... [s13] Extracting subtitle track number 13... [v02] Extracting video track number 2... [a05] Extracting audio track number 5... [a05] Extracting TrueHD stream... [a05] Removing TrueHD dialog normalization... [v02] Creating file "C:\lol\mov.vc1"... [a05] Creating file "C:\lol\sound.thd"... [s13] Creating file "C:\lol\eng.sup"... Video track 2 contains 201466 frames. Video track 3 contains 201465 frames. Subtitle track 13 contains 1473 captions. eac3to processing took 5 minutes, 11 seconds. Done. |
26th February 2017, 15:39 | #14156 | Link | |
Thanks again for the help, it's appreciated! |
15th March 2017, 20:10 | #14160 | Link |
Flac.dll 1.3.2 is available on RareWares.
http://www.rarewares.org/files/lossless/ flac_dll-1.3.2-git-20170314-icl.zip flac_dll-1.3.2-git-20170314-x64-icl.zip |
eac3to |
